查看: 2092|回复: 3
Need help about tecplot!
发表于 2004-2-10 02:22:34 | 显示全部楼层 |阅读模式
How can display the fitting function of a set of points in the graph?
Is it possible?
thanks!
 楼主| 发表于 2004-2-10 20:52:08 | 显示全部楼层
没人会么?还是不能啊
发表于 2004-2-11 01:05:25 | 显示全部楼层
I found it.
after you select the Curve, then you could find those parameters in the Menu: Data--> Curve Info
and you could write those coefficients to a txt file.
Good Luck.
 楼主| 发表于 2004-2-11 04:53:04 | 显示全部楼层
thanks indeed
