发表于 2012-9-7 02:17:04
回复 27# luo@odu.edu 的帖子
in my opinion, the CFL number is no use in standard lb. In non-standard, the cfl number may be used to choose dt. However, there are seemingly no theories that show how to choose the cfl number. choose 0.5? or 0.05? Therefore the CFL number in the lb method cannot provide its service in the conventional methods. in non-standard lb It is used to choose dt empirically.
hence it makes no sense to debate its definition. Several experts claimed that u=|u|_max/C_s, and then cfl = Ma_max. Can we use this definition to determine dt? Obviously can't, since we don't know which value of cfl number will give stable solution.
btw. i hope to learn from Prof. Luo about the relaxation times of MRT. there have been some guidences about how to choose different times, but it is seemingly still enough. In your paper, there are MRT, MRT 1, MRT 2, 3, .... You have shown that sometimes, MRT is better than another one, but in somes cases, it is inferior. Is there any theory or explanation about this problem? |
