楼主: robin
29篇piv,micro PIV文章全文提供
发表于 2005-3-13 12:40:01 | 显示全部楼层
搂主你好!不知怎么的,我一打开你上传的附件,机器就死机?
 楼主| 发表于 2005-4-8 20:59:39 | 显示全部楼层
抱歉,各位朋友,有一段时间没有来论坛了,刚刚看到各位的帖子。我会尽快把文章发给你们。祝各位工作愉快 :)
 楼主| 发表于 2005-4-8 21:05:18 | 显示全部楼层
ddouyhx 你好!没关系。这里将目录文本直接贴出来。
PIV
1) PIV studies on a submarine model
Allen Göttingen PIV01 .pdf
2) On  the accuracy of a DPIV system (algorithms and basics)
Bolinder PivAccur 1999.pdf
3) Optimization of PIV in flows with strong velocity
BolinderLundPivOpt.pdf
4) Experiments on a hydrofoil at high Reynolds-numbers
Ceccio ASME2001.pdf
5) Hydrofoil in low turbulence water tunnel at high Reynolds-numbers
CeccioATTC2001.pdf
6) Aeroacoustic coupling in cavities at very low Mach number (French)
Chatellier Poiters_Nancy 2001.pdf
7) DSPIV (dual stereo PIV) on electrokinetic microactuator arrays
Dahm Smart_control Tokyo 2001.pdf
8) Endoscopic 2D-PIV flow field measurements in IC engines
Dierksheide PIV01.pdf
9) PIV applied to landslide generated impulse waves
Fritz  Lissabon 2000.pdf
10) In-cylinder flow structure during the gas exchange process inside a small two-stroke engine
Gindele & Nauwerck_SAE.pdf
11) Fuel droplet velocities of an aero gas turbine airblast atomiser
Jermy Cranfield 1999.pdf
12) A special development of standard particle image velocimetry (PIV) to visualize and to measure the wall shear  rate in blood pumps
Kertzscher PIV01.pdf
13) Experimental study for flow fields in two dimensional wavy channels by PIV. This flow has two major applications such as a blood flow simulation and the enhancement of heat transfer in a heat exchanger
Kim Konkuk ASV62001.PDF
14) PIV measurements done in the exhaust jet of a supersonic nozzle
Laval AIAA 2001 abstract.pdf
15) Velocity distributions of the two phases are measured simultaneously , characterizing the modification of turbulence in the liquid phase by bubbles (“pseudo-turbulence”)
Lindken Göttingen PIV01.pdf
16) Non-developed pipe flow that is disturbed due to the presence of an installation inside a pipeline
Merzkirch ASV62001.pdf
17) PIV-Meßtechnik als Werkzeug zur Entwicklung von Brennverfahren in Ottomotoren mit Benzin-Direkteinspritzung (German)
Nauwerck_GALA2001.pdf
18)PIV measurements of fuel velocity on an airblast injector
Phase2PIV Cranfield.pdf
19) Interaction between flocculation and  turbulence – a method using the combination of image processing and PIV
Piirto ASME 1999.pdf
20) Determine the turbulent burning velocity in planar turbulent premixed flames stabilized by a low swirl
Plessing combustion institute 2000.pdf
21) Dreidimensionale Vermessung  der Sprühstrahlentwicklung zweier Einspritzdüsentypen zur Charakterisierung des Ausbreitungsverhaltens in Spray und Gasphase (German)
Richter_Rottenkolber_GALA2001.pdf
22) Optimization of mixture preparation in spark ignition (SI) engines
Richter_Rottenkolber_ILASS Europe 2001.pdf
23)Spray analysis of a gasoline direct injector by means of simultaneous two phase PIV
Rottenkolber St Barbara PIV99.pdf
24) Interactive Software for Turbulence Analysis from PIV Vector Data
Saarenrinne Lissabon 2000.pdf
25) A wavelet based method for the estimation of the power spectrum from irregularly sampled data
Saarenrinne lissabon 2000a.pdf
26) Theoretical and experimental investigation on particle and fluid motion in stirred media mills
Theuerkauf.pdf
27) High Speed PIV using  high-frequency diode-pumped solid state laser and multi-frame CCD
Wieneke Flow Edinburgh 2000.pdf
MicroPIV
28) A PIV system measuring velocity fields with order 1 µm spatial resolution
Werely 1999.pdf
29) Measurements of velocity fields in a MEMS device around a human red blood cell
Werely ASME 1998.pdf
发表于 2005-6-20 17:43:00 | 显示全部楼层
大好人谢谢啦,偶得邮箱ouyangxiang_2004@163.com
 楼主| 发表于 2005-6-20 19:23:29 | 显示全部楼层
各位朋友。抱歉,刚刚出差10天,没有来论坛。感谢各位的支持。遗憾的是实在没有办法用电子邮件将29篇文章一次全部发出去。想全部文章都要的朋友,麻烦您将您的邮寄地址,电话告诉我,我会用普通邮递将文章刻成光盘邮寄给您。我的电子邮件是
robinking64@sohu.com 对于没有指明要哪些文章的朋友,我只能将第一至第十篇发给您。请原谅。
发表于 2005-6-28 17:02:11 | 显示全部楼层
谢谢楼主。
发表于 2005-7-22 12:03:44 | 显示全部楼层
楼主,我的邮箱是hzhiman_1999@sina.com,麻烦你给我传一份。先谢了
发表于 2005-11-11 15:37:52 | 显示全部楼层
我想要这个,谢谢搂主
 楼主| 发表于 2005-11-12 11:10:48 | 显示全部楼层
只为喜欢
没问题,马上发给你.
发表于 2006-1-20 15:05:54 | 显示全部楼层
楼主,您是LaVision公司的吗?
请给我介绍一下你们软件的几个特色:自适应的、多重叠代的、亚像素询问窗、平移的、可变形的。
谢谢!
发表于 2006-5-16 21:52:05 | 显示全部楼层
能否都发到我的邮箱里面啊: guojunchaoab@163.com[br][br][以下内容由 guojunchaoab 在 2006年05月16日 09:52pm 时添加] [br]
duo  xie  le
发表于 2006-6-1 23:59:32 | 显示全部楼层
可否请你给我发一份??谢谢!
wufengcj@sohu.com
 楼主| 发表于 2006-6-2 10:00:56 | 显示全部楼层
Wufeng
已经发给您。请查收。
发表于 2006-6-20 14:07:46 | 显示全部楼层
大家好 我是一名就要毕业的本科生!!
我的毕业设计是关于PIV的 有谁有关于PIV 发展的文章能给我提供点 !!
在这先谢谢了!!!
 楼主| 发表于 2006-6-20 23:54:01 | 显示全部楼层
zouhaipeng
请提供一点你的联系信息,不然如何给你提供文章。
