查看: 4165|回复: 2
ZOU/HE边界是什么?
发表于 2011-11-14 11:54:11 | 显示全部楼层 |阅读模式
在书上没找到,应用在什么条件下?
发表于 2011-11-14 17:37:47 | 显示全部楼层
回复 1# 7楼 的帖子
Qisu Zou and Xiaoyi He (1997)
On pressure and velocity boundary conditions for the lattice Boltzmann BGK model, Phys. Fluids, 9, 1592-1598
Like the Inamuro model, the Zou/He model is very accurate, especially in 2D flows. In most benchmarks, it tends to be slightly less accurate, but also slightly more stable than the Inamuro approach. The 3D extension of the Zou/He model is quite straightforward, which is a great advantage of this approach.
 楼主| 发表于 2011-11-14 19:10:35 | 显示全部楼层
回复 2# xhbj 的帖子
谢谢!我找到的是这篇 “On pressure and velocity flow boundary conditions and
bounceback for the lattice Boltzmann BGK model".
