查看: 3204|回复: 2
高Re数以及Boussinesq假设
发表于 2012-4-16 20:22:18 | 显示全部楼层 |阅读模式
请问一下现在能适用于高Re数(Re>1000)的LB模型有哪些,还有对于不可压流动,有没有不是基于Boussinesq假设的热格子模型?
发表于 2012-4-27 20:57:24 | 显示全部楼层
1) For high Re flow, you can use LBE to do DNS -- no models are required. You can also use LBE-LES. Some work has been doen.
2) Energy conserving LBE does not use Boussinesq approximation. Be careful about the models to use, they may be unstable.
 楼主| 发表于 2012-5-7 15:33:52 | 显示全部楼层
回复 2# luo@odu.edu 的帖子
Thank you
