查看: 2118|回复: 1
有课题要做,实在不会,跪求各位大神!!!
发表于 2012-12-23 13:11:41 | 显示全部楼层 |阅读模式
问题如下:
The lid-driven cavity problem has been used a test or validation case for incompressible Navier-Stokes equation solvers. Let's consider two-dimensional unsteady flow in a square domain with Dirichlet boundary conditions on all sides, with three stationary sides and one moving side. Based on the lid velocity U and cavity height (or width) H, Reynolds number can be de ned as Re = UH/v  where  v is kinematic viscosity. The velocity of the impulsively started lid is given by a step function ulid = U for t  0 and ulid = 0 for t < 0.
Make your own fortran program to solve two-dimensional unsteady
ow based on a projection method. Describe your projection method in detail. Note that you may use the explicit second-order Adams-Bashforth method for convection term and Crank-Nicolson scheme for viscous term. You need to use the second-order central di erence scheme for spatial discretization in a uniform staggered grid.
谢谢啦!!!!!!!
拜托啦!!!!!!!
发表于 2012-12-23 22:28:25 | 显示全部楼层
你是学什么的啊?
