查看: 3975|回复: 6
对于角点处的反弹格式处理
发表于 2012-12-27 21:09:07 | 显示全部楼层 |阅读模式
请问对于角点处反弹格式需不需要特殊处理?
能否推荐篇相关文献呢?
谢谢!
发表于 2012-12-28 09:22:28 | 显示全部楼层
回复 1# journeyhope 的帖子
每个角点都需要另外处理,这个对于程序稳定性很重要,可以参考文献Zou, Q. and X. He (1997). "On pressure and velocity boundary conditions for the lattice Boltzmann BGK model." Physics of Fluids 9(6): 1591.
发表于 2012-12-31 06:53:38 | 显示全部楼层
Sharp Corners are singularities, thus finite-difference (FD) methods are not good to deal with them. The LBE is in fact a FD method thus it has difficulty to handle sharp corners. Having said that, MRT-LBE with bounce-back BCs in general works well to deal with corners.
When we simulate the 2D cavity flow, which has 2 top corner singularities, the MRT/TRT LBE works well.
Reference
L.-S. Luo, W. Liao, X. Chen, Y. Peng, and W. Zhang.
Numerics of the lattice Boltzmann method: Effects of collision models on the lattice Boltzmann simulations.
Physical Review E 83(5):056710 (May 2011).
发表于 2013-3-7 23:50:47 | 显示全部楼层
没有一种方法能够绝对处理奇性,只能增加一定的网格,让奇性处理引起的误差不致对周围大片区域产生显著影响,例如顶盖流动运动板与两侧壁面的角点。
发表于 2013-6-5 05:59:21 | 显示全部楼层
回复 2# hawlin 的帖子
请教 Cavity flow角点的处理方法?
是在顶盖之上再增加数层流体格点吗?
那么速度边条件该施加在哪里?
发表于 2013-6-8 15:46:34 | 显示全部楼层
回复 4# onesupeng 的帖子
Grid refinement can exacerbate numerical instability due to singularities. Tricks favored by some applied mathematicians are: (1) singularity removal technique and (2) "regularization".
发表于 2013-6-8 15:47:53 | 显示全部楼层
回复 5# wghuang 的帖子
Learn how to use MRT+LBE and bounce-back BCs. For the cavity flow, I have not seen better way than that (within the context of LBM).
