查看: 4698|回复: 10
计算流体力学的出路
发表于 2013-3-2 08:42:13 | 显示全部楼层 |阅读模式
现在做计算流体力学在哪方面会更有出路。。。。可压缩还是不可压缩。。还是。。。。
发表于 2013-3-2 12:52:25 | 显示全部楼层
回复 1# hawlin 的帖子
各有各的出路,毕竟这个世界上大部分问题不像数学中的1+1=2那样明确,且斩钉截铁。主要是看你的兴趣即可。其实都一样,建议可压缩和不可压缩都看看,看看兴趣是哪个?
发表于 2013-3-2 13:40:26 | 显示全部楼层
都玩精通不就没有问题了么~
发表于 2013-3-2 14:30:19 | 显示全部楼层
应该说都有出路,关键看你自己的机遇如何。
发表于 2013-3-5 16:56:28 | 显示全部楼层
弱弱的问一句 不编程 光玩软件的是不是一直都那么菜,研究不出啥东西啊
发表于 2013-3-8 15:50:38 | 显示全部楼层
也不能这么说。看解决什么问题。如果一个问题用现有软件能解决(当然是考虑了经济性,可靠性,精确性等因素的),那当然就用现有的就行了。相反,如果一个问题用现有的东西解决不了,那就得创造出新东西来解决,当然这个创造的方式就是发展处新理论,新技术,手段可以是编程,可以是实验等等。所以关键看你想解决的问题属于上面说的哪一类?
发表于 2013-4-25 20:45:55 | 显示全部楼层
回复 1# hawlin 的帖子
My understanding of this problem is the following. CFD is both cursed and blessed because: (1) The mathematical problem associated with the Navier-Stokes equations is nowhere near to be solved so there are things to be done; and (2) advance in computer hardware, software, and human experience allow CFD as a useful tool so there are things can be done.
CFD is related to many fields in science: mathematics, applied mathematics, and physics. One thus can pick any sub-field(s) according his/her own interest and inclination. A larger and more relevant question should be: why should someone study hard-core science at all? Why not business and such not?
One particular field which will be active for years to come is "complex and active fluids"....
[ 本帖最后由 luo@odu.edu 于 2013-4-26 00:04 编辑 ]
发表于 2013-4-26 15:37:53 | 显示全部楼层
回复 7# luo@odu.edu 的帖子
complex and active fluids是什么?求详解
发表于 2013-4-26 20:42:48 | 显示全部楼层
回复 8# sxhqjfl 的帖子
Complex fluids usually and loosely mean non-Newtonian fluids and more. Polymeric fluid is a good example. One key characteristics of complex fluids is that the Navier-Stokes equations as well as the stress-strain constitutive relation (which is valid for simple fluids) are no long applicable.
Active fluids means fluids with living/active organisms, such as blood flow or fluids with bacteria.
发表于 2013-5-14 13:48:52 | 显示全部楼层
请推荐模拟弹性血管边界的方法
有许多文章关于模拟弹性边界,请问哪种更实用
发表于 2013-5-14 15:05:36 | 显示全部楼层
原帖由 milaoshu 于 2013-3-5 16:56 发表
软件玩好了也不容易。
