查看: 2993|回复: 4
求助:非稳态流动的速度场与温度场的初始化怎么处理
发表于 2014-5-4 10:07:42 | 显示全部楼层 |阅读模式
发表于 2014-5-4 20:20:50 | 显示全部楼层
回复 1# DelvonLiu 的帖子
what kind of unsteady flows? Usually any quiescent state will do, so long as it is state initially.
 楼主| 发表于 2014-5-5 09:47:00 | 显示全部楼层
回复 2# luo@odu.edu 的帖子
多孔介质的蓄热,高温流体从罐子的上端进下端出,随着时间不断增加,介质温度不断上升。
 楼主| 发表于 2014-5-6 12:53:13 | 显示全部楼层
没明白罗老师的意思
发表于 2014-5-6 19:06:02 | 显示全部楼层
回复 3# DelvonLiu 的帖子
This appears to be a rather complex problem, although it is simple to describe.
I would assume that temperatures at entry and exit are fixed. And the thermal property of the porous media has to be specific (heat conductor or insulator). The initial field can be interpolated from the boundary conditions. This is an easy way to do it.
BTW, has your supervisor/mentor (assuming you have one) given you any ideas?
[ 本帖最后由 luo@odu.edu 于 2014-5-6 19:09 编辑 ]
