查看: 3579|回复: 2
求教
发表于 2014-5-14 14:55:38 | 显示全部楼层 |阅读模式
想问问无量纲松弛时间一般是怎么确定的啊?找不到这方面文献啊
发表于 2014-5-14 20:19:36 | 显示全部楼层
回复 1# 3.14布 的帖子
Well, there are a number of papers on this. The determination of the relaxation rates is based on the following:
1) The dimensionless parameters, such as Reynolds number;
2) The accuracy of boundary conditions;
3) The numerical stability.
You can read the following papers and references there in:
P. Lallemand and L.-S. Luo.
Theory of the lattice Boltzmann method: Dispersion, dissipation, isotropy, Galilean invariance, and stability.
Physical Review E 61:6546-6562 (June 2000)
L.-S. Luo, W. Liao, X. Chen, Y. Peng, and W. Zhang.
Numerics of the lattice Boltzmann method: Effects of collision models on the lattice Boltzmann simulations.
Physical Review E 83(5):056710 (May 2011)
 楼主| 发表于 2014-5-15 14:18:14 | 显示全部楼层
回复 2# luo@odu.edu 的帖子
谢谢您的解答!
