查看: 6985|回复: 5
[新闻动态] SU2 Education版1.2
发表于 2014-9-28 13:32:24 | 显示全部楼层 |阅读模式
SU2的学习版,非常适合初学者学习CFD经典算法。
1.2版
https://github.com/su2code/SU2_EDU/releases
SU2_EDU version 1.2.0 contains a number of improvements including:
Complete overhaul based on the latest developments in the SU2 main suite.
The deformed meshes for your airfoil are now automatically output in SU2 format for continued use (look for the file named 'mesh_AIRFOIL.su2' in the working directory after your simulation).
Improved multigrid agglomeration algorithm.
New smoothers and preconditioners for the implicit formulation.
Simplified configuration options.
General bug fixes and maintenance.
SU2 EDU User Registration
SU2 EDU Release 1.1.0
The source code is available for download here:
http://su2.stanford.edu/download/EDU/v1.1.0/SU2_EDU-1.1.000.tgz
The following binary versions are available for download:
   - Mac OS X: Gnu C++ compiler (gcc 4.2.1, Apple Inc. build 5658).
   http://su2.stanford.edu/download ... .000-Mac-64-bit.dmg
   http://su2.stanford.edu/download ... 000-SnowLeopard.tgz
   - Linux (Red Hat): Gnu C++ compiler (gcc 4.1.2 20080704, Red Hat 4.1.2-51).
   http://su2.stanford.edu/download ... -1.1.000-RedHat.tgz
   - Windows 7 Installer: Intel C++ compiler, version 12.1 (x64 and x86 platforms).
   http://su2.stanford.edu/download ... -Windows-32-bit.exe
   http://su2.stanford.edu/download ... 32-bit-Parallel.exe
Thank you for using SU2 EDU!
The SU2 team,
 楼主| 发表于 2014-10-23 21:38:45 | 显示全部楼层
粗略看了一下SU2 EDU,只能算2D airfoil,支持Euler/NS equations,需要提供airfoil的坐标数据文件,坐标数据文件可以用两种形式,Selig和Lednicer。原始计算网格是naca0012的,SU2_EDU会根据用户给定的翼型用动网格将0012的网格变形为用户给定的翼型网格。输入文件也是cfg,相关参数定义与SU2一致。
发表于 2014-11-23 12:34:07 | 显示全部楼层
xici8080 发表于 2014-10-23 21:38
粗略看了一下SU2 EDU,只能算2D airfoil,支持Euler/NS equations,需要提供airfoil的坐标数据文件,坐标数 ...
版主好厉害啊,请问您是做什么工作的啊?
发表于 2014-11-23 12:55:07 | 显示全部楼层
我没有接触过SU2,但您说"SU2_EDU会根据用户给定的翼型用动网格将0012的网格变形为用户给定的翼型网格",我感觉这个做法真的很聪明,请问您可以把这方面详细讲解一下吗?
 楼主| 发表于 2014-12-4 12:27:24 | 显示全部楼层
更新1.2版
上面那位朋友
大致过程是这样的,先读取用户给定的翼型数据,都是一个点一对x,y那种形式,然后SU2-EDU用B-spline将这些离散的点坐标拟合成曲线,再计算原始自带的NACA0012翼型表面网格点的参数坐标,利用这个参数坐标计算每个网格表面点在B-Spline中的新x,y坐标,这样就得到了每个表面网格点的位移,最后就是利用动网格方法把整体网格进行变化。
因为翼型本身变化不大,所以利用这种方法得到翼型就非常简单方便。
发表于 2015-9-10 10:45:32 | 显示全部楼层
相当好的资料
