查看: 9088|回复: 3
运行openFOAM自带例子出错
发表于 2015-1-28 17:28:59 | 显示全部楼层 |阅读模式
在运行腔体流动例子的时候,生成网格没有问题。但是在圆柱绕流例子执行blockMesh时,有如下提示:
| \\         /  F ield                | OpenFOAM: The Open Source CFD Toolbox     |
|   \\      /   O peration       | Version:  2.2.2                                                     |
|    \\   /     A nd                 | Web:      www.OpenFOAM.org                           |
|      \\/      M anipulation  |        |
Build  : 2.2.2
Exec   : blockMesh
Date   : Jan 28 2015
Time   : 17:23:24
Host   : "linux-qiko"
PID    : 10313
Case   : /home/tings/OpenFOAM/tings-2.2.2/run/tutorials/basic/potentialFoam/cylinder/constant/polyMesh
nProcs : 1
sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster
allowSystemOperations : Allowing user-supplied system call operations
Create time
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/tings/OpenFOAM/tings-2.2.2/run/tutorials/basic/potentialFoam/cylinder/constant/polyMesh/system/controlDict at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
跪求高手指导!
 楼主| 发表于 2015-1-29 09:59:52 | 显示全部楼层
已经解决了 例子默认的ployMesh没有controlDict,在里面建一个system文件夹并把controlDict就可以了
回复 支持 1 反对 0
使用道具 举报
 楼主| 发表于 2015-1-28 18:15:28 | 显示全部楼层
自己顶,我顶顶顶
发表于 2017-2-18 17:54:45 | 显示全部楼层
哈哈,谢谢你~~~
