查看: 3378|回复: 2
运动产生的新的流体粒子的LBM处理
发表于 2015-4-26 15:35:58 | 显示全部楼层 |阅读模式
请问在圆柱涡激振动的LBM模拟中,由于圆柱的运动产生新的流体粒子该如何处理呢?谢谢~
发表于 2015-4-26 22:47:47 | 显示全部楼层
You can use "overset" approach to completely remove the need of resetting the "new" fluid nodes. Otherwise, do the usual things, interpolations, extrapolations, ...
 楼主| 发表于 2015-4-27 15:36:33 | 显示全部楼层
luo@odu.edu 发表于 2015-4-26 22:47
You can use "overset" approach to completely remove the need of resetting the "new" fluid nodes. Oth ...
好的,明白了,谢谢罗老师~
