查看: 5931|回复: 5
[新闻动态] SU2 v4.0 Cardinal
发表于 2015-6-24 10:08:58 | 显示全部楼层 |阅读模式
SU2 v4.0 has a number of notable new capabilities, including:
•Non-ideal compressible fluid flows (NICFD): Van der Waals and Peng-Robinson equations of state.
•Fully-parallel preprocessing with ParMETIS.
•SA-neg turbulence model.
•Adaptive CFL.
•Easily generate FFD boxes with new options.
•Force breakdown file and FieldView output.
•Scale, rotate, translate meshes in SU2_DEF.
•Iterative smoothers: Jacobi, LU-SGS, ILU(0).
•General bug fixes and performance improvements.
Download:
http://su2.stanford.edu/download.html
or
https://github.com/su2code/SU2/releases
 楼主| 发表于 2015-6-24 11:21:35 | 显示全部楼层
发表于 2015-6-26 08:28:00 来自手机 | 显示全部楼层
下载了一个,在win下编译了一遍,config_structure.cpp里有个time()和ctime()函数说没定义。不用它们,就编译过去了。串行的。
发表于 2015-9-16 07:36:43 | 显示全部楼层
能否共享一个官方编译的windows安装文件?谢谢!
 楼主| 发表于 2015-12-19 10:34:43 | 显示全部楼层
4.0版本的主要变化是代码全部变成并行了,支持大规模并行
发表于 2016-7-6 11:43:49 | 显示全部楼层
很好,赞
新版本功能越来越多了
