Need help about tecplot!
herodazhu
herodazhu
发表于 2004-2-10 02:22:34
How can display the fitting function of a set of points in the graph?
Is it possible?
thanks!
herodazhu
herodazhu
发表于 2004-2-10 20:52:08
没人会么?还是不能啊
boling2000
boling2000
发表于 2004-2-11 01:05:25
I found it.
after you select the Curve, then you could find those parameters in the Menu: Data--> Curve Info
and you could write those coefficients to a txt file.
Good Luck.
herodazhu
herodazhu
发表于 2004-2-11 04:53:04
thanks indeed
