查看: 11418|回复: 1
TENO based open-source hypersonic flow solver
发表于 2020-3-17 03:24:40 | 显示全部楼层 |阅读模式
A new hypersonic flow solver from Center for Turbulence Research at Stanford University is published. The solver is based on the sixth-order low-dissipation TENO6-A scheme for shock-capturing and the code is open-source:
https://www.researchgate.net/pub ... _aerothermodynamics
https://www.sciencedirect.com/sc ... i/S0010465520300837
 楼主| 发表于 2021-2-26 03:30:09 | 显示全部楼层
Open-source codes based on the high-order TENO schemes for complex fluids:
OpenSBLI solver
Based on TENO5, TENO6 and TENO8
A framework for the automated derivation and parallel execution of finite difference solvers on a range of computer architectures.
Lusher, David J., Satya P. Jammy, and Neil D. Sandham. “OpenSBLI: Automated code-generation for heterogeneous computing architectures applied to compressible fluid dynamics on structured grids.” arXiv preprint arXiv:2007.14933 (2020).
Code repository, https://github.com/LMNS3d/opensbli
HTR solver
Based on TENO6-A
An open-source exascale-oriented task-based multi-GPU high-order code for hypersonic aerothermodynamics
Renzo, Mario Di; Fu, Lin; Urzay, Javier; “HTR solver: An open-source exascale-oriented task-based multi-GPU high-order code for hypersonic aerothermodynamics,” Computer Physics Communications, (2020): 107262.
TENO scheme and HTR solver have supported the DOE PSAAP 3 (Predictive Science Academic Alliance Program) project at Stanford University, link for psaap 3 at stanford.
Code repository, https://data.mendeley.com/datasets/9zsxjtzfr7/1
ALPACA solver
Based on TENO5
A MPI-parallelized C++ code framework to simulate compressible multiphase flow physics
Hoppe, Nils; Adami, Stefan; Adams, Nikolaus A. ; “A modular massively parallel computing environment for three-dimensional multiresolution simulations of compressible flows,” arXiv:2012.04385, (2020).
Code repository, https://gitlab.lrz.de/nanoshock/ALPACA
MPI-AMRVAC solver
Based on TENO5-A
MPI-AMRVAC: A Parallel Adaptive Mesh Refinement Framework
van der Holst, Bar, et al. “MPI-AMRVAC: MPI-adaptive mesh refinement-versatile advection code,” Astrophysics Source Code Library (2012): ascl-1208.
Code repository, https://github.com/amrvac/amrvac
