查看: 4075|回复: 0
[导师招生] Two (2) Ph.D. Positions at UMass Lowell, Fluid Dynamics and Machine Learning
发表于 2022-3-13 03:53:03 | 显示全部楼层 |阅读模式
Two new Ph.D. positions (2022-2023)are available for the Department of Biomedical Engineering at the University ofMassachusetts Lowell.
ML+FD Ph.D. Position:
The research will involve theapplications of fluid dynamics and machine learning.
Qualifications:
  • a Bachelor's or equivalent degree in engineering     (Computer, Mechanical, Biomedical, and Aerospace), applied mathematics, or     related fields. Applicants with a master's degree are preferred.
  • Previous research experience is highly desirable but     not required. Desirable research skills include
    • computational or experimental modeling technique in      fluid dynamics
    • fluid-structure interaction
    • programming (C, C++, or Python).
  • Strong oral and written communication skills.
Review of applications will beginimmediately. Interested students should send a single PDF containing thefollowing items to ZhenglunAlan_Wei@uml.edu with a "Ph.D. Application(ML+FD)" in the subject line.
  • Curriculum Vitae
  • Personal statement (including research interests and     availability)
  • Unofficial transcript(s)
ML+Cardio Ph.D. Position:
The research will involve machinelearning applications in machine learning, medical image processing, andpreventative cardiology.
Qualifications:
  • Previous research experience is highly desirable.     Desirable research skills include machine learning and programming (C,     C++, or Python).
Review of applications will beginimmediately. Interested students should send a single PDF containing thefollowing items to ZhenglunAlan_Wei@uml.edu with a "Ph.D. Application(ML+Cardio)" in the subject line.
  • Curriculum Vitae
  • Contact information for three references
