查看: 2706|回复: 0
mpcci报错了,怎么办,好像是abaqus有问题,数据没有传输成功
发表于 2023-4-14 11:26:50 | 显示全部楼层 |阅读模式
MpCCI-CSE:    Coupling scheme is "Explicit".
MpCCI-CSE:    Jacobi iteration algorithm.
MpCCI-CSE: Registering mesh part "ASSEMBLY_TUBE-1_INTWALL" with SIMULIA Co-Simulation Services...
MpCCI-CSE: Create field quantity definition "WallHeatFlux" at element.
MpCCI-CSE: Registering outgoing quantity" WallHeatFlux".
MpCCI-CSE: Create field quantity definition "WallTemp" at node.
MpCCI-CSE: Registering incoming quantity "WallTemp".
Establishing connection with host PC-20191023XCMG on port 51464.
Successfully connected to host PC-20191023XCMG on port 51450.
Successfully connected to host PC-20191023XCMG on port 51464.
MpCCI-CSE: Coupling grid definition for surface (id: 4) "ASSEMBLY_TUBE-1_INTWALL"...
MpCCI-CSE: Defining 161 nodes...
MpCCI-CSE: Defining 160 elements...
MpCCI-CSE:    This surface has unique element types.
MpCCI-CSE: Server: 47010@pc-20191023xcmg
MpCCI-CSE:    Part  : "ASSEMBLY_TUBE-1_INTWALL"
MpCCI-CSE:       MeshDim(2), MeshId(1), PartId(4), Nodes(161), Elements(160)
MpCCI-CSE:    2 Quantities:
MpCCI-CSE:       Direction(RECV), Dimension(1), Location(ELEM), Storage(Buffer/1), Name(WallHeatFlux)
MpCCI-CSE:       Direction(SEND), Dimension(1), Location(NODE), Storage(Direct/0), Name(WallTemp)
MpCCI-CSE: Starting MpCCI transfer...
MpCCI-CSE: No data transfer occurred.
MpCCI-CSE: Put field skipped: no quantity surface_heat_flux has been yet received...
MpCCI-CSE:
MpCCI-CSE: **** START increment...
*** MpCCI remote process fatal error: pc-20191023xcmg:mpcci_server.exe:
mpcci报错,流固耦合问题
*** MpCCI remote process fatal error: [MpCCI-SERVER]: *** ERROR *** 1 errors found while searching for mesh pairings.
*** MpCCI remote process fatal error: Exiting due to fatal error on Fri Apr 14 11:15:43 2023
*** MpCCI remote process fatal error: 0.046875 seconds CPU time used.
Error during data transfer:
Check log file for information.
Terminating connection with MpCCI .... Bye.
Error in MpCCI client call: "QUIT":
Connection to the server is finally closed.
4/14/2023 11:15:44 AM
Abaqus Error: Abaqus/Standard Analysis exited with an error - Please see the
message file for possible error messages if the file exists.
Abaqus/Analysis exited with errors
Abaqus has finished with exit code #256.
Finishing the job for Abaqus...
