查看: 3392|回复: 4
一维导热问题,学simple想从简单学起的同学看过来。
发表于 2003-4-12 03:45:56 | 显示全部楼层 |阅读模式
*                       COND1DC (PART I)                                 *
*      A FINITE VOLUME PROGRAM FOR THE SOLUTION OF ONE-DIMENSIONAL       *
*   STEADY CONDUCTION-TYPE PROBLEMS IN THE CARTESIAN COORDINATE SYSTEM   *
* DEVELOPED BY :  B. RABI BALIGA                                         *
* PREPARED FOR COMPUTATIONAL PHYSICS CLASS BY A. GHODS                   *
* DATE         :  APRIL 21, 2000                                         *
*                  COND1DC IS A TWO-PART PROGRAM                         *
*          PART I:  PROBLEM-INDEPENDENT PORTION OF COND1DC - IT CONSISTS *
*                   OF THE MAIN PROGRAM 'COND1DC' AND THE FOLLOWING      *
*                   SUBROUTINES:                                         *
*                   SETUP; COEFF; SOLVE; DETOUT; AND COEFFP              *
*  NOTATION :
*            AN(J) - THE NORTH NEIGHBOR COEFFICIENT FOR THE J NODE
*            AP(J) - COEFFICIENT FOR THE J NODE
*            AS(J) - THE SOUTH NEIGHBOR COEFFICIENT FOR THE J NODE
*           CON(J) - THE CONSTANT ASSOCIATED WITH THE DISCRETIZED
*                    EQUATION FOR THE J NODE
*           CONVGE - LOGICAL EXPRESSION: DEFAULT VALUE IS .FALSE.:
*                    TERMINATES PROGRAM WHEN SET TO .TRUE.
*          F(J,NF) - ANY ONE OF A MAXIMUM OF NV (NF = 1 TO NV) DEPENDENT
*                    VARIABLES OF INTEREST
*           GAM(J) - DIFFUSION COEFFICIENT
*             ITER - ITERATION COUNTER
*            ITSRT - STARTING VALUE OF ITER IN A PARTICULAR RUN
*             JREF - J INDEX OF A USER-SPECIFIED REFERENCE NODE
*       LPRINT(NF) - LOGICAL VARIABLE: DEFAULT VALUE IS .FALSE.: IF SET
*                    TO .TRUE. A DETAILED PRINTOUT OF THE ASSOCIATED
*                    F(J,NF) IS OBTAINED
*       LSOLVE(NF) - LOGICAL VARIABLE DEFAULT VALUE IS ,FALSE.: IF SET
*                    TO .TRUE.,  F(J,NF) IS SOLVED
*            MAXIT - USER-SPECIFIED MAXIMUM NUMBER OF ITERATIONS DESIRED
*               M1 - LAST NODE IN THE Y-DIR.
*               M2 - SECOND TO LAST NODE IN THE Y-DIR.
*               NF - REPRESENTS THE DEPENDENT VARIABLE BEING SOLVED
*               NY - TOTAL # OF NODES IN THE Y DIRECTION: USER INPUT PARAMETER
*               NV - TOTAL # OF DEPENDENT VARIABLES; USER INPUT PARAMETER
*           PCOEFF - LOGICAL VARIABLE: DEFAULT VALUE IS .FALSE.: IF SET TO
*                    .TRUE., ALLOWS A DETAILED PRINTOUT OF COEFFICIENTS:
*                    USEFUL FOR DEBUGGING DURING PROGRAM DEVELOPMENT
*            PT(J) - RECURRENCE VARIABLE USED IN TDMA ALGORITHM
*            QT(J) - RECURRENCE VARIABLE USED IN TDMA ALGORITHM
*        RELAX(NF) - DENOTES THE UNDER-RELAXATION PARAMETER FOR F(I,J,NF)
*            SC(J) - CONSTANT THE LINEARIZED SOURCE TERM
*            SP(J) - COEFFICIENT OF F(J,NF) IN THE LINEARIZED SOURCE TERM
*             Y(J) - Y-COORDINATE OF JTH NODAL POINT
*           YCV(J) - DISTANCE BETWEEN ADJACENT MAIN-GRID CV FACES
*                    IN THE Y-DIR.
*          YDIF(J) - DISTANCE BETWEEN ADJACENT MAIN-GRID NODES (J - 1) & J
*               YL - TOTAL LENGTH OF CALC. DOMAIN IN THE Y-DIR.
*             YPOW - USED TO PRODUCE AN UNEVEN NODAL DISTRIBUTION IN Y-DIR.
*            YV(J) - JTH MAIN-GRID CV FACE LOCATION
      PROGRAM COND1DC
*     INCLUDING COMMON BLOCK
      INCLUDE 'cblk3.for'
*     DOMAIN DISCRETIZATION AND RELATED CALCULATIONS
      CALL GRID
      CALL SETUP
*     ASSIGN DEFAULT VALUES TO CONTROL VARIABLES & OTHER VARIABLES IF DESIRED
      CALL DEFVAL
*     SOLUTION SEQUENCE FOR STEADY ONE-DIMENSIONAL CONDUCTION-TYPE PROBLEMS
      CALL START
10    ITER  = ITER + 1
      DO 20 NF = 1, NV
         IF (LSOLVE(NF)) THEN
            CALL GAMSOR
            CALL COEFFS
            CALL BOUND
            CALL SOLVE
         ENDIF
20    CONTINUE
      CALL OUTPUT
      IF ((.NOT.CONVGE).AND.(ITER.LT.MAXIT)) GO TO 10
      STOP
      END
      SUBROUTINE  SETUP
*     THE FUNCTION OF THIS SUBROUTINE IS TO SET UP ALL GRID-RELATED QUANTITIES
*     USED IN THE FORMULATION OF THE FINITE VOLUME METHOD
*     INCLUDING THE COMMON BLOCK
      INCLUDE 'cblk3.for'
*      NOTATION :
*                    IN THE Y-DIR.
*            YV(J) - JTH MAIN-GRID CV FACE LOCATION (USER SPECIFIED)
*     THESE FOLLOWING VARIABLES ARE INITIALIZED, BUT NOT USED IN THE FVM
      YDIF(1) = 0.0D+00
*     SET UP GRID-RELATED QUANTITIES USING USER-SPECIFIED Y(J)'s
*       NOTE:  THIS FVM IS SETUP FOR TYPE-A GRID (REF. PATANKAR)
      YV(1) = Y(1)
      DO 20 J = 2, M1
         YV(J) = (Y(J-1) + Y(J)) * 0.5D+00
         YDIF(J) = Y(J) - Y(J-1)
         YCV(J-1) = YV(J) - YV(J-1)
20    CONTINUE
      YV(M1+1) = Y(M1)
      YCV(M1) = YV(M1+1) - YV(M1)
      RETURN
      END
      SUBROUTINE COEFFS
*     THE FUNCTION OF THIS SUBROUTINE IS TO EVALUATE THE COEFFICIENTS
*     IN THE DISCRETIZED EQUATIONS
      INCLUDE 'cblk3.for'
*     NOTATION :
*     THE SOUTH COEFFICIENT FOR NODE 1 IS ZERO
      AS(1) = 0.0D+00
*     THE NORTH COEFFICIENT FOR NODE M1 IS ZERO
      AN(M1) = 0.0D+00
*     CALCULATE THE OTHER NORTH AND SOUTH COEFFICIENTS
      DO 10 J = 1, M2
         JP1 = J + 1
*        RESISTANCE-TYPE INTERPOLATION FOR THE DIFFUSION COEFFICIENTS
*          NOTE: WITH THE TYPE-A GRID, THIS BECOMES THE HARMONIC MEAN
*            -  GAMN REFERS TO THE INTERPOLATED VALUE OF GAMMA AT THE
*               NORTH FACE OF THE CV FOR NODE J
         GAMN = 2.0D+00 * GAM(J) * GAM(JP1) / (GAM(J) + GAM(JP1)
     +          + 1.0D-50)
         AN(J) = GAMN / YDIF(JP1)
*        NOTE: THE NORTH COEFFICIENT FOR NODE J EQUALS THE SOUTH COEFFICIENT
*               FOR NODE J+1 - REMEMBER THAT THIS IS A CODUCTION CODE
         AS(JP1) = AN(J)
10    CONTINUE
*     CALCULATE THE PARTICULAR-POINT COEFFICIENTS AP(J) AND UNDER-RELAX:
*     RELAX(NF) DENOTES THE UNDER-RELAXATION PARAMETER.  ALSO CALCULATE
*     THE CON(J) TERMS, AND THE UNDER-RELAXATION CONTRIBUTION
*       NOTE:  THE IMPLICIT UNDER-RELAXATION TECHNIQUE OF PATANKAR IS USED
      REL = 1.0D+00 - RELAX(NF)
      DO 20 J = 1, M1
         AP(J) = (AN(J) + AS(J) - SP(J)*YCV(J)) / RELAX(NF)
         CON(J) = SC(J) * YCV(J) + REL * AP(J) * F(J,NF)
20    CONTINUE
*     IF AN OUTPUT OF THE COEFFS. IS DESIRED IN FILE COEFF.DAT,
*       SET PCOEFF = .TRUE. IN SUBROUTINE START
      IF (PCOEFF) CALL COEFFP
      RETURN
      END
      SUBROUTINE SOLVE
*     THIS SUBROUTINE IMPLEMENTS A TRI-DIAGONAL-MATRIX-ALGORITHM FOR THE
*     SOLUTION OF THE LINEAR, OR NOMINALLY-LINEAR, DISCRETIZATION EQUATIONS
      INCLUDE 'cblk3.for'
*     PT AND QT ARE THE RECURRENCE VARIABLES FOR A TDMA
      DIMENSION PT(NY), QT(NY)
*     STARTING VALUES FOR THE RECURRENCE VARIABLES
      PT(1) = AN(1) / AP(1)
      QT(1) = CON(1) / AP(1)
*     CALCULATE OTHER RECURRENCE VARIABLES
      DO 10 J = 2, M1
         JM1 = J - 1
         DENOM = AP(J) - AS(J) * PT(JM1)
         PT(J) = AN(J) / DENOM
         QT(J) = (CON(J) + AS(J) * QT(JM1)) / DENOM
10    CONTINUE
*     INITIATE BACK-SUBSTITUTION.
      F(M1,NF) = QT(M1)
*     PERFORM THE BACK-SUBSTITUTION FOR J = M2, ............, 3, 1
      DO 20 J = 1, M2
         JJ =  M1 - J
         JJP1 = JJ + 1
         F(JJ, NF) = PT(JJ) * F(JJP1, NF) + QT(JJ)
20    CONTINUE
      RETURN
      END
      SUBROUTINE DETOUT
*     THE FUNCTION OF THIS SUBROUTINE IS TO PROVIDE A DETAILED FIELD OUTPUT
*     OF THE DEPENDENT VARIABLES OF INTEREST ( SET LPRINT(NF) = .TRUE. )
      INCLUDE 'cblk3.for'
*     FORMAT STATEMENTS
100   FORMAT( A4 , 4X, 6(I4, 8X) )
200   FORMAT( A7 , 6(1PD10.3, 2X) )
300   FORMAT( / A20, / A20 / )
400   FORMAT( /// 6(1H*), 3X, A5, I2, 2X, A6, I2, A2, 3X, 6(1H*) /
     +        9X, 19(1H-)//)
500   FORMAT( A4, 5X, 6(I4, 8X) )
600   FORMAT( 6X, 6(1PD10.3, 2X) )
700   FORMAT( 1X /)
      WRITE(6,700)
      WRITE(6,*)   '  COMPUTATION OF STEADY CONDUCTION-TYPE PROBLEMS'
      WRITE(6,*)   '      IN A 1-D CARTESIAN COORDINATE SYSTEM'
      WRITE(6,*)   '  ----------------------------------------------'
      JEND = 0
20    JBEG = JEND + 1
      JEND = JEND + 6
      IF (JEND .GT. M1) JEND = M1
      WRITE(6,100) ' J =', (J, J = JBEG, JEND)
      WRITE(6,200) ' Y(J) =', (Y(J), J = JBEG, JEND)
      WRITE(6,200) ' YV(J)=', (YV(J), J = JBEG, JEND)
      IF (JEND .LT. M1) GO TO 20
      DO 50 NF = 1, NV
         IF (LPRINT(NF)) THEN
            WRITE(6,400) 'NF = ', NF, ' F(J, ', NF, ') '
            JEND = 0
30          JBEG = JEND + 1
            JEND = JEND + 6
            IF (JEND.GT.M1) JEND = M1
            WRITE(6,500) ' J =', (J, J= JBEG, JEND)
            WRITE(6,600) (F(J,NF), J = JBEG, JEND)
            IF (JEND.LT.M1) GO TO 30
         ENDIF
50    CONTINUE
      RETURN
      END
      SUBROUTINE COEFFP
*     THE FUNCTION OF THIS SUBROUTINE IS TO OUTPUT THE COEFFICIENTS
*     FOR THE DEPENDENT VARIABLES OF INTEREST, e.g. IF DEBUGGING IS REQUIRED
*       NOTE:  COEFFS. ARE OUTPUTTED TO FILE COEFF.DAT
      INCLUDE 'cblk3.for'
*     FORMAT STATEMENTS
100   FORMAT( A5, 1X, I2 // )
200   FORMAT( '1' /)
300   FORMAT( 2X, I2, 2X, 4(1PE10.3, 2X) )
400   FORMAT( A4, 2X, 4(2X, A4, 6X), / )
      OPEN( UNIT = 7, FILE = 'COEFF.DAT', STATUS = 'UNKNOWN')
      REWIND 7
      WRITE(7,200)
      WRITE(7,100) '0NF =', NF
      WRITE(7,400) ' J = ',  ' AN ', ' AS ', ' AP ', ' CON '
      DO 10 J = 1, M1
         WRITE(7,300) J, AN(J), AS(J), AP(J), CON(J)
10    CONTINUE
      CLOSE( UNIT = 7 )
      RETURN
      END
*                         CD1DC (PART II)                                *
* PREPARED FOR  STUDENTS IN THE GRADUATE COURSE ON COMPUTATIONAL PHYSICS *
*            BY A. GHODS                                                 *
* DATE        21 APRIL 2000                                              *
*                  CD1DC IS A TWO-PART PROGRAM                           *
*         PART II:  PROBLEM-DEPENDENT PORTION OF CD1DC - IT CONSISTS     *
*                   OF THE FOLLOWING SUBROUTINES                         *
*                   GRID; DEFVAL; START; GAMSOR; BOUND; AND OUTPUT       *
*  SPECIALIZATION:  THIS VERSION IS DESIGNED TO SOLVE UNSTEADY           *
*                   HEAT 1-D HEAT CONDUCTION IN THIN PLATE THERMAL       *
*                   ISOLATED IN ALL OF ITS FACES EXCEP THOSE IN Y        *
*                   DIRECTION                                            *
*  NOTATION :
*          F(J,NF) - ANY ONE OF A MAXIMUM OF TEN (NF = 1 TO 10) DEPENDENT
*            PT(N) - RECURRENCE VARIABLE USED IN TDMA ALGORITHM
*            QT(N) - RECURRENCE VARIABLE USED IN TDMA ALGORITHM
*                    IN THE Y-DIR.
      SUBROUTINE GRID
*     THE PURPOSE OF THIS SUBROUTINE IS TO ENABLE THE USER TO INPUT THE
*     COORDINATES OF THE GRID POINTS
      INCLUDE 'cblk3.for'
*      NOTATION :
*            YL - EXTENT FO THE CALCULATION DOMAIN IN THE Y-DIR.
*          YPOW - EXPONENT IN A POWER-LAW TYPE DISTRIBUTION OF NODES
*     NOTE:  THIS IS ALSO A GOOD POINT TO ASSIGN A VALUE TO THE
*            REFERENCE NODE, JREF
      WRITE(*,*) ' M1 = ?'
      WRITE(*,*) '  '
      READ(*,*) M1
      M2 = M1 - 1
      JREF = M1
*     INPUT THE LENGHT OF THE CONDUCTING MATERIAL, H, IN METERS
      H = 100.D+00
*     INPUT THE Y-EXTENT OF THE CALCULATION DOMAIN:  HERE, WE'LL
      YL = H
*     GENERATE THE GRID:  POWER-LAW TYPE GRID; YPOW = 1 IMPLIES UNIFORM
*                         GRID; YPOW > 1 CROWDS NODES IN THE VICINITY OF
*                         THE BOTTOM WALL
      YPOW = 1.0D+00
      Y(1) = 0.0D+00
      Y(M1) = YL
      DO 20 J = 2, M2
         Y(J) = (DFLOAT(J-1) / DFLOAT(M1 - 1)) ** YPOW * YL
20    CONTINUE
      RETURN
      END
      SUBROUTINE DEFVAL
*     THE PURPOSE OF THIS SUBROUTINE IS TO ASSIGN DEFAULT VALUES TO CONTROL
*     PARAMETERS AND ANY DESIRED VARIABLES
      INCLUDE 'cblk3.for'
*     NOTATION :
*            CONVGE - TERMINATES EXECUTION OF THE PROGRAM WHEN SET TO TRUE
      ITSRT= 0
      ITER = ITSRT
      MAXIT = 10
      CONVGE = .FALSE.
      PCOEFF = .TRUE.
      DO 30 NF = 1, NV
         LSOLVE(NF) = .FALSE.
         LPRINT(NF) = .FALSE.
         RELAX(NF)  = 1.0D+00
*        SET ALL F(J,NF) TO ZERO
         DO 40 J = 1, M1
            F(J,NF) = 0.0D+00
40       CONTINUE
30    CONTINUE
      RETURN
      END
      SUBROUTINE START
*     THE PURPOSE OF THIS SUBROUTINE IS TO INPUT ALL PROBLEM-DEPENDENT
*     PARAMETERS AND ASSIGN PROPER INITIAL OR GUESS VALUES TO F(J,NF)
      INCLUDE 'cblk3.for'
*     SET LOGICAL PARAMETERS TO .TRUE. FOR NF = 1 : I.E. SOLVE FOR T(J)
      LSOLVE(1) = .TRUE.
*     SET THE RELAXATION PARAMETER FOR NF = 1
      RELAX(1) = 1.0D+00
*     READ IN VALUES OF VISC, DEN, AND DPDX
*       HERE, VALUES CLOSE TO THOSE FOR AIR
*       ARE SPECIFIED - THIS IS NOT GOING TO
*       INFLUENCE THE NONDIMENSIONAL RESULTS
*        - E.G. U/UAV AND FRE
*     SPECIFY THERMAL CONDUCTIVITY IN ?
      CONDUCT = 5.0
*     SPECIFY THE VALUE OF HEAT GENERATION
      HGEN=0
*     SET GUESS VALUES FOR T(J) IN THE DOMAIN: THE WALL VALUE = 0.0
      DO 10 J = 1, M1
         T(J) = 0.0D+00
10    CONTINUE
*     SPECIFY TEMPERATURE AT TOP AND BOTTOM BOUNDARY
      TB=0.0D+00     ! B.C. AT THE BOTTOM
      Tt=100.0D+00   ! B.C. AT THE TOP
      T(1) =TB
      T(M1) =TT
*     NOTE: IF ISTART = 1, THEN THE PROBLEM IS RUN FROM SCRATCH (ITER = 0)
*           IF ISTART > 1, THEN THE PROBLEM IS STARTED FROM THE RESULTS OF
*           THE LAST RUN
      WRITE(*,*) ' ISTART = ?'
      WRITE(*,*) '  '
      READ(*,*) ISTART
      IF (ISTART.GT.1) THEN
      OPEN (UNIT = 51, FILE = 'DATAIN.DAT', STATUS = 'UNKNOWN')
      REWIND 51
      READ(51,*) ITSRT
      DO 20 J = 1, M1
         READ(51,*) (F(J,NF), NF = 1, NV)
20    CONTINUE
      ITER = ITSRT
      WRITE(*,*) 'ITSRT = ', ITSRT, ' F(JREF,1) =', F(JREF,1)
      CLOSE (UNIT = 51)
      ENDIF
*     SET MAXIT
      WRITE(*,*) ' STARTING ITER = ', ITER
      WRITE(*,*) ' MAXIT = ?'
      WRITE(*,*) '  '
      READ(*,*) MAXIT
      RETURN
      END
      SUBROUTINE GAMSOR
*     THE PURPOSE OF THIS SUBROUTINE IS TO ASSIGN ALL DIFFUSION COEFFICIENTS
*     AND SOURCE TERMS: GAM(J), SC(J), AND SP(J) FOR EACH DEPENDENT VARIABLE
*     THAT IS BEING SOLVED
      INCLUDE 'cblk3.for'
*       NOTE:  HERE, ONLY NF = 1, I.E. T(J), IS BEING SOLVED
      DO 30 J = 1, M1
         GAM(J) = CONDUCT
         SC(J) = HGEN
         SP(J) = 0.0D+00
30    CONTINUE
      RETURN
      END
      SUBROUTINE BOUND
*     THE PURPOSE OF THIS SUBROUTINE IS TO INPUT BOUNDARY INFO., IF NEEDED
      INCLUDE 'cblk3.for'
*     SET THE VALUE OF T AT THE BOTTOM WALL TO ZERO: T(1) = 0.0D+00
      AP(1) = 1.0D+00
      AN(1) = 0.0D+00
      AS(1) = 0.0D+00
      CON(1) = TB
*     SET THE VALUE OF T AT THE TOP    WALL TO Tt: T(J) = Tt
      AP(M1) = 1.0D+00
      AN(M1) = 0.0D+00
      AS(M1) = 0.0D+00
      CON(M1) =TT
*     CALCULATE THE RESIDUE TO MONITOR THE CONVERGENCE IN OUTPUT
      RESID = 0.0D+00
      RES = 0.0D+00
      DO 10 J = 1, M1
         RES = AP(J) * T(J) - CON(J)
         IF (J .NE. 1) THEN
           RES = RES - AS(J) * T(J-1)
         ENDIF
         IF (J .NE. M1) THEN
            RES = RES - AN(J) * T(J+1)
         ENDIF
      RESID = RESID + DABS(RES)
10    CONTINUE
      RETURN
      END
      SUBROUTINE OUTPUT
*     THIS SUBROUTINE IS MAINLY USED TO SET UP OUTPUT OF DESIRED RESULTS;
*     BUT IT COULD ALSO BE USED TO SET CONVERGENCE CRITERIA; MONITOR
*     CONVERGENCE; AND CALCULATE AUXILIARY RESULTS
      INCLUDE 'cblk3.for'
*     OPEN THE MONIT.DAT FILE TO SAVE CONVERGENCE MONITORING INFO, IF NEEDED
*      NOTE:  THIS IS DONE ONLY FOR THE FIRST ITERATION OF EACH RUN
      IF (ITER.LE.ITSRT+1) THEN
          OPEN (UNIT = 11, FILE = 'MONIT.DAT', STATUS = 'UNKNOWN')
          REWIND 11
      ENDIF
      WRITE(11,*) ' ITER =', ITER,'  F(JREF,1) =', F(JREF,1)
      WRITE(11,*)
*     WRITE MONITORING INFO TO SCREEN IF DESIRED
      WRITE(*,*) ' ITER =', ITER,'  F(JREF,1) =', F(JREF,1)
      WRITE(*,*)
*     CONVERGENCE CRITERION
*       NORMALIZE THE RESIDUE W.R.T. THE THERMAL. FLUX. AT THE WALL
        WMFLUX = HGEN * YCV(1) + CONDUCT * (T(2) - T(1)) / YDIF(2)
        RESID = RESID / WMFLUX
      IF (RESID .LE. 1.0D-06) CONVGE = .TRUE.
      IF ((ITER.EQ.MAXIT).OR.CONVGE) THEN
*     CLOSE UNIT = 11 : THE MONIT FILE
         CLOSE (UNIT = 11)
*     OUTPUT ALL DESIRED DATA
*       FIRST DUMP RESTART DATA ON TO DATAOUT.DAT
         OPEN (UNIT = 50, FILE = 'DATAOUT.DAT', STATUS = 'UNKNOWN')
         REWIND 50
         WRITE(50,*) ITER
         DO 20 J = 1,M1
            WRITE(50,*) (F(J,INF), INF = 1, NV)
20       CONTINUE
         CLOSE (UNIT = 50)
*        PREPARE UNIT 6 FOR PLOTTING OUTPUT, IF DESIRED
         OPEN (UNIT = 6, FILE = 'PLOTFILE.DAT', STATUS = 'UNKNOWN')
         REWIND 6
   WRITE(*,*)'Y(J)          T(J)'
         DO 500 J = 1, M1
            WRITE(6,*) Y(J), T(J)
500      CONTINUE
         CLOSE (UNIT = 6)
      ENDIF
      IF (CONVGE) THEN
         WRITE(*,*) ' THE NUMERICAL SOLUTION CONVERGED.'
         WRITE(*,*) ' NUMBER OF ITERATIONS : ', ITER
      ELSE
         CONTINUE
      ENDIF
      RETURN
      END
 楼主| 发表于 2003-4-12 03:47:42 | 显示全部楼层
clbk3.for
发表于 2003-4-15 17:23:34 | 显示全部楼层
能否给出所用的公式和对应格式说明???3X
 楼主| 发表于 2003-4-17 23:03:48 | 显示全部楼层
SORRY,我也没仔细研究。Pantanka 的书应该看看。
 楼主| 发表于 2003-4-18 02:28:50 | 显示全部楼层
Formula for 1D heat conduction.
