查看: 3082|回复: 6
谁有面元法的求解程序?
发表于 2003-4-22 15:13:17 | 显示全部楼层 |阅读模式
那位有,我的e-mail:firedragon111@163.com
我有好东东与你交换。
发表于 2003-4-23 01:42:42 | 显示全部楼层
谁有面元法的求解程序?
       program main
c
       parameter( npmx = 101 )
c
c----  All common blocks listed here.
c
       common/bod   / nlower, nupper, nodtot, np1, ss,
     &                x(npmx+1), y(npmx+1), xm(npmx), ym(npmx),
     &                costhe(npmx), sinthe(npmx)
       common/cof   / a(npmx,npmx+10), kutta
       common/cpd   / cp(npmx), xp
       common/inf1  / aan(npmx,npmx), bbn(npmx,npmx)
       common/sing  / q(npmx), gamma
       common/forces/ cl, cm
       character*10 argi
c
       pi = acos(-1.0)
c
c----  Retrieve parameters from the command line.
c
       call getarg(1,argi)
       read(argi,*) naca
       call getarg(2,argi)
       read(argi,*) nodtot
       call getarg(3,argi)
       read(argi,*) alpi
c
c----  Valid parameter check.
c
       if (( naca .gt. 25999 ).or.( naca .lt. 1 )) naca = 12
       if ( nodtot .lt. 20 ) nodtot = 20
       if ( nodtot .gt. 100 ) nodtot = 100
       if ( alpi .gt. 90.0 ) alpi = 90.0
       if ( alpi .lt. -90.0 ) alpi = -90.0
c
       nlower = nodtot / 2
       nupper = nodtot - nlower
       np1 = nodtot + 1
c
       alpi = alpi*pi/180
c
c----  Generate the airfoil coordinates.
c
       call airfoil(naca)
c
c----  Compute a steady solution at AOA = alpi.
c
       call steady(alpi)
c
c----  Write the data.
c
       call print_cp(naca,alpi)
c
       stop
       end
c------------------------------------------------------------------
       subroutine airfoil(naca)
c
c
c
c----  Compute the airfoil coordinates and panal angles.
c
       pi = acos( -1.0 )
c
c----  Decompose the NACA number to determine airfoil coefficients.
c
       ieps = naca / 1000
       iptmax = naca / 100 - 10 * ieps
       itau = naca - 1000 * ieps - 100 * iptmax
c
c----  Compute the coefficients.
c
       epsmax = ieps   * 0.01
       ptmax  = iptmax * 0.1
       tau    = itau   * 0.01
c
c----  Error correction for bogus NACA numbers.
c
       if (( naca .le. 9999 ) .and. ( epsmax .gt. 0 ) .and.
     &     ( ptmax .eq. 0 )) ptmax = .1
c
c----  If NACA 5 digit coding is used, make neccessary changes.
c
       if ( ieps .ge. 10 ) then
         if ( ieps .eq. 21 ) then
           ptmax = 0.0580
           ak1 = 361.4
         elseif ( ieps .eq. 22 ) then
           ptmax = 0.1260
           ak1 = 51.64
         elseif ( ieps .eq. 23 ) then
           ptmax = 0.2025
           ak1 = 15.957
         elseif ( ieps .eq. 24 ) then
           ptmax = 0.2900
           ak1 = 6.643
         elseif ( ieps .eq. 25 ) then
           ptmax = 0.3910
           ak1 = 3.230
         endif
         epsmax = ak1 * ptmax**3 / 6
       endif
c
c----  initialize indexing for lower surface.
c
       npoint = nlower
       nstart = 0
c
c----  Loop over lower surface.
c
       do n = 1, npoint
         z = ( 1 + cos( pi * ( n-1 ) / npoint )) / 2
         i = nstart + n
         call naca45(naca,tau,epsmax,ptmax,z,thick,camber,beta)
         x(i) = body_x(thick,beta,z,-1.0)
         y(i) = body_y(thick,camber,beta,-1.0)
       enddo
c
c----  Reinitialize indexing for upper surface
c
       npoint = nupper
       nstart = nlower
c
c----  Loop over upper surface.
c
       do n = 1, npoint
         z = ( 1 - cos( pi * ( n-1 ) / npoint )) / 2
         i = nstart + n
         x(i) = body_x(thick,beta,z,1.0)
         y(i) = body_y(thick,camber,beta,1.0)
       enddo
c
c----  Load final point.
c
       x(np1) = x(1)
       y(np1) = y(1)
c
c----  Compute slopes of panals and arc length of airfoil skin.
c
       ss = 0.0
       do i = 1, nodtot
c
c----    Control points.
c
         xm(i) = ( x(i+1) + x(i)) / 2
         ym(i) = ( y(i+1) + y(i)) / 2
c
c----    Arc length.
c
         dx = x(i+1) - x(i)
         dy = y(i+1) - y(i)
         dist = sqrt( dx**2 + dy**2 )
         ss = ss + dist
c
c----    Slope.
c
         sinthe(i) = dy / dist
         costhe(i) = dx / dist
       enddo
c
       return
       end
       function body_x(thick,beta,z,sign)
c
c----  Compute the x coordinate of an airfoil point.
c
       body_x = z - sign * thick * sin( beta )
c
       return
       end
       function body_y(thick,camber,beta,sign)
c
c----  Compute the y coordinate of an airfoil point.
c
       body_y = camber + sign * thick * cos( beta )
c
       return
       end
       subroutine cofish(alpha)
c
c
c
       pi = acos( -1.0 )
       pi2inv = 0.5 / pi
       kutta = nodtot + 1
       cosalf = cos( alpha )
       sinalf = sin( alpha )
c
c----  Initialize coefs.
c
       do 10 j = 1, kutta
         a(kutta,j) = 0.0
   10  continue
c
c----  Set vn = 0 at midpoint of ith panel.
c
       do 30 i = 1, nodtot
         a(i,kutta) = 0.0
c
c----    Find contribution of jth panel.
c
         do 20 j = 1, nodtot
           if ( j .eq. i ) then
             flog = 0.0
             ftan = pi
           else
             dxj  = xm(i) - x(j)
             dxjp = xm(i) - x(j+1)
             dyj  = ym(i) - y(j)
             dyjp = ym(i) - y(j+1)
             flog = alog( ( dxjp**2 + dyjp**2 )
     &                  / ( dxj**2 + dyj**2 )) / 2
             ftan = atan2( dyjp * dxj - dxjp * dyj,
     &                     dxjp * dxj + dyjp * dyj )
           endif
           ctimtj = costhe(i) * costhe(j) + sinthe(i) * sinthe(j)
           stimtj = sinthe(i) * costhe(j) - costhe(i) * sinthe(j)
           a(i,j) = pi2inv * ( ftan * ctimtj + flog * stimtj )
           bbn(i,j) = pi2inv * ( flog * ctimtj - ftan * stimtj )
           a(i,kutta) = a(i,kutta) + bbn(i,j)
           if (( i .eq. 1 ) .or. ( i .eq. nodtot )) then
             a(kutta,j) = a(kutta,j) - bbn(i,j)
             a(kutta,kutta) = a(kutta,kutta) + a(i,j)
           endif
c
c----      Load aan and bbn values now so that they don't have to be
c----      recomputed in infl.
c
           aan(i,j) = a(i,j)
   20    continue
c
c----    Fill in known sides.
c
         a(i,kutta+1) = sinthe(i) * cosalf - costhe(i) * sinalf
   30  continue
       a(kutta,kutta+1) = -( costhe(1) + costhe( nodtot )) * cosalf
     &                    -( sinthe(1) + sinthe( nodtot )) * sinalf
c
       return
       end
       subroutine formom(alpha)
c
c
c
       cfx = 0.0
       cfy = 0.0
       cm = 0.0
c
       do i = 1, nodtot
c
c----    Moment coefficient is computed about the elastic axis.
c
         xmid = xm(i) - xp
         ymid = ym(i)
         dx = x(i+1) - x(i)
         dy = y(i+1) - y(i)
         cfx = cfx + cp(i) * dy
         cfy = cfy - cp(i) * dx
         cm = cm + cp(i) * ( dx * xmid + dy * ymid )
       enddo
c
c----  Compute lift.
c
       cl = cfy * cosalf - cfx * sinalf
c
       return
       end
       subroutine gauss(nrhs,m,nitr)
c
c
       common/cof   / a(npmx,npmx+10), neqns
c
c----  Performs Gaussian elimination of matrix a.
c
       np = neqns + 1
       ntot = neqns + nrhs
c
       if (( m .le. 1 ) .and. ( nitr .eq. 0 )) then
c
c----    Do full matrix elimination sequence.
c
         do 10 i = 2, neqns
           im = i - 1
c
c----      Eliminate the (i-1)th unknown from i-th through
c----      neqns-th equations.
c
           do 10 j = i, neqns
             r = a(j,im) / a(im,im)
             do 10 k = i, ntot
               a(j,k) = a(j,k) - r * a(im,k)
   10    continue
       else
c
c----    Elimination on RHS only.
c
         do 20 i = 2, neqns
           im = i - 1
           do 20 j = i, neqns
             do 20 k = np, ntot
   20    continue
       endif
c
c----  Back subtitution.
c
       do 40 k = np, ntot
         a(neqns,k) = a(neqns,k) / a(neqns,neqns)
         do 40 l = 2, neqns
           i = neqns + 1 - l
           do 30 j = i+1, neqns
             a(i,k) = a(i,k) - a(i,j) * a(j,k)
   30      continue
           a(i,k) = a(i,k) / a(i,i)
   40  continue
c
       return
       end
       subroutine naca45(naca,tau,epsmax,ptmax,z,thick,camber,beta)
c
c----  Compute the thickness, camber, and angular location of an
c----  airfoil point.
c
c----  Thickness, corrected when z is very small.
c
       if ( z .lt. 1.0e-10 ) then
         thick = 0.0
       else
         thick = tau * 5 * ( 0.2969 * SQRT(Z)
     &               - Z * ( 0.1260
     &               + Z * ( 0.3537
     &               - Z * ( 0.2843
     &               - Z * 0.1015))))
       endif
c
       if ( epsmax .eq. 0.0 ) then
c
c----    For NACA 4-digit symmetrical arfoils.
c
         camber = 0.0
         beta = 0.0
       else
         if ( naca .gt. 9999 ) then
c
c----      For NACA 5 digit numbers.
c
c----      Ptmax = m and epsmax = (k_1*m^3)/6 from Abbott and Doenhoff.
c
           if ( z .gt. ptmax ) then
             camber = epsmax * ( 1.0 - z )
             dcamdx = - epsmax
           else
             w = z / ptmax
             camber = epsmax * ( w**3 - 3*w**2 +(3.-ptmax)*w)
             dcamdx = epsmax/ptmax*(3*w**2 - 6*w + ( 3.0-ptmax))
           endif
         else
c
c----      For NACA 4 digit airfoils.
c
             camber = epsmax / ( 1.0 - ptmax )**2
     &              * ( 1. + z - ptmax * 2 ) * ( 1. - z )
             dcamdx = epsmax * 2 / ( 1.0 - ptmax )**2
     &              * ( ptmax - z )
           else
             camber = epsmax / ptmax**2 * ( ptmax*2 - z ) * z
             dcamdx = epsmax * 2 / ptmax**2  * ( ptmax - z )
           endif
         endif
c
         beta = atan( dcamdx )
       endif
c
       return
       end
       subroutine print_cp(naca,alpi)
c
c
c
c----  Write out data.
c
       open(8,file='cp.fmt',form='formatted',status='unknown')
       do n=1,nodtot
         write(8,*) xm(n), ym(n), cp(n)
       enddo
       close(8)
c
       return
       end
       subroutine steady(alpha)
c
c----  alpha is angle of attack in radians, positive clockwise.
c
       call cofish(alpha)
       call gauss(1,0,0)
       call veldis(alpha)
       call formom(alpha)
c
       return
       end
       subroutine veldis(alpha)
c
c
c
c
c----  Retrieve solution from a matrix.
c
       sum = 0.0
       do i = 1, nodtot
         q(i) = a(i,kutta+1)
         ds = sqrt((x(i+1)-x(i))**2 + (y(i+1)-y(i))**2)
       enddo
       gamma = a(kutta,kutta+1)
c
c----  Find vt and cp at mid-point of i-th panel.
c
       do i = 1, nodtot
         vtfree = cosalf * costhe(i) + sinalf * sinthe(i)
         vtang = vtfree
c
c----    Add contribution of j-th panel.
c
         do j = 1, nodtot
           vtang = vtang - bbn(i,j) * q(j) + gamma * aan(i,j)
         enddo
         cp(i) = 1.0 - vtang**2
       enddo
c
       return
       end
发表于 2003-4-23 21:24:45 | 显示全部楼层
谁有面元法的求解程序?
谢谢斑主!!其实势流理论计算升力还是比较准的.
外加边界层修正可以满足工程要求.
 楼主| 发表于 2003-4-24 17:27:20 | 显示全部楼层
谁有面元法的求解程序?
谢谢斑竹的帮助,我要好好研究一下了。
发表于 2003-4-24 18:47:04 | 显示全部楼层
谁有面元法的求解程序?
好象是二维的,有三维的吗?
发表于 2003-5-1 12:31:58 | 显示全部楼层
谁有面元法的求解程序?
二维组合--形成三维---目前不是很难
发表于 2003-5-3 13:20:02 | 显示全部楼层
谁有面元法的求解程序?
恩情哦 惹眼洋可以就  如同就哟哦呕吐经验棵了解麻烦古兰经
