查看: 2271|回复: 1
AUSMDV
发表于 2003-6-7 07:05:34 | 显示全部楼层 |阅读模式
有谁采用AUSMDV格式计算格式,需要仔细探讨格式本质!请各位高手发表高见
发表于 2003-6-7 13:07:47 | 显示全部楼层
AUSMDV
This method can solve some special cases (for example, very small density
at some locations, disformed shock in hypersonic flow). However, it is hard to
implement it. It is slow. You will take more time to make it run if you want to
have a implicit solver. The Roe's scheme is much more popular.
