查看: 3327|回复: 2
【建议】能否提供一些源代码分析说明?
发表于 2002-7-8 21:00:27 | 显示全部楼层 |阅读模式
虽然CFD的教材不算很少,但是书中的方法用代码实现的时候会遇到许多问题。
建议大家能否把以前阅读过的源代码(不涉及版权问题)或者自己作过的练习程序的说明共享出来?
发表于 2002-7-21 15:12:57 | 显示全部楼层
【建议】能否提供一些源代码分析说明?
include 'TriCross.f90'  !TriCross是求解三对角方程的子程序
program main
implicit none
real:: L,NJ,TIME,DT,Y,UEDGE,UINITIAL
real,dimension(1:200,0:1000)::u
real,allocatable,dimension(:,:: a
real,allocatable,dimension(::b,U1D
real,dimension(0:1000)::x,tm
integer i,j,n,jmax,nmax
real dx,r
open(1,file = 'control.txt',status = 'old')
read(1,*)
read(1,*) L
read(1,*)
read(1,*) NJ
read(1,*)
read(1,*) TIME
read(1,*)
read(1,*) DT
read(1,*)
read(1,*) Y
read(1,*)
read(1,*) UEDGE
read(1,*)
read(1,*) UINITIAL
close(1)
nmax = int(TIME/DT)
dx = L/(NJ-1)! Length
jmax = NJ
do j = 1, jmax
X(j) = dx * (j-1)
end do
do n = 0,nmax
Tm(n) = DT * n
end do
do j = 1, jmax
U(j,0) = UInitial
end do
do n = 0, nmax
U(1,n)= UEdge
U(jmax,n)= UEdge
end do
r = Y*DT/dx**2
!--------------- 三对角方程求解 ------------
allocate(a(jmax-2,jmax-2))
a = 0.0
do j = 2, jmax-3
a(j,j)   = -2*(r+1)
a(j,j-1) = r
a(j,j+1) = r
end do
a(1,1) = -2*(r+1)
a(1,2) = r
a(jmax-2,jmax-2) = -2*(r+1)
a(jmax-2,jmax-3) = r
allocate(b(jmax-2))
b = 0.0
allocate(U1D(jmax-2))
U1D = 0.0
do n = 0, nmax-1
do j = 1,jmax-2
b(j) = -r*U(j+2,n)+2*(r-1)*U(j+1,n)-r*U(j,n)
end do
b(1)      = b(1) - r*U(1,n+1)
b(jmax-2) = b(jmax-2) - r*U(jmax,n+1)
CALL TriCross(a,b,U1D,jmax-2)
do j = 1, jmax-2
U(j+1,n+1) = U1D(j)
end do
continue
end do
open(1,file = 'Simple.tec')
write(1,*)" variables = x,t,u"
write(1,*) " zone i = "
write(1,*) jmax
write(1,*) " j = "
write(1,*) nmax+1
do i = 0, nmax
do j = 1, jmax
write(1,*) tm(i), X(j), U(j,i)
end do
end do
close(1)
end program main
发表于 2002-7-21 15:25:21 | 显示全部楼层
【建议】能否提供一些源代码分析说明?
以上是一维非稳态导热的例子,初始温度为100,边界保持200不变
差分格式是 Crank-Nicoloson 隐式
L = 总长度
1.0
NJ =
10
Time = 总时间
DT = 时间步长
0.005
Y = 热传导系数
1.0
UEdge =
200.0
UInitial =
100.0
以上程序在X方向加密后(NJ=100),出现了不正常的解(边界附近温度升高)
请帮我看看,谢谢  :)
