查看: 2744|回复: 3
[求助]离心力引起的二次留问题
发表于 2004-12-30 11:20:41 | 显示全部楼层 |阅读模式
在一般的资料文献中,一般认为弯管处外侧压力大,内侧压力小,相应的也就是外侧速度小,内侧速度大。但是在下面情况下,纯粹的环型管道,刚好相反,U型管道只有在直管与圆弧过渡处是这样,90度管道也是如此,不知道应该如何解释。
 楼主| 发表于 2004-12-30 11:23:37 | 显示全部楼层
[求助]离心力引起的二次留问题
环型管道
 楼主| 发表于 2004-12-30 11:24:26 | 显示全部楼层
[求助]离心力引起的二次留问题
U型管道
发表于 2004-12-30 22:28:17 | 显示全部楼层
[求助]离心力引起的二次留问题
To 午夜流星:
1. U型管道
You may explain the velocity distribution based on the vorticity conservation (zeta = constant):
zeta = @V/@R + V/R
where R is the radius that may vary along flow. The first term is called shear vorticity and the second term is called curvature vorticity.  Before entering the U-section, vorticity is zero (zeta=0). To maintain a zero vorticity at the U-section where V/R>0, the velocity distribution needs to be @V/@R<0, that is, the velocity decreases with the radius.
2. 环型管道
You may explain the velocity distribution based on the balance between the pressure gradient (force) and the centrifugal acceleration. ........
