查看: 4052|回复: 2
[求助]K-E湍流模型中涡粘性系数Vt的取值范围?
发表于 2005-4-26 10:53:04 | 显示全部楼层 |阅读模式
目前正在算一个射流问题,采用K-E湍流模型。
有个疑问:按照定义,涡粘性系数Vt=Cu*K*K/E,那么Vt应该是K和E函数,其取值随K和E值变化。
但是流体的涡粘性不可能无限大,究竟Vt的值域是多少呢?
谢谢!
发表于 2005-4-26 13:10:12 | 显示全部楼层
按照定义,涡粘性系数涡粘性系数Vt
         ~~~~~~~~~~~~~~~~~~~~~~~ This is just some assumption, not the definition of turbulent visocity.
其取值随K和E值变化 ~~Also this is assumed in turbulent viscosity models.
Actually turbulence models based on 涡粘性系数Vt are to give specific description of 涡粘性系数Vt.
For k-eps, just Cu*K*K/E.
For k-omega, another experssion.
 楼主| 发表于 2005-4-26 16:48:30 | 显示全部楼层
turbulencest,thank you for your answer.
as you said, in k-eps model,let Vt=Cu*K*K/E, then could you tell me the range of it?
that is an important question for me to calculate k and eps, you know, if I get a wrong Vt, the k and eps should not be true.
or,
I can get some important information from Vt to know whether my results are wrong or true.
