查看: 3447|回复: 4
[求助]SIV(scalar image vvelocimetry)怎么翻译呀
发表于 2006-6-27 16:42:06 | 显示全部楼层 |阅读模式
呵呵,不知道怎么翻译这个方法。。。。google也没有找到。。。
发表于 2006-6-27 20:41:29 | 显示全部楼层
没有听说过,我在SCI上搜索了一下,只找到一篇文章。
http://elsevier.lib.tsinghua.edu.cn/cgi-bin/sciserv.pl?collection=journals&journal=09277757&issue=v222i1-3&article=273_evpim
Colloids and Surfaces A: Physicochemical and Engineering Aspects
Vol: 222, Issue: 1-3, July 30, 2003  Bibliographic Page
Article Full Text PDF (546 KB)
Get citation export (Reference format)
pp. 273 - 283
   Title:  Electroosmotic velocity profiles in microchannels
Authors:  Sinton, Davida; Li, Dongqinga
Affiliations:  a. Department of Mechanical and Industrial Engineering, University of Toronto, 5 King';s College Road, Toronto, Ont., Canada M5S 3G8
Keywords:  Electroosmotic flow; Microchannel; Pressure; Joule heating; Velocimetry
Abstract (English):  Electroosmotic flows in microchannels of circular and square cross-sections with a range of hydraulic diameters are investigated experimentally. Velocity profiles at the mid-planes of the channels are obtained using a caged-dye based technique with a high degree of resolution in the bulk and near the channel walls. At low electric fields, plug-like velocity profiles are obtained, in agreement with electrokinetic theory. However, high electric fields in channels of larger hydraulic diameter were found to result in concave velocity profiles. The presence of this velocity deficit is shown to correlate with both an increase in pressure sensitivity, and an increase in fluid temperature due to Joule heating. To obtain accurate dye-based velocimetry data in such cases, a new scalar image velocimetry method is presented and verified with concurrent current-based measurements. The velocimetry method compensates for the temperature dependence of the dye mobility without explicit knowledge of the fluid temperature.
Publisher:  Elsevier Science
Language of Publication:  English
Item Identifiers:  10.1016/S0927-7757(03)00233-4 S0927-7757(03)00233-4
Publication Type:  Article
ISSN:  0927-7757
发表于 2006-7-5 20:37:17 | 显示全部楼层
标量图像测速,以前听说过
 楼主| 发表于 2006-7-14 00:53:38 | 显示全部楼层
恩,以前没有听说过.不过其中有一种方法叫MTV可以同时测量温度场和速度场.是一个很好的发展方向.....
发表于 2006-7-14 10:05:43 | 显示全部楼层
MTV用的是荧光分子作为失踪粒子,可以消除粒子对PIV测量精度的影响,用于微/小尺度的测量前景很可观
