查看: 6471|回复: 16
求助:NASA-VOF3D
发表于 2004-11-8 21:43:46 | 显示全部楼层 |阅读模式
那位高手知道NASA-VOF3D的源程序是用来模拟什莫问题的,可否指点一下?先谢过了!
 楼主| 发表于 2004-11-10 20:34:23 | 显示全部楼层
求助:NASA-VOF3D
有没有读过这个程序的,可否交流一下啊?我的qq是280310764
发表于 2004-11-11 00:00:19 | 显示全部楼层
求助:NASA-VOF3D
3维不可压带自由面. 好想只能用于柱坐标.
1. NAME OR DESIGNATION OF PROGRAM - NASA-VOF3D.
2. COMPUTER FOR WHICH PROGRAM IS DESIGNED AND OTHER MACHINE VERSION PACKAGES AVAILABLE -
To request or retrieve programs click on the one of the active versions below. A password and special authorization is required.
Explanation of the status codes.
Program-name         Package-ID  Status
NASA-VOF3D           NESC9568/01 Tested
Machines used:
Package-ID     Orig.Computer                       Test Computer
NESC9568/01    CRAY 1                              DEC VAX 8810
3. DESCRIPTION OF PROGRAM OR FUNCTION - NASA-VOF3D is a three- dimensional, transient, free surface, incompressible fluid dynamics program. It is specifically designed to calculate confined flows in a low gravity environment in which surface physics must be accurately treated. It allows multiple free surfaces with surface tension and wall adhesion and includes a partial cell treatment that allows curved boundaries and internal obstacles. Variable mesh spacing is permitted in all three coordinate directions. Boundary conditions available are rigid free-slip wall, rigid no-slip, wall, continuative, periodic, and specified pressure outflow boundary.
4. METHOD OF SOLUTION - NASA-VOF3D simulates incompressible flows with free surfaces using the volume-of-fluid (VOF) algorithm. This technique is based on the use of donor-acceptor differencing to track the free surface across an Eulerian grid. The free surfaces are treated by introducing a function defined to be unity at any point occupied by the fluid and zero elsewhere. The complete Navier- Stokes equations for an incompressible fluid are solved by finite differences with surface tension effects included. Wall adhesion may be included or neglected as a user option. The pressures (and velocities) are advanced in time throughout the computing mesh by either a conjugate residual method or the successive overrelaxation (SOR) method. The conjugate residual method is vectorized for the Cray and uses a scaled coefficient matrix.
5. RESTRICTIONS ON THE COMPLEXITY OF THE PROBLEM - NASA-VOF3D is restricted to cylindrical coordinate representation of the geometry. A three-dimensional wall-adhesion procedure is available only for straight-walled containers.
6. TYPICAL RUNNING TIME -
7. UNUSUAL FEATURES OF THE PROGRAM - NASA-VOF3D is highly structured so that individual components may be easily modified to fit specific problem requirements or to accept subsequent code upgrades.
8. RELATED AND AUXILIARY PROGRAMS - NASA-VOF3D is a three-dimensional successor to NASA-VOF2D (NESC 9644); however, its origin and architecture are most directly related to SOLA-3D.
9. STATUS
NESC9568/01: 12-FEB-1992 Tested at NEADB
10. REFERENCES  -
- Martin D. Torrey et al:
NASA-VOF2D - A Computer Program for Incompressible Flows with Free Surfaces
  LA-10612-MS (December 1985).
- B. Nichols, C.W. Hirt, and R.S. Hotchkiss:
  SOLA-VOF - A Solution Algorithm for Transient Fluid Flow with
  Multiple Free Boundaries
  LA-8355 (August 1980).
NESC9568/01:
- Martin D. Torrey, Raymond C. Mjolsness, Leland R. Stein:
  NASA-VOF3D - A Three-Dimensional Computer Porgram for
  LA-11009-MS UC-32 (issued July 1987).
- M. Birgersson:
  NASA-VOF3D Tape Description and Implementation Information
  NESC Note 88-25 (December 7, 1987).
11. MACHINE REQUIREMENTS - 4 units in addition to the standard input/output units.
12. PROGRAMMING LANGUAGE(S) USED -
NESC9568/01: FORTRAN
13. OPERATING SYSTEM UNDER WHICH PROGRAM IS EXECUTED -
14. OTHER PROGRAMMING OR OPERATING INFORMATION OR RESTRICTIONS -
NASA-VOF3D contains calls to several environment-dependent routines, including graphics systems. These routines are not included, and users must substitute the appropriate routines for their computing environment. While many problems can be run using NASA-VOF3D without code modification, specific applications may require logic changes which can be accomplished by using the UPDATE utility.
15. NAME AND ESTABLISHMENT OF AUTHORS -
          M.D. Torrey
          Los Alamos National Laboratory
16. MATERIAL AVAILABLE -
NESC9568/01:
NESC9568_01.001 This information file 51 records
NESC9568_01.002 JCL and control information 5 records
NESC9568_01.003 NASA-VOF3D UPDATE format source 7647 records
NESC9568_01.004 NASA-VOF3D source updates for sample problem 61 records
NESC9568_01.005 NASA-VOF3D FORTRAN source (VAX version) 12251 records
NESC9568_01.006 NASA-VOF3D dummy graphics routines 92 records
NESC9568_01.007 NASA-VOF3D auxiliary SLATEC routines 317 records
NESC9568_01.008 Sample problem input 32 records
NESC9568_01.009 Sample problem output 4667 records
17. CATEGORIES  -
- H.  Heat Transfer and Fluid Flow
Keywords: Navier-Stokes equation, finite difference method, fluid flow, incompressible flow, three-dimensional
 楼主| 发表于 2004-11-11 09:01:22 | 显示全部楼层
求助:NASA-VOF3D
请问anyone有没有读过这个程序阿?谁读过阿?
发表于 2004-11-11 11:13:01 | 显示全部楼层
求助:NASA-VOF3D
抱歉, 没用过.
发表于 2004-11-14 16:11:31 | 显示全部楼层
求助:NASA-VOF3D
NASA-VOF3D是用于计算三维带自由面运动的不可压缩流动,好像没有考虑表面张力的影响。
发表于 2004-11-18 20:13:52 | 显示全部楼层
求助:NASA-VOF3D
哪里能得到这个程序?
发表于 2004-11-29 09:40:45 | 显示全部楼层
求助:NASA-VOF3D
有,但是不清楚,我的2d也是不清楚,我想交流一下边界条件问题,请指教一下我的qq125856697
发表于 2004-11-29 17:45:46 | 显示全部楼层
求助:NASA-VOF3D
源程序要找NASA的报告,附件就是源代码,不过是老式fortran
什么边界条件?可以探讨
 楼主| 发表于 2004-12-1 20:12:34 | 显示全部楼层
求助:NASA-VOF3D
有调试过这个程序的吗?请回复好吗?
 楼主| 发表于 2004-12-1 20:15:09 | 显示全部楼层
求助:NASA-VOF3D
二维的有没有调试过的?急盼回复!
发表于 2004-12-8 22:56:26 | 显示全部楼层
求助:NASA-VOF3D
三维,二维的我都使用过,有什么问题
 楼主| 发表于 2004-12-10 21:18:36 | 显示全部楼层
求助:NASA-VOF3D
谢谢hongfw2的回复,不知道可否加一下我的qq:280310764,这样方便向您请教!非常感谢,期待您的帮助!
 楼主| 发表于 2004-12-13 21:05:25 | 显示全部楼层
求助:NASA-VOF3D
我的问题是在调用子程序EQUIB时,不能正确执行,不知你当初调试程序的时候,是否对这一部分做过改动(与报告中相比),能不能把您的EQUIB子程序发给我呢?我的邮箱是jyyang_2002@yahoo.com.cn,非常感谢!急盼回复!
发表于 2004-12-24 21:12:24 | 显示全部楼层
求助:NASA-VOF3D
可否用来计算 水膜流动问题? 其中的边界条件一段能否给我讲解一下,急用qq125856697
