查看: 26991|回复: 53
[原创]DUNS使用手册(2005.3.10日更新)
发表于 2004-11-24 09:26:07 | 显示全部楼层 |阅读模式
[这个贴子最后由wangdingxi在 2005/03/10 04:44pm 第 7 次编辑]
the manual was update on 10 March 2005[DISABLELBCODE]
 楼主| 发表于 2004-11-24 10:01:58 | 显示全部楼层
[这个贴子最后由wangdingxi在 2005/09/06 05:24pm 第 4 次编辑]
you are strongly recommended to download this version of duns to follow the manual provided above
 楼主| 发表于 2004-11-24 10:08:44 | 显示全部楼层
[这个贴子最后由wangdingxi在 2005/03/03 10:25am 第 5 次编辑]
这是一个网格格式转化小程序,能够将CFD-GEOM输出的网格数据(formatted with iblank or without iblank)转化为formatted 格式的duns网格数据。
 楼主| 发表于 2004-11-24 10:11:47 | 显示全部楼层
If you want to run those test examples,you can download them wherever you can find them only if they are kept intact as the original ones.The size of those examples are too big to post here.
 楼主| 发表于 2004-11-24 10:17:45 | 显示全部楼层
[这个贴子最后由wangdingxi在 2004/11/24 10:19am 第 1 次编辑]
Just after I posted the above message,I asked myself:why not post those examples separately?In addition,I want to tell you that actually it is your own business instead of my duty to find them. Now since they are available here and I have a good mood to do those tedious things,I do it.
this is the first part of the test cases
Notice: I am not sure of the validation of all these test cases
but I tested all of them, but most of them are good,and some behave abnormal
 楼主| 发表于 2004-11-24 10:18:59 | 显示全部楼层
here is the second part
good luck
if you have some questions or suggestions,you are strongly recommended to post them here instead of writing to me.
发表于 2004-11-24 11:46:09 | 显示全部楼层
虽然我不用,但看了文档,觉得非常不错,收下并道谢
发表于 2004-11-24 18:13:47 | 显示全部楼层
谢谢王哥!!!请大家多多讨论,能够把开源软件用到这个程度真的需要一定的耐力和精神。
欢迎大家来讨论。
王哥有什么新的体会可以一直发到这个帖子,只要我还是斑竹,这个帖子就一直固顶,期待王哥的精彩文章。
 楼主| 发表于 2004-11-24 20:18:37 | 显示全部楼层
this article was ever posted here,for the sake of integraty and convenience for other users,I posted it again.It deals with the meaning of each constant in the file parameters
 楼主| 发表于 2004-11-24 20:20:49 | 显示全部楼层
here is the other article ever posted here, for the same reason as the above,I posted it again.It illustrates things regarding solution blocks or sweep blocks
 楼主| 发表于 2004-11-24 20:27:01 | 显示全部楼层
[这个贴子最后由wangdingxi在 2004/11/24 08:28pm 第 1 次编辑]
下面引用由赵玉心在 2004/11/24 06:13pm 发表的内容:
欢迎大家来讨论。
Thanks for your appreciation,I will try my best to show what I know about DUNS,I hope what I did will give a push for those using DUNS and eliminate unnecessarcy duplicated efforts to decipher the source codes which perhaps is the best profit I want to gain.
发表于 2004-12-28 13:31:00 | 显示全部楼层
好不容易编译没有问题了
结果运行test的例子时
一个都没法运行啊
哈哈
 楼主| 发表于 2005-1-19 11:24:35 | 显示全部楼层
请把具体问题贴出来,我给你诊断一下
发表于 2005-1-21 02:10:54 | 显示全部楼层
先回家过年了,回来了再和各位灌水,呵呵!
家在兰州啊,远着呢...............
发表于 2005-1-24 10:57:30 | 显示全部楼层
非常感谢,正想看看这方面的东西,在这里学了很多
