查看: 1629|回复: 1
linux or unix command: crontab
发表于 2004-3-24 00:08:13 | 显示全部楼层 |阅读模式
using this command you can make a copy of your development directory
at time you define everyday. If you use CVS to store your files,
that is OK. Do not forget to check in often. This command can
help you copy a dir which has not been in CVS to another dir.
As you know, you can accidently delete all files you write
in dir.
发表于 2004-3-24 06:10:15 | 显示全部楼层
??? more details? plz
what is CVS?
