查看: 1888|回复: 0
求助,哪位大大能帮我看看这段程序?并解释下,谢谢了
发表于 2004-4-15 10:44:46 | 显示全部楼层 |阅读模式
function varargout = cry_sim(varargin)
% CRY_SIM Application M-file for cry_sim.fig
%    FIG = CRY_SIM launch cry_sim GUI.
%    CRY_SIM('callback_name', ...) invoke the named callback.
% Last Modified by GUIDE v2.0 11-Jul-2003 17:34:08
if nargin == 0  % LAUNCH GUI
fig = openfig(mfilename,'reuse');
% Generate a structure of handles to pass to callbacks, and store it.
handles = guihandles(fig);
guidata(fig, handles);
if nargout > 0
varargout{1} = fig;
end
elseif ischar(varargin{1}) % INVOKE NAMED SUBFUNCTION OR CALLBACK
try
if (nargout)
[varargout{1:nargout}] = feval(varargin{:}); % FEVAL switchyard
else
end
catch
disp(lasterr);
end
end
function varargout = listbox1_Callback(h, eventdata, handles, varargin)
global  lselect                                 %lselect is used for a symbol of distribution function
listnum1=get(handles.listbox1,'value'); %list{index_selected}
switch listnum1
case 1%'Normal Distribution'
    lselect=1;
    set([handles.text28,handles.edit3,],'visible','on');
case 4%'Log Normal Distribution'
    lselect=4;
case 7%'Gamma Distribution'
    lselect=7;
case 10%'Uniform Distribution'
    lselect=10;
case 13%'Exponenetial Distribution'
    lselect=13;
    set([handles.text28,handles.edit3,],'visible','off');
case 2%'Normal Distribution'
    lselect=1;
case 5%'Log Normal Distribution'
   lselect=4;
case 8%'Gamma Distribution'
    lselect=7;
case 11%'Uniform Distribution'
    lselect=10;
case 14%'Exponenetial Distribution'
    lselect=13;
end
function varargout = listbox4_Callback(h, eventdata, handles, varargin)
global gselect                    % gselect is used for a symbol of distribution function
listnum4=get(handles.listbox4,'value');    %list{index_selected}
switch listnum4
    gselect=1;
    set([handles.text26,handles.edit10,],'visible','on');
   gselect=4;
    gselect=7;
    gselect10;
    gselect=13;
    set([handles.text26,handles.edit10,],'visible','off');
    gselect=1;
    gselect=4;
    gselect=7;
    gselect=10;
    gselect=13;
end
function varargout = edit1_Callback(h, eventdata, handles, varargin)
function varargout = edit2_Callback(h, eventdata, handles, varargin)
function varargout = edit3_Callback(h, eventdata, handles, varargin)
function varargout = edit8_Callback(h, eventdata, handles, varargin)
function varargout = edit9_Callback(h, eventdata, handles, varargin)
function varargout = edit10_Callback(h, eventdata, handles, varargin)
function varargout = pushbutton1_Callback(h, eventdata, handles, varargin)
function varargout = pushbutton2_Callback(h, eventdata, handles, varargin)
function varargout = edit11_Callback(h, eventdata, handles, varargin)
function varargout = pushbutton3_Callback(h, eventdata, handles, varargin)
function varargout = pushbutton4_Callback(h, eventdata, handles, varargin)
global  l_mu l_d l_a l_b g_mu g_d g_a g_b  cn  g_mean lselect gselect mdl l crystallization_time gmu
l_mu=str2Num(get(handles.edit2,'string'));                 % get different parameters for size distribution
l_cv=str2Num(get(handles.edit3,'string'));
g_d=str2Num(get(handles.edit10,'string'));                % get different parameters for growth rate distribution
g_mean=str2Num(get(handles.edit11,'string'));             % get crystallization parameters such as growth rate and crystallization time
crystallization_time=str2Num(get(handles.edit19,'string'));
l=linspace(0,2500,251);                                  % divide size aix into 250 peaces
switch gselect                                           % create a grwoth rate distribution function
    case 1
        g=linspace(0,15*g_d,51);                                     % divide growth rate aix into 50 peaces according different g_d
        fg=normpdf(g,1,g_d);
    case 4
        g_d=sqrt(log(1+g_d^2));
        g_mu=-g_d^2/2;
        fg=lognpdf(g,g_mu,g_d);
    case 7
        g_a=1/g_d^2;
        g_b=g_d^2;
        g=linspace(0,10*g_d,51);                                     % divide growth rate aix into 50 peaces  according different g_d
        fg=gampdf(g,g_a,g_b);
    case 10
        g=linspace(0,3,31);                                        % divide growth rate aix into 30 peaces
        g_a=1-sqrt(3)*g_d;
        g_b=g_a+sqrt(12)*g_d;
        fg=unifpdf(g,g_a,g_b);
    case 13
        g=linspace(0,10,51);                                     % divide growth rate aix into 50 peaces
        fg=exppdf(g,1);
    end
    switch lselect                          % create a size distribution function
    case 1
        fl=normpdf(l,l_mu,l_cv*l_mu);
    case 4
        l_d=sqrt(log(1+l_cv^2));
        l_mu=log(l_mu)-0.5*l_d^2;
        fl=lognpdf(l,l_mu,l_d);
    case 7
        l_d=l_cv*l_mu;
        l_b=l_d^2/l_mu;
        l_a=l_mu/l_b;
        fl=gampdf(l,l_a,l_b);
    case 10
        l_d=l_cv*l_mu;
        l_a=l_mu-sqrt(3)*l_d;
        l_b=l_a+sqrt(12)*l_d;
        fl=unifpdf(l,l_a,l_b);
    case 13
        fl=exppdf(l,l_mu);
    end
dt=5;                                       % create time interval (/minute)
Crystal_Number=9.3667e+10;                        % set crystal number
g_length=length(g);                         % get the lenth of g
dg=g(2)-g(1);
l_length=length(l);                         % get the lenth of l
dl=l(2)-l(1);                              % calculate the lenth of size interval
flg=fg'*fl;                                 % create  joint distribution of growth rate and crystal size
for i=1:g_length                            % creat crys_number which is a matrix which element is the crystal number in cell (ij)
    for j=1:l_length
        crys_number(i,j)=Crystal_Number*flg(i,j)*dg*dl;
    end
end
h1=figure(1);                        %output figures
subplot(2,2,1);
plot(l,fl);
h2=figure(2);
subplot(2,2,1);
contour(l,g,flg);
h3=figure(3);                        % xlabel is the crystal size distribution, ylabel is the crystal growth rate distribution
subplot(2,2,1);
mesh(l,g,flg);
total_step=linspace(0,0,g_length);         %set initial value of growth steps
delta_l=linspace(0,0,g_length);
g_growth=g_mean*g;
for t=dt:dt:crystallization_time                     % loop begin
    for i=1:g_length
     delta_l(i)=delta_l(i)+g_growth(i)*dt;                        %calculate the ith level crystal growth;
     step(i)=fix(delta_l(i)/dl);
     total_step(i)=total_step(i)+step(i);
          if step(i)>0                          %Begin to recalculate crys_number
            for j=l_length:-1:l_length-step(i)  % move the crystals of cell(i,l_length-step(i)) to cell(i,l_length-1) to cell(i,l_length)
                crys_number(i,l_length)=crys_number(i,l_length)+crys_number(i,j);
            end
            for j=l_length-step(i):-1:step(i)+1         % move the crystals of cell(i,l_length-step(i)-1) to cell(i,l_length-step(i)) and so on.
                crys_number(i,j)=crys_number(i,j-step(i));
            end
            for j=total_step(i):-1:1            % cleanup the crystals of cell(i,1) to cell(i,total_step(i))
                crys_number(i,j)=0;
            end
        delta_l(i)=delta_l(i)-step(i)*dl;
        end
      end
nl=linspace(0,0,l_length);                 % recalculate the crystal number in one size interval
     for j=1:l_length
        for i=1:g_length
            nl(j)=nl(j)+crys_number(i,j);
        end
     end
     for j=1:l_length                            % recalculate the size distribution function
        fl(j)=nl(j)/(Crystal_Number*dl);
     end
for i=1:g_length                             % recalculate joint distribution of growth rate and crystal size
    for j=1:l_length
        flg(i,j)=crys_number(i,j)/(Crystal_Number*dg*dl);
    end
end
                                   % recalculate crystal mass X in weight
crys_mu_3=0;
     for j=1:l_length
         crys_mu_3=crys_mu_3+fl(j)*l(j)^3*dl;
     end
     X3(t/dt)=pi*1.585*Crystal_Number*crys_mu_3*1e-15/6;
      if ((t-crystallization_time/2)<=2.5)
        h1=figure(1);                       % xlabel is the crystal size range, and ylabel is the crystal size distribution
        subplot(2,2,2);
        plot(l,fl);
        h2=figure(2);
        subplot(2,2,2);
        contour(l,g,flg);
        subplot(2,2,2);
        mesh(l,g,flg);
    end
    if (t==crystallization_time)
        subplot(2,2,3);
        plot(l,fl);
        h2=figure(2);                        % xlabel is the crystal size range, and ylabel is the crystal number is each interval
        subplot(2,2,3);
        contour(l,g,flg);
        subplot(2,2,3);
        mesh(l,g,flg);
    end
    %h5=figure(5);
    %plot(time,crys_content_value);
    xlabel('crystal size')
    ylabel('growth rate')
end
    h4=figure(4);
    plot(X3);
    xlabel('time--minute')
    ylabel('Crystal Mass (kg)')
function varargout = pushbutton5_Callback(h, eventdata, handles, varargin)
function varargout = edit14_Callback(h, eventdata, handles, varargin)
function varargout = edit15_Callback(h, eventdata, handles, varargin)
function varargout = edit16_Callback(h, eventdata, handles, varargin)
function varargout = edit17_Callback(h, eventdata, handles, varargin)
function varargout = edit18_Callback(h, eventdata, handles, varargin)
% --- Executes during object creation, after setting all properties.
function edit19_CreateFcn(hObject, eventdata, handles)
% hObject    handle to edit19 (see GCBO)
% eventdata  reserved - to be defined in a future version of MATLAB
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc
    set(hObject,'BackgroundColor','white');
else
    set(hObject,'BackgroundColor',get(0,'defaultUicontrolBackgroundColor'));
end
function edit19_Callback(hObject, eventdata, handles)
% handles    structure with handles and user data (see GUIDATA)
% Hints: get(hObject,'String') returns contents of edit19 as text
%        str2double(get(hObject,'String')) returns contents of edit19 as a double
function varargout = edit21_Callback(h, eventdata, handles, varargin)
function varargout = Untitled_1_Callback(h, eventdata, handles, varargin)
function varargout = edit23_Callback(h, eventdata, handles, varargin)
