查看: 1549|回复: 0
单步仿真问题
发表于 2004-6-12 10:59:11 | 显示全部楼层 |阅读模式
请教高手!Simulink 问题!!
建立一个模型,然后一步一步仿真,我想要每输入一个(或一组)数据,然后从模型中得到一个(或者是和输入同维的)输出。而且输出要和所有数据一齐输入时得出的结果一致。请教高手。是不是用下面的函数,怎么用?帮助说的很让人迷惑。
[sys,x0,str,ts] = model(t,x,u,flag);
This command is intended to allow linear analysis and other M-file program-based tools to run a simulation step by step, gathering information about the model's states and outputs at each step. It is not intended for interactive use, for example, to debug a model.
Use this command if you want to write an M-file program that needs to examine intermediate results of a simulation. Use the sim command if the program does not need to examine intermediate results. Use the Simulink debugger if you need to examine intermediate results to debug a model.
我的电邮:ttroyce@21cn.com
