查看: 4498|回复: 13
[原创]流线计算
发表于 2003-9-30 13:37:03 | 显示全部楼层 |阅读模式
请多指教!
该程序根据网格点和速度矢量来刻画流场,最后输出的画图文件用Tecplot打开。
!* FileName   : StreamLine.f90
!* Written by : Dr.Tinghe Lee
!* Purpose    : Calculate position of stream lines
!* Originally complete date : 08/07/2002
!* Usage      :
!* History    : complete - 2002.8.7 - Dr.Tinghe Lee
! Common data are saved in module for convenience
module mdlsm
implicit none
end module mdlsm
program main
use mdlsm
implicit none
integer im,jm,me,ms,i,j
real dt,ei0,ej0
real,dimension(,allocatable:: ex,ey,ez,es
real,dimension(:,,allocatable:: x,y,z,u,v,w
me = 1000
dt = 0.1
open(3,file='streamline.dat')
read(3,*) im,jm
allocate(x(im,jm),y(im,jm),z(im,jm))
allocate(u(im,jm),v(im,jm),w(im,jm))
do i = 1, im
do j = 1, jm
  read(3,*) x(i,j),y(i,j),z(i,j),u(i,j),v(i,j),w(i,j)
enddo
enddo
close(3)
allocate(ex(me),ey(me),ez(me),es(me+1))
!open(1,file='tecress.dat')
!write(1,*) 'variables="x","y","z","u","v","w"'
!write(1,*) 'zone i=',im,' j=',jm,' f=point'
!do j = 1, jm
!do i = 1, im
!  write(1,*) x(i,j),y(i,j),z(i,j),u(i,j),v(i,j),w(i,j)
!enddo
!enddo
!close(1)
open(2,file='tecline.dat')
write(2,*) 'variables="x","y","u","v"'
write(2,*) 'zone i=',im,' j=',jm,' f=point'
do j = 1, jm
do i = 1, im
  write(2,*) x(i,j),y(i,j),u(i,j),v(i,j)
enddo
enddo
do j = 1, 20
  ei0 = 1
  ej0 = j
  call streamline(x,y,z,u,v,w,im,jm,ei0,ej0,dt,me,ex,ey,ez,es,ms)
  ! output streamline for tecplot
  write(2,*) 'zone i=',ms,'j=',1,' f=point'
  do i = 1, ms
    write(2,*) ex(i),ey(i),1,1
  enddo
enddo
close(2)
deallocate(x,y,z,u,v,w,ex,ey,ez,es)
end program main
! Bi-interpolation in logical field
! f00,f10,f11,f01 - function values on four corners [in]
! u,v - coordinates of logical cell [in]
! fuv - value at point (u,v) [out]
subroutine Binter(f00,f10,f11,f01,u,v,fuv)
implicit none
real f00,f10,f11,f01,u,v,fuv
fuv = (1-u)*(1-v)*f00 + u*(1-v)*f10 + u*v*f11 + (1-u)*v*f01
return
end subroutine Binter
! Calculate stream line on a given surface
! Parameters:
! x,y,z    - surface coordinates in phisical space [in]
! u,v,w    - velocity on surface in phisical space [in]
! im,jm    - dimension of surface grid [in]
! ei0,ej0  - start position of stream line [in]
! em   - number of point on stream line[in]
! ei,ej    - surface coordinates in logical space [out]
! es       - local length along stream line[out]
! eh       - streamline metric [out]
subroutine streamline(x,y,z,u,v,w,im,jm,ei0,ej0,dt,me,ex,ey,ez,es,ms)
implicit none
integer im,jm,me,i,j,m,ms,blOutBnd
real,dimension(im,jm):: x,y,z,u,v,w,ui,uj
real,dimension(im,jm):: Remi,Remj,Rems
real,dimension(me):: ex,ey,ez
real,dimension(me+1):: es
real:: ei0,ej0,ei,ej,fui,fuj,dt,ai,aj
call RightValue(x,y,z,im,jm,u,v,w,Remi,Remj,Rems)
ei = ei0
ej = ej0
ms = 0
blOutBnd = 0
do m = 1, me
  if(ei<1)then
    ei = 1
    blOutBnd = 1
  endif
  if(ej<1)then
    ej = 1
    blOutBnd = 1
  endif
  if(ei>im)then
    ei = im
    blOutBnd = 1
  endif
  if(ej>jm)then
    ej = jm
    blOutBnd = 1
  endif
  i = int(ei)
  j = int(ej)
  ai = ei-i
  aj = ej-j
  ms = ms + 1
  call Binter(Remi(i,j),Remi(i+1,j),Remi(i+1,j+1),Remi(i,j+1),ai,aj,fui)
  call Binter(Remj(i,j),Remj(i+1,j),Remj(i+1,j+1),Remj(i,j+1),ai,aj,fuj)
  ei = ei+dt*fui
  ej = ej+dt*fuj
  call Binter(x(i,j),x(i+1,j),x(i+1,j+1),x(i,j+1),ai,aj,ex(m))
  call Binter(y(i,j),y(i+1,j),y(i+1,j+1),y(i,j+1),ai,aj,ey(m))
  call Binter(z(i,j),z(i+1,j),z(i+1,j+1),z(i,j+1),ai,aj,ez(m))
  es(m+1) = es(m)+dt*sqrt(fui*fui+fuj*fuj)
  if(blOutBnd==1) goto 10
enddo
10 continue
return
end subroutine streamline
! Function for calculating the value of vector
function FmSqrt(dx,dy,dz)
implicit none
real FmSqrt,dx,dy,dz
FmSqrt = sqrt(dx*dx+dy*dy+dz*dz)
return
end function FmSqrt
! Calculate right value of difference equation
subroutine RightValue(x,y,z,im,jm,u,v,w,Remi,Remj,Rems)
implicit none
integer im,jm,i,j,in,jn
real,dimension(im,jm):: x,y,z,u,v,w,Remi,Remj,Rems
real,dimension(im,jm):: dxdi,dxdj,dxdk,dydi,dydj,dydk,dzdi,dzdj,dzdk
real:: Jack,didx,didy,didz,djdx,djdy,djdz,dkdx,dkdy,dkdz,Vel,dhdj
in = im-1
jn = jm-1
do j = 1, jm
  dxdi(1,j) = x(2,j)-x(1,j)
  dydi(1,j) = y(2,j)-y(1,j)
  dzdi(1,j) = z(2,j)-z(1,j)
  do i = 2, in
    dxdi(i,j) = 0.5*(x(i+1,j)-x(i-1,j))
    dydi(i,j) = 0.5*(y(i+1,j)-y(i-1,j))
    dzdi(i,j) = 0.5*(z(i+1,j)-z(i-1,j))
  enddo
  dxdi(im,j) = x(im,j)-x(in,j)
  dydi(im,j) = y(im,j)-y(in,j)
  dzdi(im,j) = z(im,j)-z(in,j)
enddo
do i = 1, im
  dxdj(i,1) = x(i,2)-x(i,1)
  dydj(i,1) = y(i,2)-y(i,1)
  dzdj(i,1) = z(i,2)-z(i,1)
  do j = 2, jn
    dxdj(i,j) = 0.5*(x(i,j+1)-x(i,j-1))
    dydj(i,j) = 0.5*(y(i,j+1)-y(i,j-1))
    dzdj(i,j) = 0.5*(z(i,j+1)-z(i,j-1))
  enddo
  dxdj(i,jm) = x(i,jm)-x(i,jn)
  dydj(i,jm) = y(i,jm)-y(i,jn)
  dzdj(i,jm) = z(i,jm)-z(i,jn)
enddo
do i = 1, im
do j = 1, jm
  dxdk(i,j) = dydi(i,j)*dzdj(i,j)-dydj(i,j)*dzdi(i,j)
  dydk(i,j) = dxdj(i,j)*dzdi(i,j)-dxdi(i,j)*dzdj(i,j)
  dzdk(i,j) = dxdi(i,j)*dydj(i,j)-dxdj(i,j)*dydi(i,j)
enddo
enddo
do i = 1, im
do j = 1, jm
  Jack = dxdi(i,j)*(dydk(i,j)*dzdj(i,j)-dydj(i,j)*dzdk(i,j))-  &
         dxdk(i,j)*(dydi(i,j)*dzdj(i,j)-dydj(i,j)*dzdi(i,j))+  &
         dxdj(i,j)*(dydi(i,j)*dzdk(i,j)-dydk(i,j)*dzdi(i,j))
  Jack = 1.0/Jack
  didx = Jack*(dydk(i,j)*dzdj(i,j)-dydj(i,j)*dzdk(i,j))
  didy = Jack*(dxdj(i,j)*dzdk(i,j)-dxdk(i,j)*dzdj(i,j))
  didz = Jack*(dxdk(i,j)*dydj(i,j)-dxdj(i,j)*dydk(i,j))
  djdx = Jack*(dydi(i,j)*dzdk(i,j)-dydk(i,j)*dzdi(i,j))
  djdy = Jack*(dxdk(i,j)*dzdi(i,j)-dxdi(i,j)*dzdk(i,j))
  djdz = Jack*(dxdi(i,j)*dydk(i,j)-dxdk(i,j)*dydi(i,j))
  dkdx = Jack*(dydj(i,j)*dzdi(i,j)-dydi(i,j)*dzdj(i,j))
  dkdy = Jack*(dxdi(i,j)*dzdj(i,j)-dxdj(i,j)*dzdi(i,j))
  dkdz = Jack*(dxdj(i,j)*dydi(i,j)-dxdi(i,j)*dydj(i,j))
  dhdj = sqrt(dxdj(i,j)*dxdj(i,j)+dydj(i,j)*dydj(i,j)+dzdj(i,j)*dzdj(i,j))
  Vel  = sqrt(u(i,j)*u(i,j)+v(i,j)*v(i,j)+w(i,j)*w(i,j))
  Remi(i,j) = dhdj*(u(i,j)*didx+v(i,j)*didy+w(i,j)*didz)
  Remj(i,j) = dhdj*(u(i,j)*djdx+v(i,j)*djdy+w(i,j)*djdz)
  Rems(i,j) = dhdj*Vel
enddo
enddo
return
end subroutine RightValue
发表于 2003-10-12 00:29:04 | 显示全部楼层
[原创]流线计算
tecplot本身就实现了这个功能了啊
发表于 2003-10-13 09:01:48 | 显示全部楼层
[原创]流线计算
还不如直接生成dxf格式,在cad好修改!
 楼主| 发表于 2003-10-18 22:18:09 | 显示全部楼层
[原创]流线计算
气动热工程计算的轴对称比拟法要用到流线,总不能用tecplot去完成吧!汗一个!这个流线不是拿来好看的。如果说好看,反而不如tecplot的牛。
发表于 2003-10-19 15:45:13 | 显示全部楼层
[原创]流线计算
下面引用由iceArcher在 2003/10/18 10:18pm 发表的内容:
怎么不能呢?既然流场数据有了,对称条件也有了。还画不出流线来。
 楼主| 发表于 2003-10-19 16:37:58 | 显示全部楼层
[原创]流线计算
不是说其他软件不能做流线,而是说必须在程序中实时地生成流线,然后根据流线来作气动热的估算。偶现在就在作这样的恶心工作,流线是没啥问题了,但老板希望能对任意外形都能算,而且希望精度要高。晕大了。每月300块的工资,想让我编个价值上万元的程序。我已经换了五个版本的程序了!每个程序都是5000行左右,我想干我自己的毕业课题啊~~~~~~日子不是人过的了!
发表于 2003-10-31 21:31:49 | 显示全部楼层
[原创]流线计算
同情中.............
发表于 2003-11-24 21:58:46 | 显示全部楼层
[原创]流线计算
高度同情
发表于 2004-2-11 15:28:06 | 显示全部楼层
[原创]流线计算
很同情
发表于 2004-2-12 01:56:59 | 显示全部楼层
[原创]流线计算
剥削啊!不给他干了!!!
发表于 2004-2-13 20:21:20 | 显示全部楼层
[原创]流线计算
支持原创性劳动!
发表于 2004-2-15 11:54:38 | 显示全部楼层
[原创]流线计算
兄弟在给哪里的老板做事呀?
发表于 2004-3-5 20:17:48 | 显示全部楼层
[原创]流线计算
真够惨的,不过大家也都是这样,你自己成为老板就好了,可以剥削别人了,呵呵。
发表于 2004-3-6 14:43:49 | 显示全部楼层
[原创]流线计算
不错。
