查看: 2280|回复: 5
请教原来发布的TTM网格程序
发表于 2004-7-15 23:18:28 | 显示全部楼层 |阅读模式
[这个贴子最后由harry在 2004/07/15 11:20pm 第 1 次编辑]
c=======================================================================72
      subroutine gridgen2d_TTM(nbx,nby,nblocx,nblocy,
     &                         IM,JM,linex,liney,X,Y,ISW,iprint)
c        c
c                     UUU        UUU    HH       HH                     c
c                      UU        UU     HH       HH                     c
c                      UU        UU     HH       HH                     c
c                      UU        UU     HH       HH                     c
c                      UU        UU     HHHHHHHHHHH                     c
c                      UU        UU     HH       HH                     c
c                      UU        UU     HH       HH                     c
c                       UU      UU      HH       HH                     c
c                         UUUUUU        HH       HH                     c
c        c
c                  USTC Hydrodynamics # "GridGen2D-TTM"                 c
c        c
c             2D Numerical Body-Fitted Grid Generation using            c
c            Elliptic Partial Differential Equations (P.D.E.)           c
c           by Thompson, Thames, Mastin (J.C.P. Vol.15, 1974)           c
c        c
c-----------------------------------------------------------------------c
c  Acknowledge: Teachers, researchers and students at USTC :-)          c
c        c
c  The user may use and modify the code or give it to third parties,    c
c  provided that an acknowledgement to the USTC source of the original  c
c  version is retained.                                                 c
c
c 2-D grid generation subroutine using elliptic P.D.E.
c to find source functions on boundaries
c
c Valid for geometry (transformed plane):
c      +--+     +-------+                    +-----------------+
c      |  |     |       |   +---+    +---+   |                 |
c   +--+  +--+  |   +---+   |   |    |   |   |   +--------+    |
c   |        |  |   |       |   +----+   |   |   |        |    |
c   +--+  +--+  |   +---+   |            |   |   +---+    |    |
c      |  |     |       |   +------------+   |       |    |    |
c      +--+     +-------+                    +-------+    +----+
c
c Variables:
c  nbx,nby       : number of x lines and y lines
c  nblocx,nblocy : location arrays of grid line (excluding boundaries)
c                  nblocx(num,1) start location of x line "num"
c                  nblocx(num,2) end location of x line "num"
c                  nblocx(num,3) y location of the special x line
c  linex,liney   : location arrays of grid points refering nblocx,nblocy
c                  reverse transformation of nblocx,nblocy on the grid
c  im,jm         : number of rectangle grid points which contains
c                  the physical domain
c  x,y           : arrays of grid points
c  isw           : improvement parameter for orthogonal property
c  iprint        : debug parameter to print the iteration information
c
c References:
c  Thmpson JF, Thames FC, Mastin CW, Automatic Numerical Generation of
c     Body-Fitted Curvilinear Coordinate System for Fields Containing
c     Any Number of Arbitrary Two-Dimensional Bodies, J. Comput. Phys.
c     Vol.15, pp.299-329, 1974.
c  Thomas PD, Middlecoff JF, Direct Control of the Grid Point Distribution
c     in Meshes Generated by Elliptic Equations, AIAA J. Vol.18, p.652
c     1980.
c  Thompson JF, Warsi ZUA, Mastin CW, Numerical Grid Generation,
c     Foundation and Application, North-Holland, New York, 1985.
c
c      subroutine gridgen2d_ttm(nbx,nby,nblocx,nblocy,
c     &                         IM,JM,linex,liney,X,Y,ISW,iprint)
      parameter (NI=250,NK=200)
c Params
      dimension nblocx(nbx,3),nblocy(nby,3)
     &         ,linex(im,jm), liney(im,jm)
      dimension X(IM,JM),Y(IM,JM)
c Locals
      dimension PHI(NI,NK),PSI(NI,NK)
      dimension A(NI),B(NI),C(NI)
      dimension D1(NI),D2(NI),D3(NI),BETA(NI)
      dimension I1(NI),I2(NI),J1(NI),J2(NI),K1(NI),K2(NI)
      dimension RTX(NI),RTY(NI),RTZ(NI),RTM1(NI),RTM2(NI),RTM3(NI)
c
c-----------------------------------------------------------------------72
c
c.....Set the constants
c
      PI=4.*ATAN(1.)
      OMG=1.615
      EPS=0.001
      ErrAngle = 10.
      NumIterPDE  = 200
      NumIterOrth = 100
c
c.....Calculate the coordinate transformation and
c     find source functions PHI, PSI on boundaries
c
      do ib = 1, nby
         I = nblocy(ib,3)
         jst = nblocy(ib,1)
         jed = nblocy(ib,2)
         do IDN = 1, 2
            J = jst + (IDN-1)*(jed-jst)
            XXI=(X(I+1,J)-X(I-1,J))/2.
            YXI=(Y(I+1,J)-Y(I-1,J))/2.
            XXX=(X(I-1,J)-2.*X(I,J)+X(I+1,J))
            YXX=(Y(I-1,J)-2.*Y(I,J)+Y(I+1,J))
            PHI(I,J)=-(XXI*XXX+YXI*YXX)/(XXI**2+YXI**2)
         end do
         do J = jst+1, jed-1
            ET=FLOAT(J-jst)/FLOAT(jed-jst)
            PHI(I,J)=(1.-ET)*PHI(I,jst)+ET*PHI(I,jed)
c...........! Initial guess
c            y(i,j) = (1.-et)*y(i,jst)+et*y(i,jed)
         end do
      end do
      do ib = 1, nbx
         J = nblocx(ib,3)
         ist = nblocx(ib,1)
         ied = nblocx(ib,2)
         do IDN = 1, 2
            I = ist + (IDN-1)*(ied-ist)
            XET=(X(I,J+1)-X(I,J-1))/2.
            YET=(Y(I,J+1)-Y(I,J-1))/2.
            XEE=(X(I,J-1)-2.*X(I,J)+X(I,J+1))
            YEE=(Y(I,J-1)-2.*Y(I,J)+Y(I,J+1))
            PSI(I,J)=-(XET*XEE+YET*YEE)/(XET**2+YET**2)
         end do
         do I = ist+1, ied-1
            XI=FLOAT(I-ist)/FLOAT(ied-ist)
            PSI(I,J)=(1.-XI)*PSI(ist,J)+XI*PSI(ied,J)
c            x(i,j) = (1.-xi)*x(ist,j)+xi*x(ied,j)
         end do
      end do
c
c.....Iteration for Elliptic P.D.E. Iteration for Elliptic P.D.E.
c
      ITEOUT=1
40   CONTINUE
      N=1
50   CONTINUE
      EPXM=0.
      EPYM=0.
      DSMIN=10000.
      ARMIN=10000.
      ARMAX=0.
c
c.....SLOR method for Elliptic P.D.E. along Y directional line,
c     require the X lines should be continuous such as the above sketch
c     but have no requirement for Y lines
c
      do 100 ib = 1, nby
         I = nblocy(ib,3)
         jst = nblocy(ib,1)
         jed = nblocy(ib,2)
         do 60 J = jst+1, jed-1
            XXE=(X(I+1,J+1)-X(I+1,J-1)-X(I-1,J+1)+X(I-1,J-1))/4.
            YXE=(Y(I+1,J+1)-Y(I+1,J-1)-Y(I-1,J+1)+Y(I-1,J-1))/4.
            ALP=XET**2+YET**2
            BT=XXI*XET+YXI*YET
            ist = nblocx(linex(i,j),1)
            ied = nblocx(linex(i,j),2)
            IF(I.EQ.ist+1 .OR. I.EQ.ied-1 .OR.
     &         J.EQ.jst+1 .OR. J.EQ.jed-1) BT=0.
            GM=XXI**2+YXI**2
            A(J-1)=GM*(1.-.5*PSI(I,J))
            B(J-1)=-2.*(ALP+GM)
            C(J-1)=GM*(1.+.5*PSI(I,J))
            DB=-ALP*(X(I-1,J)+X(I+1,J))+2.*BT*XXE-ALP*PHI(I,J)*XXI
            D1(J-1)=DB
            IF(J.EQ.jst+1) D1(J-1)=DB-A(J-1)*X(I,jst)
            IF(J.EQ.jed-1) D1(J-1)=DB-C(J-1)*X(I,jed)
            DB=-ALP*(Y(I-1,J)+Y(I+1,J))+2.*BT*YXE-ALP*PHI(I,J)*YXI
            D2(J-1)=DB
            IF(J.EQ.jst+1) D2(J-1)=DB-A(J-1)*Y(I,jst)
            IF(J.EQ.jed-1) D2(J-1)=DB-C(J-1)*Y(I,jed)
60      CONTINUE
         A(jst)=0.
         C(jed-2)=0.
c
c........Tri-diagonal equation solver, call the subroutine
c
         CALL TRI2D(jed-jst-1,A(jst),B(jst),C(jst),D1(jst),D2(jst),
     &              BETA(jst),RTM1(jst),RTM2(jst),RTX(jst),RTY(jst))
c
c........Compute the new grid coordinates by relax iteration,
c        and post error estimating
c
         DO 90 J = jst+1, jed-1
            XPRV=X(I,J)
            YPRV=Y(I,J)
            X(I,J)=OMG*RTX(J-1)+(1.-OMG)*X(I,J)
            Y(I,J)=OMG*RTY(J-1)+(1.-OMG)*Y(I,J)
            DS1=SQRT((X(I,J)-X(I-1,J))**2+(Y(I,J)-Y(I-1,J))**2)
            DS2=SQRT((X(I,J)-X(I,J-1))**2+(Y(I,J)-Y(I,J-1))**2)
            AR=DS1/DS2
            DSLOC=AMIN1(DS1,DS2)
            DSMIN=AMIN1(DSMIN,DSLOC)
            ARMIN=AMIN1(ARMIN,AR)
            ARMAX=AMAX1(ARMAX,AR)
            IF(J.NE.jed-1) GO TO 70
            DS22=SQRT((X(I,J)-X(I,J+1))**2+(Y(I,J)-Y(I,J+1))**2)
            AR=DS1/DS22
            DSLOC=AMIN1(DSLOC,DS22)
70         IF(I.NE.nblocx(linex(i,j),2)-1) GO TO 80
            DS12=SQRT((X(I,J)-X(I+1,J))**2+(Y(I,J)-Y(I+1,J))**2)
            AR=DS12/DS2
            DSLOC=AMIN1(DSLOC,DS12)
            IF(J.EQ.jed-1) ARMIN=AMIN1(ARMIN,DS12/DS22)
            IF(J.EQ.jed-1) ARMAX=AMAX1(ARMAX,DS12/DS22)
80         EPX=ABS(X(I,J)-XPRV)/DSLOC
            EPY=ABS(Y(I,J)-YPRV)/DSLOC
            IF(EPX.GT.EPXM) EPXM=EPX
            IF(EPY.GT.EPYM) EPYM=EPY
90      CONTINUE
100  CONTINUE
c
c.....Internal output options
c
c      if (iprint.eq.1) WRITE (*,*) N,EPXM,EPYM,ADFM
      IF(N.GT.NumIterPDE) GO TO 110
      IF(EPXM.LT.EPS.AND.EPYM.LT.EPS) GO TO 110
      N=N+1
      GO TO 50
110  CONTINUE
c
c.....Y lines iteration end
c
      IF(ISW.EQ.1) GO TO 150
c
c.....Orthogonal property requirement and improvement,
c     need more outer iteration
c
      ADFM=0.
      ADFV=0.
      do ib = 1, nby
         I = nblocy(ib,3)
         jst = nblocy(ib,1)
         jed = nblocy(ib,2)
         do IDN = 1, 2
            JV= jst + (IDN-1)*(jed-jst-1)
            XET=(X(I,JV+1)-X(I,JV))
            YET=(Y(I,JV+1)-Y(I,JV))
            RX=SQRT(XXI**2+YXI**2)
            RE=SQRT(XET**2+YET**2)
            RXRE=XXI*XET+YXI*YET
            COSA=RXRE/(RX*RE)
            ANG=ACOS(COSA)
            DIFA=0.5*PI-ANG
            ADFM=AMAX1(ADFM,ABS(DIFA))
            ADFV=ADFV+ABS(DIFA)
            SGN=FLOAT(3-2*IDN)
            PHI(I,J)=PHI(I,J)-SGN*0.1*TANH(DIFA)
         end do
         do J = jst+1, jed-1
         end do
      end do
      do ib = 1, nbx
         J = nblocx(ib,3)
         ist = nblocx(ib,1)
         ied = nblocx(ib,2)
         do IDN = 1, 2
            IV= ist + (IDN-1)*(ied-ist-1)
            XXI=(X(IV+1,J)-X(IV,J))
            YXI=(Y(IV+1,J)-Y(IV,J))
            COSA=RXRE/(RX*RE)
            ANG=ACOS(COSA)
            DIFA=0.5*PI-ANG
            SGN=FLOAT(3-2*IDN)
            PSI(I,J)=PSI(I,J)-SGN*0.1*TANH(DIFA)
         end do
         do I = ist+1, ied-1
         end do
      end do
      ADFM=ADFM*180./PI
      ADFV=ADFV/(2.*IM)
      if (iprint.eq.1)
     &    WRITE (*,*) 'IOUT=',ITEOUT,'  DIF=',ADFM,'  DIV=',ADFV
      IF(ADFM.LT.ErrAngle.or.iteout.gt.NumIterOrth) GO TO 150
      ITEOUT=ITEOUT+1
      GO TO 40
150  continue
      return
      end
      SUBROUTINE TRI2D(N,A,B,C,F1,F2,BETA,Y1,Y2,X1,X2)
      DIMENSION A(N),B(N),C(N),X1(N),X2(N),F1(N),F2(N)
      DIMENSION BETA(N),Y1(N),Y2(N)
c
      BETA(1)=C(1)/B(1)
      NM1=N-1
      DO 10 I=2,NM1
         BETA(I)=C(I)/(B(I)-A(I)*BETA(I-1))
  10  CONTINUE
      Y1(1)=F1(1)/B(1)
      Y2(1)=F2(1)/B(1)
      DO 20 I=2,N
         Y1(I)=(F1(I)-A(I)*Y1(I-1))/(B(I)-A(I)*BETA(I-1))
         Y2(I)=(F2(I)-A(I)*Y2(I-1))/(B(I)-A(I)*BETA(I-1))
  20  CONTINUE
      X1(N)=Y1(N)
      X2(N)=Y2(N)
      DO 30 K=1,NM1
         X1(N-K)=Y1(N-K)-BETA(N-K)*X1(N-K+1)
         X2(N-K)=Y2(N-K)-BETA(N-K)*X2(N-K+1)
  30  CONTINUE
      RETURN
      END
上边是程序,请问程序中求解对三角用的是什么方法,也就是TRI2D(N,A,B,C,F1,F2,BETA,Y1,Y2,X1,X2)对应的子程序
发表于 2004-7-15 23:23:11 | 显示全部楼层
请教原来发布的TTM网格程序
解三对角,不用追赶法用什么?
 楼主| 发表于 2004-7-16 07:52:35 | 显示全部楼层
请教原来发布的TTM网格程序
我怎么看,不是追赶法
发表于 2004-7-16 17:12:15 | 显示全部楼层
请教原来发布的TTM网格程序
[这个贴子最后由wangdingxi在 2004/07/16 10:44pm 第 1 次编辑]
老兄,这明摆着是追赶法。解三对角不用追赶法。让我给你细细道来;
c
     BETA(1)=C(1)/B(1)
     NM1=N-1
     DO 10 I=2,NM1
10  CONTINUE
     Y1(1)=F1(1)/B(1)
     Y2(1)=F2(1)/B(1)
     DO 20 I=2,N
20  CONTINUE
     X1(N)=Y1(N)
     X2(N)=Y2(N)
     DO 30 K=1,NM1
30  CONTINUE
     RETURN
     END
这个程序就是用来解三对角方程的,并且解两个方程组(每个方程组NxN),方程组形式如下
A(I)X(I-1)+B(I)X(I)+C(I)X(I+1)=F(I)     (1)
LET X(I)=Y(I)-BETA(I)X(I+1)              (2)
substitute the (2) into (1),we get
A(I)( Y(I-1)-BETA(I-1)X(I))+B(I)X(I)+C(I)X(I+1)=F(I) (3)
organize the above we get
X(I)=(F(I)-A(I)Y(I-1))/(B(I)-A(I)BETA(I-1))-C(I)/(B(I)-A(I)BETA(I-1)) (4)
compare (2) and (4) we can get
BETA(I)=C(I)/(B(I)-A(I)BETA(I-1))
Y(I)=(F(I)-A(I)Y(I-1))/(B(I)-A(I)BETA(I-1))
这就是从追赶法推出来的,你看看求BETA的表达式和求Y1,Y2的表达式是不是和我的一样?
有问题吗?
 楼主| 发表于 2004-7-16 20:46:43 | 显示全部楼层
请教原来发布的TTM网格程序
先谢谢,不过帮人不必用这种方式表达吧,基础不一样嘛!本来很感激你
发表于 2004-7-16 22:41:32 | 显示全部楼层
请教原来发布的TTM网格程序
下面引用由harry在 2004/07/16 08:46pm 发表的内容:
呵呵,把你当老朋友了,不要介意。其实我也是菜鸟:)
