查看: 1708|回复: 0
求助:关于等值线的算法
发表于 2004-7-17 19:51:04 | 显示全部楼层 |阅读模式
下面是书上的关于等值线的程序源码(BASIC),总是看不明白,请高手指教!多谢
CONTZ:                                       '  display isovalue contours
        ZXO = 100: ZYO = 350: DZX = 400 / NX1: DZY = -200 / NY1
        LINE (ZXO, ZYO)-(ZXO + NX1 * DZX, ZYO + NY1 * DZY), GW%, B, &HFFFF
        XA = ZXO: YA = ZYO: XB = ZXO + (IXS - 1) * DZX: YB = ZYO + (IYS - 1) * DZY
        Line (XA, YA)-(XB, YB), GW%, BF
        ZMAX = -1000: ZMIN = 1000
        For IX = 1 To NX: For IY = 1 To NY
                If Z(IX, IY) > ZMAX Then ZMAX = Z(IX, IY)
                If Z(IX, IY) < ZMIN Then ZMIN = Z(IX, IY)
        Next IY: Next IX
        IXP% = ZXO / 16: IYP% = ZYO / 16 + 1
        LOCATE IYP%, 18:
        Print USING; "Max. value=##.###^^^^  Min. value=##.###^^^^"; ZMAX; ZMIN;
        ZMIN = 0: DZ = (ZMAX - ZMIN) / NZ
        If DZ = 0 Then Return
        For IX = 1 To NX1: For IY = 1 To NY1
           XI = IX - 1: YI = IY - 1: XI1 = XI + 1: YI1 = YI + 1
           N = 0
           For K = 1 To NZ: GPK(K) = 0: GPX(K) = 0: GPY(K) = 0: Next K
           Z1 = (Z(IX, IY) - ZMIN) / DZ
           Z2 = (Z(IX, IY + 1) - ZMIN) / DZ
           Z3 = (Z(IX + 1, IY + 1) - ZMIN) / DZ
           Z4 = (Z(IX + 1, IY) - ZMIN) / DZ
           K1 = Int(Z1): K2 = Int(Z2): K3 = Int(Z3): K4 = Int(Z4)
           If K1 <> K2 Then
                  DZ1 = 1 / (Z2 - Z1)
                  KB = K1 + 1: KE = K2: If K1 > K2 Then KB = K2 + 1: KE = K1
                  For K = KB To KE
                         N = N + 1: GPK(N) = K: GPX(N) = XI * DZX + ZXO
                         GPY(N) = Int((YI + (K - Z1) * DZ1) * DZY + ZYO)
                  Next K
           End If
           N1 = N
           If K2 <> K3 Then
                  DZ2 = 1 / (Z3 - Z2)
                  KB = K2 + 1: KE = K3: If K2 > K3 Then KB = K3 + 1: KE = K2
                  For K = KB To KE
                         N = N + 1: GPK(N) = K: GPY(N) = YI1 * DZY + ZYO
                         GPX(N) = Int((XI + (K - Z2) * DZ2) * DZX + ZXO)
                  Next K
           End If
           N2 = N
           If K3 <> K4 Then
                  DZ3 = 1 / (Z3 - Z4)
                  KB = K3 + 1: KE = K4: If K3 > K4 Then KB = K4 + 1: KE = K3
                  For K = KB To KE
                         N = N + 1: GPK(N) = K: GPX(N) = XI1 * DZX + ZXO
                         GPY(N) = Int((YI + (K - Z4) * DZ3) * DZY + ZYO)
                  Next K
           End If
           N3 = N
           If K4 <> K1 Then
                  DZ4 = 1 / (Z4 - Z1)
                  KB = K1 + 1: KE = K4: If K1 > K4 Then KB = K4 + 1: KE = K1
                  For K = KB To KE
                         N = N + 1: GPK(N) = K: GPY(N) = YI * DZY + ZYO
                         GPX(N) = Int((XI + (K - Z1) * DZ4) * DZX + ZXO)
                  Next K
           End If
           N4 = N
           If K4 <> K2 Then
                  DZ5X = 1 / (Z2 - Z4): DZ5Y = 1 / (Z2 - Z4)
                  KB = K4 + 1: KE = K2: If K4 > K2 Then KB = K2 + 1: KE = K4
                  For K = KB To KE
                          GPX(N) = Int((XI1 - (K - Z4) * DZ5X) * DZX + ZXO)
                          GPY(N) = Int((YI + (K - Z4) * DZ5Y) * DZY + ZYO)
                  Next K
           End If
           N5 = N
           For N = 1 To N1: For NN = N3 + 1 To N4
                  If GPK(N) = GPK(NN) Then
                         CL = GPK(N)
                         While CL > 7: CL = CL - 7: Wend
                         While CL < 1: CL = CL + 7: Wend
                         LINE (GPX(N), GPY(N))-(GPX(NN), GPY(NN)), GC%(CL), , &HFFFF
                  End If
           Next NN: Next N
           For N = N1 + 1 To N2: For NN = N2 + 1 To N3
                         CL = GPK(N)
                  End If
           Next NN: Next N
           For N = N4 + 1 To N5: For NN = 1 To N4
                         CL = GPK(N)
                  End If
           Next NN: Next N
        Next IY: Next IX
Return
