查看: 3081|回复: 0
Senior Research Assistant/Associate--City University of Hongkong
发表于 2008-6-22 16:18:20 | 显示全部楼层 |阅读模式
We are seeking for a Research Senior Assistant/Associate to work on experimental measurement of
VOC and bioaerosols.
Ideal candidate should have
1. PhD Degree(s) in chemical engineering/applied biology or a closely related field with sound knowledge of
surface reaction, adsorption, activated carbon and photocatalytic oxidation,
2. Willing to work as a team.
4. Knowledge in microbiology is an advantage but not critical.
The position is expected to be filled immediately for an initial period of one
year with the possibility of extension, subject to the availability of funds.
Interested candidates should submit a full curriculum vitae, covering letter
together with academic records (pdf.file, please) to Dr. Alvin Lai
(alvinlai@cityu.edu.hk). More information regarding to the research activities
by the team can be found http://personal.cityu.edu.hk/~alvinlai/
