查看: 2437|回复: 1
[求助]CFX—5.6安装后出现异常?
发表于 2004-4-15 13:06:38 | 显示全部楼层 |阅读模式
各位大虾:我安装了CFX—5。6后,打开该软件时我按了CFX—Bulid后出现Warning: You appear to be running in a directory containing spaces. while this is a valid  thing to do , some parts of CFX—5 will not work correctly under these circumstances ,and so we recommend against running CFX—5 this way.
这不知是我软件安装的问题还是其他什么问题。望各位指导!!!!!!!!!!
发表于 2004-4-19 09:45:23 | 显示全部楼层
[求助]CFX—5.6安装后出现异常?
试着更换起始路径
