查看: 3612|回复: 0
command to look at the results from the beginning
发表于 2007-7-1 23:36:56 | 显示全部楼层 |阅读模式
Often there are too many results printed on screen. Then it is hard to see the results at the beginning because it is impossible to roll back the slider that far. One way to solve the problem is to pipe the results to less, like:
      cfd.exe input.dat | less
cfd.exe is the binary and input.dat is the control file. Press space key to move forward to see the results from beginning. less is similar to more.
