查看: 4476|回复: 1
autorun.inf 专杀
发表于 2007-7-17 20:25:49 | 显示全部楼层 |阅读模式
@echo off
title autorun专杀工具
color 9A
echo 欢迎使用autorun专杀工具!
echo ------------------------
echo 如果你的光驱中有光盘请先弹出然后继续!
:n
echo 您要继续吗?输入y整机杀毒开始,输入u只杀u盘,输入n退出!
:retry
set /p c=请输入您的选择(y/u/n):
if "%c%"=="y" goto s
if "%c%"=="u" goto b
if "%c%"=="n" goto t
goto retry
:b
set /p a=请输入你要查杀的盘符(e f g...):
if "%a%"=="e" goto e
if "%a%"=="f" goto f
if "%a%"=="g" goto g
if "%a%"=="h" goto h
if "%a%"=="i" goto i
if "%a%"=="j" goto j
if "%a%"=="k" goto k
if "%a%"=="l" goto l
echo 输入错误!请重新输入!&&goto b
:s
taskkill /im explorer.exe /f
taskkill /im wscript.exe /f
taskkill /im algsrvs.exe /f
start reg DELETE HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run /v IMJPMIG8.2 /f
start reg DELETE HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run /v MsServer /f
start reg DELETE HKEY_LOCAL_MACHINE\Software\Microsoft\windows\CurrentVersion\explorer\Advanced\Folder\Hidden\SHOWALL /v CheckedValue /f
start reg add HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\EXplorer\Advanced /v ShowSuperHidden /t REG_DWORD /d 1 /f
start reg add HKEY_LOCAL_MACHINE\Software\Microsoft\windows\CurrentVersion\explorer\Advanced\Folder\Hidden\SHOWALL /v CheckedValue /t REG_DWORD /d 1 /f
start reg import kill.reg
attrib c:\fun.xls.exe -h -r -a -s
attrib c:\autorun.* -h -r -a -s
del c:\autorun.* c:fun.xls.exe /f
attrib %SYSTEMROOT%\system32\fun.xls.exe -h -r -a -s
attrib %SYSTEMROOT%\system32\autorun.* -h -r -a -s
del %SYSTEMROOT%\system32\autorun.* %SYSTEMROOT%\system32\msime82.exe %SYSTEMROOT%\system32\algsrvs.exe %SYSTEMROOT%\system32\fun.xls.exe %SYSTEMROOT%\system32\msfun80.exe /f
del %temp%\~DF8785.tmp %temp%\~DFD1D6.tmp %temp%\~DFA4C3 %temp%\~DFC86B.tmp /f /q /as
del %systemroot%\ufdata2000.log /f
attrib d:\fun.xls.exe -h -r -a -s
attrib d:\autorun.* -h -r -a -s
del d:\autorun.* d:\fun.xls.exe /f
attrib e:\fun.xls.exe -h -r -a -s
attrib e:\autorun.* -h -r -a -s
del e:\autorun.* e:\fun.xls.exe /f
attrib f:\fun.xls.exe -h -r -a -s
attrib f:\autorun.* -h -r -a -s
del f:\autorun.* f:\fun.xls.exe /f
attrib g:\fun.xls.exe -h -r -a -s
attrib g:\autorun.* -h -r -a -s
del g:\autorun.* g:\fun.xls.exe /f
attrib h:\fun.xls.exe -h -r -a -s
attrib h:\autorun.* -h -r -a -s
del h:\autorun.* h:\fun.xls.exe /f
attrib i:\fun.xls.exe -h -r -a -s
attrib i:\autorun.* -h -r -a -s
del i:\autorun.* i:\fun.xls.exe /f
attrib j:\fun.xls.exe -h -r -a -s
attrib j:\autorun.* -h -r -a -s
del j:\autorun.* j:\fun.xls.exe /f
attrib k:\fun.xls.exe -h -r -a -s
attrib k:\autorun.* -h -r -a -s
del k:\autorun.* k:\fun.xls.exe /f
attrib l:\fun.xls.exe -h -r -a -s
attrib l:\autorun.* -h -r -a -s
del l:\autorun.* l:\fun.xls.exe /f
start explorer.exe
cls
if exist c:\autorun.reg echo 病毒没有清除!&&goto n
if exist c:\fun.xls.exe echo 病毒没有清除!&&goto n
echo 杀毒成功!感谢您的支持!十九真诚为你工作!
set /p d=现在重新启动系统确定吗?(y/n):
if "%d%"=="y" shutdown -r -t 0
exit
if "%d%"=="n"
echo  按任意键退出。
pause
exit
:t
echo 多谢您的支持!按任意键退出。
pause
exit
:e
cls
if not exist e:\autorun.* echo 您的u盘没有病毒!&&goto t
cls
if exist e:\autorun.reg echo 病毒没有清除!&&goto n
if exist e:\fun.xls.exe echo 病毒没有清除!&&goto n
goto m
:f
cls
if not exist f:\autorun.* echo 您的u盘没有病毒!&&goto t
cls
if exist f:\autorun.reg echo 病毒没有清除!&&goto n
if exist f:\fun.xls.exe echo 病毒没有清除!&&goto n
goto m
:h
cls
if not exist h:\autorun.* echo 您的u盘没有病毒!&&goto t
cls
if exist h:\autorun.reg echo 病毒没有清除!&&goto n
if exist h:\fun.xls.exe echo 病毒没有清除!&&goto n
goto m
:i
cls
if not exist i:\autorun.* echo 您的u盘没有病毒!&&goto t
cls
if exist i:\autorun.reg echo 病毒没有清除!&&goto n
if exist i:\fun.xls.exe echo 病毒没有清除!&&goto n
goto m
:j
cls
if not exist j:\autorun.* echo 您的u盘没有病毒!&&goto t
cls
if exist j:\autorun.reg echo 病毒没有清除!&&goto n
if exist j:\fun.xls.exe echo 病毒没有清除!&&goto n
goto m
:k
cls
if not exist k:\autorun.* echo 您的u盘没有病毒!&&goto t
cls
if exist k:\autorun.reg echo 病毒没有清除!&&goto n
if exist k:\fun.xls.exe echo 病毒没有清除!&&goto n
goto m
:l
cls
if not exist l:\autorun.* echo 您的u盘没有病毒!&&goto t
cls
if exist l:\autorun.reg echo 病毒没有清除!&&goto n
if exist l:\fun.xls.exe echo 病毒没有清除!&&goto n
goto m
:m
cls
echo 杀毒成功,请重新弹出后在插入您的u盘!按任意键退出。谢谢你的支持!
pause
exit
以上存为**.bat运行即可,还可以,还好用。
发表于 2007-7-17 20:35:47 | 显示全部楼层
autorun.inf 专杀
麦咖啡可以杀。
