查看: 5444|回复: 0
work as an adminstrator
发表于 2008-2-5 04:22:54 | 显示全部楼层 |阅读模式
[这个贴子最后由newcfd在 2008/02/05 04:30am 第 1 次编辑]
After you install Ubunto, you may not be able to use sudo. If you want to add you to administrator list, you can get to root to do it. The steps are as follows:
   1. sudo bash
    2. type your password  to  sign in
    3. adduser username admin
    4. exit
At first to use command "id" to check if your user name is in the administrator list.
[ 本帖最后由 webmaster 于 2010-8-31 18:05 编辑 ]
