查看: 6741|回复: 9
软件介绍:River2D
发表于 2005-1-21 12:25:12 | 显示全部楼层 |阅读模式
软件介绍:River2D
River2D是垂向平均二维水动力学模型,包括四个软件包:R2D_Bed , R2D_Ice, R2D_Mesh 和 River2D。R2D_Bed用于编辑河床地形,R2D_Ice用于编辑模拟冰盖中的冰盖区域,R2D_Mesh用于生成River2D计算需要的网格。
呵呵,就翻译这么几句。剩下的自己看吧:)
 楼主| 发表于 2005-1-21 12:27:53 | 显示全部楼层
软件介绍:River2D
Background
River2D is a two dimensional depth averaged finite element hydrodynamic model that has been customized for fish habitat evaluation studies. The River2D model suite actually consists of four programs: R2D_Bed , R2D_Ice, R2D_Mesh and River2D. All three programs have graphical user interfaces that are supported by any 32 bit version of Windows. R2D_Bed, R2D_Ice, and R2D_Mesh are graphical file editors. R2D_Bed was designed for editing bed topography data while R2D_Ice is intended for developing ice topographies to be used in the modelling of ice-covered domains. The R2D_Mesh program is used for the development of computational meshes that will ultimately be input for River2D.
These programs are typically used in succession. The normal modelling process would involve creating a preliminary bed topography file (text) from the raw field data, then editing and refining it using R2D_Bed. If an ice-covered domain were being modelled, R2D_Ice would be used to develop ice topography. The resulting bed topography file is used (inconjunction with an ice topography file where relevant) in R2D_Mesh to develop a computational discretization as input to River2D. River2D is then used to solve for the water depths and velocities throughout the discretization. Finally, River2D is used to visualize and interpret the results and perform PHABSIM type fish habitat analyses. An iterative approach at various stages, including modification of the bed topography (and ice topography), is usual.
R2D_Bed
Accurate representation of the physical features of the river channel bed is probably the most crucial factor in successful river flow modelling. In addition to accurate and extensive field data, judgement and experience are necessary to connect the scattered data points into a digital surface representation. The River2D model family is based on the Triangulated Irregular Network (TIN) methodology, including breaklines, for spatial interpolation of nodal parameters. The nodal values are usually measured points, but the breakline locations are judgemental. R2D_Bed allows interactive setting and deleting of breakline segments.
The relevant physical characteristics of the channel bed necessary for flow modelling are the bed elevation and the bed roughness height. R2D_Bed allows these values to be edited on an individual point basis or over irregular polygonal regions. R2D_Bed is also useful for editing channel index files, used in habitat analyses, with channel index replacing roughness height as the second nodal parameter.
R2D_Ice
The River2D is equipped to model flow under an ice cover of known geometry. Ice properties relevant to the 2D hydrodynamic calculations are ice thickness and ice roughness height at every node in the computational domain. R2D_Ice allows provides the user with an effective graphical environment for the development of ice topography files. Various commands allow the user to modify ice properties globally, regionally, or individually. Breakline can be inserted into an ice topography to define the edge of the ice in partially ice-covered domains.
R2D_Mesh
The purpose of R2D_Mesh is to provide a relatively easy to use but effective computational mesh generating environment for two-dimensional depth average finite element hydrodynamic modelling. To generate a mesh, the necessary input to the R2D_Mesh program is a bed topography file, possibly edited in R2D_Bed, defining the reach of interest using pointwise elevations and roughnesses. The points can be independent or connected in breaklines or featurelines. Once the bed topography is input, the user can graphically define the computation discretization and boundary conditions with the aid of various tools in the R2D_Mesh enviroment. When the user is satisfied, an input file for the River2D program can be generated.
River2D
The River2D model is a two-dimensional, depth averaged finite element model. It is intended for use on natural streams and rivers and has special features for accommodating supercritical /subcritical flow transitions and variable wetted area. It is basically a transient model but provides for an accelerated convergence to steady-state conditions.
The River2D environment has a number of options to aid the user in visualizing the progression and/or final results of the hydrodynamic computations including colour maps, contour maps and velocity vector fields.
The fish habitat module in River2D is based on the PHABSIM weighted usable area approach, adapted for a triangular irregular network geometrical description. The visual aids can also be used to display the results of habitat analyses.
In River2D, the user also has access to a few mesh editing commands so that adjustments can be made to the mesh without having to leave the River2D environment.
 楼主| 发表于 2005-1-21 13:13:04 | 显示全部楼层
软件介绍:River2D
bedprogram
 楼主| 发表于 2005-1-21 13:29:54 | 显示全部楼层
软件介绍:River2D
iceprogram
 楼主| 发表于 2005-1-21 13:42:02 | 显示全部楼层
软件介绍:River2D
meshprogram
 楼主| 发表于 2005-1-21 13:43:59 | 显示全部楼层
软件介绍:River2D
flow
发表于 2005-1-21 14:53:13 | 显示全部楼层
软件介绍:River2D
那里有下载的?不吝赐教吧!谢谢
发表于 2005-2-10 23:56:06 | 显示全部楼层
软件介绍:River2D
我用过River2D这个软件,这个软件的最大好处就是使用特别简单,有过其它商用软件使用经验的人估计用个3到5天时间就可以很熟练地使用它了。它的最大缺点是,只能是非常标准的边界条件,即入流侧是流量边界条件,出流侧是水位边界条件,使用上受到了很大的限制。如果工程上只知道了入流是水位边界条件,而出流是流量边界条件用起来就非常麻烦,得用试算来解决,尤其是对分叉河道更是郁闷。
发表于 2005-3-26 15:44:21 | 显示全部楼层
软件介绍:River2D
哪里有下的:告示我一下:flasit@126.com
感谢,
发表于 2005-5-25 21:57:25 | 显示全部楼层
软件介绍:River2D
能够很好的模拟水流马?
