查看: 5657|回复: 9
[分享]刘峰老师的个人主页
发表于 2005-7-27 16:45:48 | 显示全部楼层 |阅读模式
http://fliu.eng.uci.edu/
有刘峰老师的简历和主要论文作品,可以下载
榜样……
 楼主| 发表于 2005-7-28 10:29:02 | 显示全部楼层
[分享]刘峰老师的个人主页
C15_Computation of Mistuning Effects on Cascade Flutter.pdf
C16_Computation of Mistuning Effects on Cascade Flutter.pdf
C17_Computation of Mistuning Effects on Cascade Flutter.pdf
C18_Ignition and Flame Studies for an Accelerating Transonic.pdf
C19_Turbojet and Turbofan Engine Performance Increases.pdf
C20_Development and Validation of a Massively Parallel Flow Solver.pdf
C21_Unsteady Flow Calculations with a Multi-Block Moving.pdf
C22_Calculation of Wing Flutter by a Coupled CFD-CSD.pdf
C23_Flutter Predictions by a Filtered Impulse.pdf
C24_COMPUTATION OF CASCADE FLUTTER WITH A COUPLED.pdf
C25_A THREE DIMENSIONAL NAVIER-STOKES CODE FOR.pdf
C26_Ignition and Flame Studies for Turbulent.pdf
C27_Ignition and Flame Studies.pdf
C28_Investigation of Non-Linear Flutter by a.pdf
C29_Static Aero-elastic Computation with.pdf
C30_Three-Dimensional Flame Propagation.pdf
C31_Combustion in a Transonic Flow with Large Axial and.pdf
C32_Stability of a Vortex Pair Behind.pdf
C33_Stability of Symmetric Vortices over Slender.pdf
C34.pdf
C35_Opposed Flow Impact on Flame Spread.pdf
C36_SIMULATIONS OF AEROELASTICITY IN AN ANNULAR CASCADE USING A.pdf
C37_Viscous Computation of SteadyUnsteady Transonic Diffuser Flows.pdf
C38_GRIDLESSS BOUNDARY CONDITION TREATMENT FOR A.pdf
C39_Aerodynamic Design of Cascades by Using an.pdf
C40.pdf
C41_EULER SOLUTION USING CARTESIAN GRID WITH LEAST SQUARES TECHNIQUE.pdf
C42_Calculation of Unsteady Transonic Flow by an.pdf
C43_Parallel Computation of Wing Flutter with a.pdf
C44_Computation of Shock Induced Separated Flow with a Lagged k-ω Turbulence Model.pdf
C45_Application of Spline Matrix for Mesh Deformation.pdf
C46.pdf
C47.pdf
C48_CARTESIAN GRID SOLUTION OF THE EULER EQUATIONS.pdf
C49_Comparison of Three Geometric.pdf
C50_AN OVERSET GRID SOLVER FOR VISCOUS COMPUTATIONS.pdf
J07.pdf
J10_AN ADAPTIVE GRID METHOD AND ITS APPLICATION.pdf
J11_TURBULENT TRANSITION SIMULATION.pdf
J12.pdf
J13_Flutter Computation of Turbomachinery Cascades.pdf
J14_Level-Set-Based Deformation Methods.pdf
J15_Computation of Mistuning Effects on Cascade Flutter.pdf
J16_Turbojet and Turbofan Engine Performance.pdf
J17_Calculation ofWing Flutter by a Coupled Fluid-StructureMethod.pdf
J18_Development and Validation of a Massively Parallel.pdf
J19_Ignition and Flame Studies for an Accelerating.pdf
J20_Unsteady Flow Calculations with a Parallel Multiblock.pdf
J21_Development and Validation of a Massively Parallel.pdf
J22_Stability of symmetric vortices in two dimensions.pdf
J23_Computation of Transonic Diffuser Flows.pdf
J24.pdf
J25_THREE-DIMENSIONAL STRUCTURES OF FLAMES.pdf
J26.pdf
J27_Stability of symmetric and asymmetric vortex pairs over slender conical.pdf
发表于 2005-7-30 10:16:00 | 显示全部楼层
[分享]刘峰老师的个人主页
不好意思,对刘锋老师不了解,能介绍一下吗?他的简历,尤其是他的研究方向和主要成果!谢谢
 楼主| 发表于 2005-8-3 16:35:48 | 显示全部楼层
[分享]刘峰老师的个人主页
去他主页上看啊,呵呵
发表于 2006-7-20 15:29:30 | 显示全部楼层
[分享]刘峰老师的个人主页
下面引用由zyzyeast在 2005/07/28 10:29am 发表的内容:
C18_Ignition and ...
发表于 2006-8-12 19:59:48 | 显示全部楼层
[分享]刘峰老师的个人主页
我们学校的特聘教授,他很牛,他导师更牛
发表于 2006-8-13 15:57:34 | 显示全部楼层
[分享]刘峰老师的个人主页
去他主页上看看,很么人啊
发表于 2006-8-24 20:42:49 | 显示全部楼层
[分享]刘峰老师的个人主页
的确很牛
发表于 2006-9-4 09:47:11 | 显示全部楼层
[分享]刘峰老师的个人主页
看看
发表于 2006-10-9 23:41:13 | 显示全部楼层
[分享]刘峰老师的个人主页
哦,是我校友啊,西工大的,呵呵,想老校友学习
