查看: 3682|回复: 10
请问Seast是否有Flow3D 8.2
发表于 2003-9-28 13:19:17 | 显示全部楼层 |阅读模式
据说增加了不少新功能
发表于 2003-9-28 20:11:23 | 显示全部楼层
目前没有,我找找,找到后会共享的。。。
发表于 2003-9-28 20:58:29 | 显示全部楼层
What's New in FLOW-3D® Version 8.2
In addition to several new and useful physical models, the multi-block grid coupling has been significantly improved and one of FLOW-3D®’s strengths, the VOF method for tracking fluid interfaces, has been enhanced. We’re calling it TruVOF®, because we feel our implementation is the truest form of that method there is.
And with Version 8.2, we’ve taken a big step forward in user-friendliness. Perhaps the most significant functional change for many users will be the new interactive, on-screen geometry and mesh creation capability we have built into the user interface.
What follows is a brief description of the key new features and changes to FLOW-3D® for Version 8.2.
  New VOF advection model -- TruVOF®. A new semi-Lagrangian VOF advection method has been implemented. The new VOF advection model has enhanced the ability of FLOW-3D® to track fluid interfaces in complex 3D flows. Go here for more information.
  Improved Multi-block coupling model. Stability, accuracy and efficiency of pressure-velocity coupling between mesh blocks has been greatly improved through the use of the Chimera multi-block method. The new method further widens the range of problems that can be tackled with FLOW-3D®, from large scale flows in civil engineering to casting to micro-electro-mechanical systems (MEMS). Go here for more information.
  Improved Graphical User Interface. FLOW-3D® now offers users the ability to interactively create and modify geometry and meshes using the FlowVu OpenGL-based visualization program.
  New Elastic-plastic stress model. A new elastic-plastic stress model has been developed for modeling materials having elastic properties. A yield stress may be defined to allow for plastic flow of these materials. Go here for more information.
  New Electro-osmosis model. A new electro-osmosis model, using a GMRES-based solver, has been implemented. Go here for more information.
  New Sand core blowing model. A brand-new model simulating the sand core blowing process has been developed Go here for more information.
New Two-Fluid model. A phase change has been added to the two-fluid model in the absence of free surface. Condensation/boiling can be initiated in situations when initially there is only vapor or fluid present.
New Implicit Shallow Water model. An implicit treatment of pressure forces has been added to the shallow water model. The addition eliminates the time-step stability limit associated with the explicit setting of the free surface pressure as a function of fluid depth and gravity.
New Individual Blade Effects. We have added a model for individual blade effects for fan-type rotating obstacles.
Improved Lost Foam Model. We have added a capability to have variable density foam patterns. Using a special scalar, the user can define how the foam density deviates from an average: a zero value of the scalar means no deviation. Go here for more information.
New Visualization Capabilities. An option has been added to the post-processor to allow the generation of iso-surfaces that are suitable for symmetry reflection for both Cartesian and cylindrical geometries. Users can also display particle data at the same time as fluid and obstacle iso-surfaces.
Improved Post-Processing. We have made the post-processor more robust by allowing it to continue data extraction when a requested variable is not found in the results file. This is even more useful for restart calculations. FLOW-VU has been made significantly more efficient in both speed and memory use. And the file size limit for results files has been increased on all platforms to up to 1,280 gigabytes (1.28 terabytes).
发表于 2003-11-15 18:10:02 | 显示全部楼层
算我一份!!
jackliucheng@yahoo.com.cn
发表于 2003-11-16 11:36:36 | 显示全部楼层
现在本版的ftp里有8。2了,这个版本我装的时候好像有点问题,你可以自己试试。如果没有其他选择,可以用来试试你的波浪问题。
发表于 2003-11-16 13:58:11 | 显示全部楼层
但是我总是只能看到本版FTP的欢迎信息,而看不到任何其他内容。
200 PORT Command successful.
COMMAND:>LIST
150 Opening ASCII mode data connection for /bin/ls.
STATUS:>Received 0 bytes, Abnormal termination
STATUS:>Trashed response received
426 Data connection closed, transfer aborted.
发表于 2003-11-16 14:13:31 | 显示全部楼层
你用的什么软件?设置了端口号吗?端口号2003,几乎没有人不能登陆的,除非你的网络受到当地限制,没有开通2003端口号。
发表于 2003-11-21 14:59:04 | 显示全部楼层
how to setup flow3d8.2
发表于 2003-11-21 15:20:47 | 显示全部楼层
i have not tried to setup it for my pc is doing some work important
发表于 2003-11-22 21:12:21 | 显示全部楼层
试了几次始终没成功,好像缺几个小文件,请seast证实一下
发表于 2003-12-25 19:36:59 | 显示全部楼层
我装完flow3d后,按帮助文件操作,导入工程"flow over a weir",点击"preview",提示:
SIGN= attribute required, but missing from license
This is probably because the license is older than the application
You need to obtain a SIGN= version of this license from your vendor.
Feature:       prep3d
Missing:       SIGN2=
License path:  C:\FLOW3D\licenses\flow3d.lic
FLEXlm error:  -114,526
available at "www.globetrotter.com".
为什么? 能帮我吗??给点建议也可以。
