查看: 22778|回复: 36
[导读] Traffic Flow Theory Glossary
发表于 2004-5-15 18:37:16 | 显示全部楼层 |阅读模式
[这个贴子最后由水寿松在 2004/05/15 07:23pm 第 1 次编辑]
Density——the number of vehicles occupying a road lane per unit length at a given instant.
Flow—— the number of vehicles passing a point per unit of time; often called volume when the time unit is one hour.
Gap—— the time interval between the passage of consecutive vehicles moving in the same stream, measured between the rear of the lead vehicle and the front of the following vehicle.
Headway—— the time interval between passage of consecutive vehicles moving in the same stream, measured between corresponding points (e.g. front bumper) on successive vehicles.
Interrupted Flow—— occurs when flow is periodically interrupted by external fixtures, primarily traffic control devices.
Jam Density—— the density when speed and flow are zero.
PHF (Peak Hour Factor)—— This describes the relationship between hourly volume and the maximum rate of flow within the hour: PHF = hourly volume/maximum rate of flow. For the 15 minute periods, PHF = volume/4 x (maximum 15 minute volume within the hour)
Shockwaves—— Shockwaves occur as a result of differences in flow and density which occur when there are constrictions in traffic flow. These constrictions are called bottlenecks. The speed of growth of the ensuing queue is the shockwave, and is the difference in flow divided by the difference in density.
Space Mean Speed—— the arithmetic mean of the speed of those vehicles occupying a given length of road at a given instant.
Spacing—— the distance between vehicles moving in the same lane, measured between corresponding points (front to front) of consecutive vehicles.
Speed—— the time rate of change of distance.
Time Mean Speed—— the arithmetic mean of the speed of vehicles passing a point during a given time interval.
Travel Time—— the total time required for a vehicle to travel from one point to another over a specified route under prevailing conditions.
Uninterrupted Flow—— occurs when vehicles traversing a length of roadway are not required to stop by any cause external to the traffic stream, such as traffic control devices.
Volume—— Traffic volume is the most basic and widely used parameter in traffic engineering, vehicles per mile, or vehicles per kilometer.
发表于 2004-6-22 23:20:15 | 显示全部楼层
我倒,上面的英文我怎么都不认识!初次来这里,请大家关照!
 楼主| 发表于 2004-6-23 00:00:08 | 显示全部楼层
个人以为英英解释的话更加可以增加理解,有些词汇非要翻译成汉语还是觉得有些不通顺的!
发表于 2004-7-19 21:09:53 | 显示全部楼层
与水寿松有同感,英文表达的有时很贴切,直接翻译的汉语有时实在很糟糕。比如说capacity应该是通行能力,珂很多人译为容量。应该作一下道路交通方面的概念标准化。顺便问一下,不知哪位有《通行能力手册》的电子版?求助!
 楼主| 发表于 2004-7-19 23:03:16 | 显示全部楼层
你是指《HCM2000》?很大的,下载比较麻烦,就没有要!
还是可以找到的!
 楼主| 发表于 2004-9-25 17:29:21 | 显示全部楼层
觉得有必要收集一些交通行业的英语术语翻译,为大家更好的学习提供一点帮助!
下面的跟帖是根据每个字母分类区分安排,以便阅读方便!
 楼主| 发表于 2004-9-25 17:29:46 | 显示全部楼层
Bit 钻头
Bit Per Second bps 每秒传输的位数
Bitumen 沥青
Bituminous Joint Fillers 沥青接缝填充料
Bituminous Material 沥青材料
Bituminous Overlay 沥青封层
Bituminous Pavement Road 沥青铺路
Bituminous Penetration Macadam 灌入式沥青路面
Bituminous Pressure Distributor 沥青压力散布机
Bituminous Sand Slurry 沥青沙浆
Bituminous Surface Treatment 沥青表面处理
Bituminous Water Proof Coating 沥青防水层
Bituminous Treated Base BTB 沥青处理底层
Bituminous Treated Sand Gravel 沥青处理砂砾
Black-Hole Effect 黑洞效应
Balance Cut and Fill 挖填之平衡
Blast 开炸
Blast Pad 喷气防护坪
Blasting Method 炸移法
Bleeding 路面冒油
Blight proof courses 病虫害防治
Blood alcohol concentration 血液中酒精浓度
Blown Asphalt 吹制沥青
Boiling 砂涌
Bonding Agent 黏着剂
Bore 钻凿
Bored pile 钻掘桩
Borehole 钻孔
Boring 钻探
Boring log 钻孔柱状图
Boring machine 钻机
Boring Rod 钻杆
Boring-core 钻孔岩心
Borrow 借土;借方
Borrow area 借土区
Borrow Pit 借土坑;取土坑
Bottle neck control 瓶颈路段(地点)管制法
Bottle Neck Road 瓶颈段;瓶颈路
Bottleneck 瓶颈
Bottom Course 底层
Bottom Flange 下翼绿
Boulder 卵石
Box caisson 沉箱;箱式沉箱;匣式沉箱
Box Culvert 箱涵;箱形涵洞
Box Drain 水沟渠;匣形沟渠
Box girder 箱形梁
Bracing 支撑
Bracket / Chassis 拖架
Brake failure, Defective brake 煞车失灵
Brake light 煞车灯
Brake Reaction time 煞车反应时间;制动反应时间
Braking Distance 剎车视距(停车视距)
Braking system 煞车系统
Branch and Bound Algorithm 分枝界定法
Breakdowns 故障
Breaking of Emulsion 乳化沥青黏结
Breaking Wave 碎波
Breakaway 脱离式接头
Breath alcohol concentration 呼气酒精含量
Brick Pavement 砖铺路面;砖铺面
Brick Pavement Road 砖铺路
Brick Road 砖面路
Bridge 桥梁
Bridge Abutment 桥台
Bridge Approach 桥粱引道
Bridge bearing 桥支承
Bridge deck 桥面板
Bridge deck/floor 桥面
Bridge expansion joint 桥面伸缩缝
Bridge floor 桥面
Bridge head 桥塔
Bridge inspection 桥梁检测
Bridge Management System 桥梁管理系统
Bridge pier 桥墩
Bridge railing 桥栏杆
Bridge span 桥跨
Brightness 照杜;辉杜;明亮度
Brightness contrast 辉度对照比
Brittle fracture 碎裂
Brittleness 脆性;脆度
Gravel Road 碎石路
Broken Stone Surface 碎石路面
Broken-back Curve 断背曲线
Broken-Beach Grade Line 破背坡度线
Benkelman Beam 彭柯曼梁
Buckling 挫屈;路面拱起
Budget 预算经费
Budgetary estimate 经费概算
Buffer 缓冲剂;缓冲器
Buffer buildings 缓冲建筑物
Buffer distance 缓冲距离
Buffer reach 缓冲段
Buffer time 缓冲时间
Buffer zone 缓冲带
Building Code 建筑规刖;建筑法规
Building Coverage Ratio 建蔽率;建筑面积比
Building Line 建筑线
Built-in Parking Facilities 建筑物附设停车空间
Bulb Type 球状
Bulk Density 虚松体密度
Bulk Specific Gravity 松比重;容积比重;虚比重
Bulkhead 隔墙;天窗;驳岸;隔舱
Bull Dozer 堆土机
Bulldozer 推土机
Bulldozer Blade 刮刀
Bullet-nose 弹头尖端式
Bullet-nose Form 弹头式
Bumper 保险杆
Bundle method 光束法
Bureau of Public Road (renamed to FHWA) 美国联邦公路局
Bus 大客车
Bus Bay 公车湾
Bus company 公车公司
Bus driver 公车驾驶员
Bus driving 公车运行
Bus Exclusive Lane 公车专用道
Bus fare 公车费率
Bus Lane 公车专用车道
Bus management information system 公车管理信息系统
Bus network 公车路网
Bus Operating Rate/Bus Dispatching Rate 出车率
Bus operation 公车营运
Bus operation management 公车营运管理
Bus parking area 大客车停车场
Bus Rapid Transit 公车捷运
Bus ridership 公车运量
Bus route 公车路线
Bus route inquiring system 公车路线查询系统
Bus scheduling 公车排班
Bus speed limits 公车速限
Bus station 公车停靠站
Bus stop spacing 公车站距
Bus Street 公车专用街道
Bus system design 公车系统设计
Bus system, Bus transit system, Public bus system 公车系统
Bus Terminal 公车终站;公车总站;公车场站
Bus transportation 公车运输
Bus, Public bus 公共汽车
Buses 大客革
Bush hammering 粗面石工
Business District 商业区
Business Vehicle 营业车辆
Bus-Kilometer 客车行驶里程
Busway 公车专用道
Butt Joint 平头接缝
Button reflector 反光钮
Buttressed Wall 外支墙
Buttressed Abutment 撑式桥台墙
Buttressed Retaining Wail 外支式挡土墙
Bypass highway 绕越公路
Bypass road 外环道
Bypass route 绕道路线
Bypass Street 绕越街
Bypassing Traffic 绕越交通
Bystreet 支街
 楼主| 发表于 2004-9-25 17:32:13 | 显示全部楼层
Cab Signal 车厢号志
Cab, Taxi 出租车
Cable Car, Cableway 空中缆车
Cable stayed bridge 斜张桥;斜索桥
Cable Suspension Bridge 索桥
Caboose 车务员专用车
Cadastral map 地籍图
Cadastral Survey 地籍测量
California Bearing Ratio CBR 加州乘载力比
Canal Aqueduct 输水桥
Canal Bridge 渠桥
Canal Tunnel 输水隧道
Cancellation 注销
Candle (Candle Power) Cd, Cp 单位:烛光
Cantilever Bridges 悬臂式桥梁
Cantilever method 悬臂工法
Cantilever retaining wall 悬臂挡土墙
Cantilever type retaining wall 悬臂式挡土墙
Cap 桩帽;雷管(俗)
Capacitated arc routing problem 容量限制弦路径车辆行驶问题
Capacitated freight distribution 零担货物运输
Capacity 容量;涵容性
Capacity analysis 容积分析
Capacity and level of service analysis 容量与服务水准分析
Capacity constraint, Capacity restriction 容量限制
Capacity estimation 容量估计
Capacity limitation 容量极限值
Capacity model 容量模式
Capacity of Bus Line 公车路线容量
Capacity reduction factor, Strength reduction factor 强度折减因子
Capacity utilization 容量使用率
Capillary Lift 毛管水升高度;毛细管水升高度
Capillarity 毛细管作用;毛细管现象
Captive Riders 无自由选择的乘客
Captive Transit Rider 大众运输固有使用者
Car accident, Traffic accident 交通事故
Car accreditation system 车辆认证制度
Car body 车体
Car detector, Vehicular detector 车辆侦测器
Car following model 跟车模式;自动跟车系统
Car navigation system 汽车导向系统
Car Ownership 汽车持有;汽车持有权
Car Pooling, Carpool 汽车共乘
Car, Vehicle 车辆
Carbon Dioxide CO2 二氧化碳
Carphone 车用电话
Car-Rental Carrier 小客车租赁业
Carriage 马车
Carrier wave 载波
Casing 套管
Cast stone 人造石
Cast-in-place pile 场铸桩
Cast-in-place (CIP) Concrete 场铸混凝土
Casualty 伤亡
Catalog Service Interface Specification 目录服务接口规范
Catch Basin 集水井;截流井
Catch Drain 排水沟;截水沟
Catch Feeder 灌溉水道
Cathodic method 阴极防锈法
Cationic Asphalt Emulsions 阳离子乳化沥青
Caution Light 警告灯
Caution Sign 警告标;警告标志
Caution Signal 注意信号;警告号志
Cavitations 孔蚀现象;穴蚀现象
Concrete Pavement 混凝土路面
Critical Speed 临界速率
Cement Grout 灌水泥浆;水泥灌喷枪
Cement grouting 水泥灌浆
Cement mortar 水泥砂浆
Cement Paste 水泥浆
Cement Treated Sand Gravel 水泥处理砂砾
Cencrete Cribbing 框式混凝土挡土墙
Census 普查
Center Frog k形岔心
Center Island 中央岛
Center Line 中线;中心线
Center Line Lane 中心车道;中央车道
Center Line Marking 中心标线
Center Platform (Island Platform) 岛式站台
Center Span 中央跨孔
Center(line) stake 中心桩
Centerline 中心线
Center-to-Center C2C 中心与中心
Center-to-Field C2F 中心与现场
Central Business District CBD 中心商业区
Central corridor system 中央走廊系统
Central Cross-Island Highway, East-West Cross-Island Highway 中横公路
Central Divider 中央分向岛
Central Island 分隔岛;中央岛;分向岛
Central Mixing Plant 中央拌合厂
Central projection 中心投影
Central Shopping area 中央商业区
Centralized Control System 集中式控制系统
Centralized Traffic Control CTC 中央行车控制法
Centrifugal force 离心力
Centrifuge Cup 离心杯
Centrifuge Kerosene Equivalent CKE 离心煤油当量法
Certification, Accreditation 认证;核准
Change License 换照
Change of Registration 变更登记
Changeable Message Sign, Variable Message Sign CMS 信息可变标志
Changeable Speed Limit Sign CSLS 速限可变标志
Changing Lane 变换车道
Channel 槽道
Channelized Intersection 槽化交叉
Channelization 槽化
Channelization island 槽化岛
Channelized Intersection 槽化式交叉;槽化路口
Channelizing Island 槽化岛
Channelizing Line 槽化线;检核点
Characteristic Deflection 代表性挠度
Character arrangement 文字排列方式
Character size 文字尺寸
Charging system 收费系统
Charter Bus 专用游览车
Check Point 检核点
Check Valve 逆止阀
Chemical grouting 药液灌浆
Chevron of divergence 分流式山形条纹
Chevron of mergence 并流式山形条纹
Chevron strip 山形条纹
Chief Engineer 总工程司
Child pick-up area 家长接送区
Children-only Bus 幼童专用车
Chinese road sign 中文道路标志
Chord 弦;弦杆
Chord Length 弦长
Chute 竖槽;陡槽;吊沟
Circle 周期
Circle/Roundabout 圆环
Circuit 环道(测);电话(电)
Circuit-switched Public Data Network CSPDN 线路交换公众数据网络
Circular Arch 圆拱;弧拱
Circular Curve 圆曲线;单曲线;圆弧曲线
Circular failure 圆弧型破坏
Circular green light 圆形绿灯
Circular rod level 圆盒水准器
Circular sliding surface 圆弧滑动面
Circulation 通风;交通
Circulation Map 交通图
Circulation system 转乘系统
Circumferential street (road) 外环(环状)道路
City Bus 市区公共汽车
City Planning 都市计画
City Planning Commission 都市计画委员会
City Planning Law 都市计画法
City Rebuilding 都市重建
City Transit 都市大众运输
Clamshell 抓式挖土机
Classification Count 分类调查
Classification of road 道路分类
Classification of Soil 土壤分类
Clear distance 净距
Clear height 净空高
Clear Span 净跨距
Clear Zone 清除区
Clearance 净距
Clearance Height 净高
Clearance Lost Time 清道损失时间
Clearance time 清道时间
Climate Conditions 气候情况
Climbing Lane 爬坡道.爬坡车道
Clinker 溶块
Close Network 封闭网络
Close System Toll Station 封闭制收费站
Close Tunnel 隧道区
Closed Circuit Television Camera CCTV 闭路电视摄影机
Closed Loop 封闭环路
Closed Network 网络系统
Closed traverse 闭合导线
Clothoid Curve (Clothide) 螺旋曲线;克罗梭曲线;罗线形曲线
Clover Leaf Interchange 四叶形交流道;苜蓿叶形交流道
CO Detector 一氧化碳侦测器
Coarse Aggregate 粗粒料;粗骨材
Code 规范;数值
Coefficient of friction, Friction coefficient, Frictional coefficient 摩擦系数
Coefficient of Kinenatic Viscosity 动黏滞系数
Coefficient of kurtosis 峰度系数
Coefficient of Side Friction 侧犘擦系数
Coefficient of Subgrade 路基抗力系数
Cofferdam 围堰
Coefficient of Utilitization CU 照明率
Cohesion 凝聚力;黏力;黏结力
Cohesion of soil 土壤之凝聚力
Cohesive value 凝聚值
Cold-Mix Asphalt Concrete 泠拌沥青混凝土
Collector Ditch 集水沟
Collector Road 连络道路
Collector Street 联络道路
Collector-distributor Roads 集散道
Collision 冲撞;碰撞
Collision Accident 碰撞事故
Collision area 碰撞区
Collision diagram 碰撞图;相横示意因
Collision Warning Systems 碰撞预警系统
Color Light Signal 色灯号志
Color contrast 色彩对比
Color quality 光色品质
Combination Truck Tractor-trailer 联结车
Commercial Center 商业中心
Commercial District 商业区
Commerical Driver's License CDL 大型车辆驾照(16人以上)
Commercial Fleet Management 商用车队管理
Commercial Motor Vehicle CMV 商业用车
Commercial Speed 商业运转速率
Commercial Traffic 商车交通量
Commercial Vehicle Electronic Credential Management 商用车辆电子凭证管理
Commercial Vehicle Operating System 商用车营运系统
Commercial Vehicle Operations CVO 商车营运系统
Commercial Vehicle Operations Services CVOS 商车营运服务
Commodity 商品
Community Center 杜区中心
Community Planning 社区规画
Commuter 通勤者
Commuter Rate 回数费率
Commuter Rail, Commuter Train 通勤火车
Commuting Distance 通勤距离
Compacted Subgrade 压实路基
Compaction 夯实;压实
Compaction effort 夯实能量
Compatibility 兼容性
Compensation 征收补偿
Compensation for Damage 损失赔偿
Compensation for the land price 地价补偿
Complementary Route 补充路线
Complex intersection 复合适交叉路口
Composite Beam 合成粱;复合粱
Composition of Traffic 交通组成
Compound Curve 复曲线
Comprehensive 整体性
Comprehensive parking program 综合性停车计画
Comprehensive Planning 综合性计画
Compressibility of Soil 土壤压缩性
Compression 压缩;压力
Compression Stress 压应力
Compressive Strength 抗压强度
Compulsory Purchase 征收
Computer signal 计算机号志
Computer signal lamp system 计算机号志系统
Computer-Aided Dispatching System 计算机辅助派车系统
Computerized traffic signal system 计算机化号志系统
Concave 凹
Concave Bank 凹岸
Concave curve 凹形曲线
Concave Joint 四缝
Concave-convex 凹凸形
Concentrated load 集中荷重
Concentration time 集流时间
Concentric opposed plane helical ramp 同心反向螺旋状匝道
Concrete 混凝土
Concrete barrier (New Jersey) 纽泽西(混凝土)护栏
Concrete islands 混凝土交通岛
Concrete joint 混凝土接缝
Concrete Mixing 混凝拌合机
Concrete Overlays 混凝土路面加铺
Concrete pavement 混凝土铺面
Cone 交通锥
Cone of acute vision 明晰视锥角
Cone of glance area 瞥视锥角范围
Cone of sight 视锥角
Conflict 冲突
Conflict analysis 冲突分析
Conflict Area 冲突区域
Conflict lane change 冲突性变换车道
Conflict management 冲突管理
Conflict point 冲突点
Congestion 拥挤
Congestion degree 拥挤度
Congestion delay 拥挤延滞
Congestion dummy variable 拥挤虚拟变量
Congestion pricing 拥挤定价
Congestion Time 拥挤时间
Congestion toll 拥挤费
Conical Surface 圆锥面
Connecting Road 连络公路
Connector 连接道路
Consistency 稠度
Consolidation 压实;固结;压密
Consolidation Rate 压密率
Construction Contract 工程合约
Construction Joint 施工接缝
Construction Load 施工道路
Construction Planning 施工计画
Construction Sign 施工标志
Construction Specification 施工规范
Construction/Maintenance Zone 施工维修区
Contact detector 接触式侦测器
Contact strip 接触带
Container Packing Shed 货柜并装通栈
Container parking area 联结车停车场
Container Trucking Carrier 货柜运输业
Continuous Mixing Plant 连绩式拌合厂
Continuous move-up operation 连续跟进行为
Continuous Station 长期观测站
Continuous Volume-count Program 长期持续**通量调查
Continuously reinforced concrete pavement CRCP 连续钢筋混凝土路面
Continuous-Mix Plant 连续式拌合厂
Contour Interval 等高线间隔;等高距
Contour Line 等高线
Contour Map 等高线图
Contours 等高线
Contract 契约
Contract Change Order 契约变更通知
Contraction Joint 收缩接缝
Contractor 承包商
Contraflow bus lane 逆向公车专用道
Contributing area 集水面积
Control Count 控制量交通调查
Control of Access 出入管制
Control point comparison 控制点比较法
Control points 控制点
Control Radius 控制半径
Control section 管制路段
Control span 控制限制
Control Station 控制站
Control strategy, Regulation strategy 管制策略
Control survey, Control surveying 控制测量
Controlled Access Highway 出入管制公路
Controller 控制器
Controlling Load 控制轮重
Convenience store 贩卖区
Conventional Roundabout 传统圆环
Conventional Simulcast Radio System 同频发射共波式无线电话系统
Converted traffic 转乘交通量
Convex Function 凸函数
Convex Joint 凸接缝
Conveyer 输送机
Conviction 违规
Convoy 车队
Cooperative Planning 合作规划
Coordinate scheduling 协调排班
Coordinated control 连锁控制
Coordinated Control Signal 连锁控制号志
Capital Cost 公路资本
Cordon Count 周界交通量调查;内圈交通量调查
Cordon Line 区域线;周界线
Corridor 交通通廊
Corridor Control 通廊控制
Cost of Service 服务成本
Count-down pedestrian signal 行人倒数计时显示器
Counter flow 对向车流
Counter map 等量线图
Counter Wall 等高线
Country road 乡道
Courier service 快递服务
Covered Conduit 暗渠
Covered Ditch 加盖暗沟
Crack Spacing 裂纹间距
Crash 冲撞;碰撞
Crawling lane 爬坡道
Creep 潜变
Crest Vertical Curve 凸形竖曲线
Crew scheduling 人员排程
Crib retaining wall 框条式挡土墙
Critical bottleneck 关键瓶颈
Critical gap 临界间距
Critical Length of Grade 披道临界长度
Critical Path 要径
Critical Path Method CPM 要径法
Critical Point 临界点
Critical rate of flow 临界流率
Critical Slope 临界坡度
Critical speed 临界速度
Critical Zone 临界区
Crop 露头
Cross road 十字路口;交叉路;十字路
Cross Section 断面;横断面;截面
Cross Slope 横向坡度
Cross walk 行人穿越道
Crossing 穿越
Crossing facility 穿越设施
Crossing maneuver 交叉穿越运行
Crossing point 交会点
Crossing rate 穿越率
Crosswalk Line 行人穿越道线
Crowding 拥挤
Crown 路拱;路冠
Crown Ditch 坡顶截流沟
Crown line 路拱线
Crude Oil 原油
Cruise control 自动控速
Crusher 碎石机
Cubic Parabola 二次拋物线
Cul-De-Sac 死巷
Culvert 涵洞;箱涵
Curb 缘石;路边石;护角
Curb Bus Lane 设于路缘之公车专用车道
Curb ditch 路缘浅沟
Curb inlet 路缘进水口;绿石进水口
Curb Lane 缘侧车道;路缘车道
Curb Line 路边线
Curb Loading Zone 沿路载货区;路旁装卸地带
Curb Marking 缘石标线
Curb parking 路边停车(场)
Curb ramp 缘石坡道
Cure 养治
Curing 湿治;养护
Curing age 养护材龄
Curing compound 养护剂
Curing Room 养护室;保养室
Current Traffic 当时交通量;现有交通量
Curvature 曲度;曲率
Curve 曲线;曲线板;弯道
Curve Path 曲线路线
Curve, Bend 弯道
Curved Bridge 曲线桥
Cushion material 缓冲材料
Cushioning effect 缓冲效应
Cut 挖方
Cut and cover method 明挖覆盖法(隧道)
Cut and Fill 挖填(动词);挖方和填方(名词)
Cut-Back Asphalt 油溶沥青
Cycle 周期
Cycle Expansion/Contraction 周期增长缩短法
Cycle slips 周波脱落
Cycle Time 周期时间
Cyclic scheduling 循环排班
发表于 2004-9-25 18:30:41 | 显示全部楼层
Daily Rainfall 日雨量
Daily time pattern 每日时态
Daily Traffic 日交通量
Daily variation diagram 日变化图
Datum 基面
Datum mark 基准点
Datum Level 基准面
Datum Line 基准线;基准面
Datum Place 基准面
Day Light Signal 日光式号志;灯光式号志
Day Work System 日工制;点工制
Daylight illumination 日光照明
Dense-Graded Asphalt Concrete DGAC 密级配沥青混凝土
Debris 漂流物;碎片
Debris flow 土石流
Debris hazard 土石灾害
Deceleration 减速度
Deceleration force 减速力
Deceleration lane 减速车道
Decentralize, Multilevel Control System 分布式多层控制系统
Decision sight distance 反应视距
Deck 版
Deck Floor 桥面
Deck Truss 面层式
Deep excavation 深开挖
Deep well method 深井法
Default 违约(动词)
Default value 内设值
Deflection 变位;挠度
Deflection angle 倾斜角
Deflection inclinometer 倾斜仪
Deformation 变形
Deformed Bar 竹节钢筋
Deformed Plate 弯曲钣
Deformed Plate Joint 曲板接缝
Defrosting 解冻
Degree of brightness 辉度水准;照度水准
Degree of Compaction 压实度
Degree of Congestion 拥塞度
Degree of curvature 曲度
Degree of loading 负荷度
Degree of Saturation 饱和度
Delay 延迟;迟延
Delay duration 延滞持续时间
Delay in queue 等候延滞
Delay in system 系统延滞
Delay model 延滞模式
Delay rate, rate of delay 延滞率
Delay study 延滞研究
Delay timer 延滞定(对)时器
Delineators 反光导标
Delivery area 卸货区
Delivery system 配送系统
Delivery time 递送时间;送货时间
Demand Curve 需求曲线
Demand Response, Dial-a-Ride 拨召车辆
Demand volume 需求流量
Demand-Capacity Control 需求容量控制
Demand-supply of parking spaces 停车空间的供需问题
Demographic Data 人口资料
Dense Grade Asphalt Concrete DGAC 密级配沥青混凝土
Dense-Graded Aggregate 密级配粒料
Density 密度
Density of Traffic 交通密度;车流密度
Density of volume 流量密度
Department of Transportation DOT 运输部
Departure Headway 纾解间距
Departure rate 离开率
Dependent signal control 相依号志控制
Depot 检修处
Depth Factor 深度因子
Design Capacity 设计容量
Design Controls and Criteria 设计控制与标准
Design curve 设计曲线
Design Designation 设计要件
Design frequency 设计频率
Design Hourly Volume DHV 设计小时交通量
Design Lane 设计车道
Design Level of Service 设计服务水准
Design of Concrete Mix 混凝土配合设计
Design Period 设计年限
Design Period Adjustment 设计年限之校正系数
Design rule 设计法则
Design Speed 设计速率
Design Structure Number 铺面设计结构数值
Design Subgrade Strength 设计路基强度值
Design Thickness 设计厚度
Design Traffic Number 设计交通当量
Design vehicle 设计(用)车辆;设计车型
Design Wheel Load 设计轮重
Design year 设计年
Desire Line 旅次需求希望线;愿望线;期望路线
Desire line chart 愿望线图
Desire speed 愿望速率
Desired Design Period 拟定之设计年限
Destination 目的地
Destination zone 讫点区
Detector 侦测器
Deterring semibarrier 制止作用的半高式栅栏
Deterioration 变质;恶化
Deterministic Delay 固定延滞
Deterministic Model 定值模式
Detour 便道
Deviation 偏位
Device 设备
D-factor D-因素;方向因素
Diagonal crosswalk lines 班马纹行人穿越道
Diagonal Parking 斜式停车道
Diagrammatic map 示意图
Dial 标度盘;刻度盘
Dial a ride 拨召服务
Dial Gauge 测微表
Dial-a-Ride, Demand Response 拨召车辆
Diamond bit 钻石钻头
Diamond Interchange 茭形交流道;钻石型交流道
Diamond Lane 划钻石标记的车道(给高乘载车辆使用)
Diamond or parallel ramp 钻石型或平行匝道
Diaphragm wall 地下连续壁
Diatom 道线
Diesel Fuel 柴油
Diffuse 扩散
Digital image processing 数字影像处理
Digital Map 数字地图
Digital terrain model 数值地形模型
Digital topographic map 数值地形图
Dilemma zone 疑虑判断区;犹豫区间;两难
Dining area 餐饮区
Dip 倾斜
Dip slope 顺向坡
Direct bus 直达公车
Direct connection 直接连结式
Direct Illumination 直接照明
Direct path 直接行径
Direction Factor 方向系数
Direction Line 指向线
Directional Angles 方向角
Directional Distribution 方向分布
Directional Interchange 直接式交流道
Directional island 导向槽化岛;导向岛
Directional Sign 方向标志
Directional With Loops 附有圈道之直接交叉型
Disabled parking lots 残障停车位
Disabled toilet 残障厕所
Disabling Injury 残障性伤害
Discharge 流量
Discharge Area 流量面积
Discharge Measurement 流量测量
Discharge Rate 流出率
Discomfort glare 不适眩光
Dispatching 派车问题
Dispatching efficiency 调度效率
Dispatching of duty 勤务派遣
Dispersed network equilibrium 分散路网均衡
Dispersion 离差;离散
Displacement 位移;变位
Displacement Dial Indicator 位移测微表
Display Panel 显示面版
Disposal area 弃土区
Distance 距离
Distance based fare 里程费率
Distance change 距离变化
Distance error 距离误差
Distance Post 里程标
Distance test 距离测试
Distance-Measuring Equipment DME 测距仪
Distress severity 破坏严重程度
Distress survey 损坏调查
Distributed Control System 分布式控制系统
Distribution 配销
Distribution center 配运中心
Distribution center, Goods distribution center 物流中心
Distribution channel 流通通路
District 小区
District Engineer 工程处处长
Disutility 负效用
Ditch 边沟
Ditching Machine 挖沟机
Diverging 分流
Diverging area 分流区;分流区域
Diverging conflicts 分流冲突点
Diverging point 分流点
Diversion flow 分道车流
Divided Highway 分隔式公路
Divided Road 分隔式道路
Dividing Strip 分隔带
Divisional island 分向岛;分向槽化岛
Divorce 分开
Do not cross 禁止跨越
Do not enter 车道禁止进入;不准进入;请勿进入
Do not enter sign 禁行方向标志
Document Type Definition 文件型态定义
Domain Expert 领域专家
Domestic 本土的;区域的
Door to door service 及门服务;及户服务
Dot marker 圆点标物
Double decked bus 双层巴士
Double Opening 双开孔
Double parking 并排停车
Double Y type 双Y式
Double-deck ramp 双层匝道
Double-decked Bus 双层公车
Dowel Bar 缀缝筋;接缝钢筋(横向)
Down Grade 下坡
Down Slope 卸坡
Downgrade Ramp 下坡匝道
Downhill Grade 下坡
Downstream 下游
Downstream section 下游段;下流段
Downtown street 闹市街道
Dozer 推土机
Dr. Sun Yat-Shen Highway, Sun Yat-Sen National Freeway 中山高速公路
Drafting 绘制;绘图
Drafting Room 制图室
Draftsman 绘图员
Dragline 扒土机
Drain Ditch 排水沟
Drain Pipe 排水管
Drainage 排水
Drainage pavement 排水性铺面
Drainage Basin 流域
Drainage Channel 排水渠
Drainage Coefficient 排水系数
Drainage Ditch 排水沟
Drainage Facilities 排水设施
Drainage Pavement 排水铺面
Drainage Pipe 排水管
Drainage System 雨水沟系
Drawbar Pull 拉杆牵引力
Drawing Interchange File 图形交换文 件
Drawings 图说
Dredging 浚渫
Driven pile 打击桩
Driver 驾驶人
Driver behavior model 驾驶者行为模式
Driver behavior, Driving behavior 驾驶行为
Driver characteristic 驾驶员特性
Driver Expectancy 驾驶人期望
Driver Information System 驾驶信息系统
Driver Perception Reaction Distance 驾驶人反应距离
Driver Reaction Time 驾驶人反应时间
Driver training circuit 驾驶训练班
Driver's License 汽车驾驶执照;汽车驾照
Driver's vision 驾驶人视觉
Driveway 私用进出车道
Driving Behavior 驾驶行为
Driving Cycle 行车型态
Driving environment 驾驶环境
Driving pattern 行车型态
Driving power 行进动力
Driving rod 传动轴
Driving school 驾训班
Driving school training vehicles 教练车
Driving Simulator 驾驶仿真器
Driving Skill 驾驶技能
Driving test 路试;桩试
Driving under the influence of alcohol 酒后驾驶
Dropping Weights 落锤式夯压机
Drum Mix Plant 鼓式拌合厂
Drunk driving enforcement acts 酒醉驾驶取缔法
Dual Left Turn 双向左转
Dual mode bus 双用途公车
Ductility 延展性
Dumper 倾卸车
Durability Test 施工测量
Duration 持续期间;延时
Duration curve 延时曲线
Duration of lane change operation 变换车道作业的延时
Dynamic characteristics 动态特性
Dynamic Information Subsystem 动态信息次系统
Dynamic route choice 动态路径选择
Dynamic route guidance 动态路径导引
Dynamic route switching 动态路径变换
Dynamic Segmentation 动态分段
Dynamic signal control 动态号志控制
Dynamic system-optimum control model 动态系统最佳控制模式
Dynamic timing computation 动态时制计算
Dynamic traffic characteristic 动态交通特性
Dynamic traffic signal control 动态交通号志控制系统
I'm all out of love;
I'm so lost without you;
What am i without you.
发表于 2004-9-25 18:36:07 | 显示全部楼层
Early age strength of concrete 混凝土早期强度
Early cut-off period 早闭(关)时段
Earth Embankment 土堤
Earth Excavation 挖土
Earth Fill 填土
Earth slide 地滑
Earth structure 土工结构物
Earth Wedge 土楔
Earth Work 路基土石方
Earthflow 泥流;土流
Earthquake 地震
Earthwork 土石方工程;土方
Easement or Transition Curve 渐曲线
East-West Expressway 东西向快速公路
Ecological Engineering Methods 生态工法
Economic benefits analysis 经济效益分析
Economical Haul 经济运距
Economy on Quantity of Haul 经济运量
Effect of depth 深度效应
Effective contrast ratio 有效对照比
Effective Diameter of Voids 有效孔隙粒径
Effective Green Time 有效绿灯时间
Effective Normal Stress 效正应力
Effective red (green) time 有效红(绿)灯时间
Effective Specific Gravity 有效比重
Effective unit weight 有效单位重
Effective width 有效路幅宽度
Effectiveness 有效度
Effluent 放流口;出流水
Eighty-fifth Percentile Speed 85百分位速率
Elastic Deformation 弹性变形
Elastic equilibrium 弹性平衡
Electric Lighting 照明
Electric motorcycle 电动机车
Electric public bus 电动公共汽车
Electric room 电气室
Electrical contact 电动侦 测器
Electrically operated meter 电动运转表
Electrodynamics Suspension EDS 电动悬浮
Electromagnetic Suspension EMS 电磁悬浮
Electromechanical 机电式
Electronic decade meter 电子十进(分)位表
Electronic distance measurement instrument 电子测距仪
Electronic gate 电子门;电动门
Electronic theodolites 电子经纬仪
Electronic Toll Collection 电子收费
Element 单元;元素;要素
Elemental maneuver area 基本运行区 域
Elemental weaving section 基本的交织段长度
Elevated Highway 高架公路
Elevated observer method 居高观测(察)法
Elevated rail bridge 高架桥
Elevation 标高;高程
Elevation above mean sea-level 平均海水面
Elevator 电梯
Elimi nation of off-set leg 错 开 车 道 的 消 除
Elongated area 延伸区域
E-map of highway 公路电子地图
Embankment 路堤
Embedded Depth 浸没深度
Emer gency 急 难;紧 急 事 故
Emer gency delivery 紧 急 输 送
Eme rgency Escape Ramps 紧 急 出 口 匝 道
Emer gency evacuation 紧 急 疏 散
Emer gency Management Services EMS 紧 急 事 故处 理 服 务
Emer gency Notification 紧 急 事 故 通 告
Emer gency response 紧 急 应 变
Emer gency road 紧 急 道 路
Emer gency service delivery 紧 急运送服务
Emer gency telephone 紧 急 电 话机
Emer gency Vehicle Management 紧 急 救 援 车辆管 理
Eminent Dom ain 地征收权
Emotion or judgment 激 发 情 绪或判 断
Employee 员 工
Employee buy-out 员 工 买 断
Employer 雇 主
Emulsified Asphalt 乳化沥肯
Emulsified Asphalt slurry 乳化沥青砂浆
Enabling act 权 能 附 与 方 案
Enabling law 权 能 附 与 法 -令
Encr oachm ent line 侵 线
End of Curve E.G. 曲线终点
End-Area Method 平均底面积法
Energy dis sipater 消能器
Enfor cem ent 执 法;执 行
Engine resist ance 引擎阻力
Engineering 工 程
Engineering Economic Analysis 工程经济分析
En-Route Driver Information 旅行中驾驶信息
En-Route Transit Information 行程中大 众运输信息
Entity 实 体
Ent rance 入口
Ent rance (entry), ingress 进口路段
Ent rance curve 进口曲线段
Ent rance Loss 入口损头
Entr ance ramp 入口匝道
Entr anc e-exit 出入口
Entry der egulation 放 宽 进 入 管 制
Envelope of fa ilure 破 坏 包 络 线
Environment factor 环 境 因 素
Environment Traffic Light 环境交通标志
Environmental impact assessment 环境影响评估
Environmental quality 环 境 品 质
Environmental quality standards 环境品 质标准
Environmental sensitive area 环境敏 感地带(环 境 敏 感 区 位)
Environmental sound volume criteria 环境音量标准
Epoxy Resin 环氧树脂
Epoxy Adhesive 环氧胶
Equilibrium network flow 均衡路网流量
Equipment Package 设备组合
Equival ent detectablity 等量察觉性
Equival ent Factor 当量因子
Equival ent-injury-only EIO 受 伤当量
Equivale nt Single Axle Load ESAL 单轴载重当量数
Equivalent Wheel Load EWL 轮荷重当量
Erosion control 侵 蚀控制
Err or of Closure 闭合差
Escalator 电扶梯
Ethanol 酒精
Euler Spiral 尢拉螺旋线
Eutrophication 优养化
Event Data Recorder EDR 事 故 资 料 纪 录 器
Excavation 开挖;挖方;挖掘法
Excavation Work 挖土工程
Except buses 公车除外
Excess capacity 超额容量
Excess Fuel Consumption 超额燃油消耗
Exclusive bike lane/Bikes only 脚踏车专 用道
Exclusive bus lane 公车专 用道
Exclusive Highway 专 用公路
Exclusive lane 专 用车道
Exclusive Motorcycle Lane 机车专 用道
Exclusive Right-of-Way 专 用路权
Exclusive Road 专 用道路
Exclusive telephone 专用电话机
Exhi b it area 展 示 区
Exit 出 口
Exit curve 出 口曲线段
Exit Lane 出 口车道
Exit Only Ticket 出站车票
Exit Ramp Closure 出 口匝道关闭
Exit Ramp Control 出 口匝道控制
Exit Ramp Metering 出 口匝道仪控
Exit Taxiway 出 口滑行道
Exit-ramp 出 口匝道
Expanded Average Daily Trucks 膨胀之平均每日货车交通量
Expansion 扩展
Expansion Cap 伸缩帽
Expansion Factor 膨胀因素;扩展系数
 楼主| 发表于 2004-9-26 12:57:08 | 显示全部楼层
Glance value 瞥见距离之远近
Glare 眩
Glare control 眩光控制
Glare recovery 眩光消除
Glare recovery time 眩光消除时间
Glare screen 防眩设施
Glare shield 眩光遮蔽物
Glare vision 眩光视觉
Glass Funnel 玻璃漏斗
Global Positioning System GPS 全球定位系统
Global System for Mobile Communication GSM 泛欧式数字行动电话系统
Goal 目标
Goal Driven 目标驱动法
Goods delivery problem 货物配送问题
Gordon Ray 雷伊
Government-owned Public Parking Facility 公有公共停车场
Gradation Curve 级配曲线
Grade 坡度;纵向坡度
Grade Crossings 平面交叉
Grade I Road 一级路面
Grade Line 坡度线
Grade resistance 坡度阻力
Grade Separation 立体交叉
Grade separation bridge 立体交叉桥(结构物)
Grade Separation Structure 立体叉结构
Graduated Rate 累计费率
Grain size analysis 粒径分析
Grants 政府奖助
Granular Materials 粒状材料
Graphical analysis 图解分析法
Gravel 砾石
Gravel Equivalent Factor 卵石当景因素
Gravel Road 砾石路
Gravity Model 重力模式
Gravity Yard 重力调车场
Green Arrow 箭头绿灯
Green/cycle ratio G/C 绿灯时间与号志周期之比值
Green Extension 绿灯延长时间
Green Flashing 闪光绿灯
Green wave signal design 绿波式号志设计
Greenhouse effect 温室效应
Groove Joint 槽形接缝
Gross National Product GNP 全国总生产毛额
Gross Vehicle Weight GVW 总重
Ground 地;地面
Ground control point 地面控制点
Ground improvement 地盘改良
Ground treatment 地基处理
Groundwater level 地下水位
Group 群组
Grouting 灌浆
Growth Factor 成长因素
Guardrail 护栏
Guidance 导引
Guidance information 导引信息
Guide 导引
Guide line 导引线
Guide Sign 指示标志
Gully control 蚀沟控制
Gussasphalt 高温沥青胶浆
Gutters 水沟
 楼主| 发表于 2004-9-26 12:57:24 | 显示全部楼层
Half-Integer Synchronization 半整数同步相位
Hand in for Cancellation 缴销
Hangar Marker 维护棚厂标记
Hazard marker 危险标物
Hazardous materials 危险物品
Head (of water) 水头
Head light 前灯;车前大灯
Head On Collision 车头对撞
Head Section 头区
Head Sight Distance 车灯视矩
Head Wall 端墙
Header Board 横梁板
Heading, Pilot tunnel 隧道导坑
Headlight Sight Distance 车灯视距
Head-on collision 对撞;正撞
Headwater Depth 上水深
Headway 时间车距;班距;行进间距(车距)
Headway distribution 班距分布
Headway Elasticity 班距弹性
Headway, Period 班距
Hearing 听力
Heaving 隆起
Heavy Commercial Vehicle Safety Management 重车安全管理
Heavy Motorcycle 重型机踏车
Heavy duty truck 重型卡车
Heavy weight transportation management 大载重运输管理
Heel of Switch 转辙轨跟端
Heel Spread 跟端展距
Height limit 高度限制
Heuristic Approach 推理方法
Hidden-Dip 躲坑
High beam 远光灯
High capacity buses 高容量巴士
High Data Rate Digital Subscriber Line HDSL 高速数字用户回路
High decked bus 高层巴士
High oblique photography 平倾斜摄影
High Occupancy Vehicle HOV 高乘载车辆
High Occupancy Vehicle (HOV) Lane 高乘载车道
High or direct gear 高速檔
High Truss With Overhead Lateral Connections 高顶式
High type 高级型
High-mast Lighting 高杆多灯式照明设计
High-Occupancy Vehicle Priority Control 高承载率车优先行驶控制
High Speed Rail 高速铁路
Highway 公路
Highway (or street) lighting 公路(或街道)照明
Highway Advisory Radio HAR 公路路况广播
Highway aesthetics 公路美学
Highway alignment design 公路线形设计
Highway bridge 公路桥梁
Highway Bus Carrier 公路汽车客运业
Highway bus industry 公路客运业
Highway Capacity Manual HCM 公路容量手册
Highway Capacity 公路容量
Highway construction 公路施工
Highway Construction and Maintenance Cost 公路建设维护成本
Highway database 公路数据库
Highway Density 公路密度
Highway embankment 公路路堤
Highway engineering, Road engineering 公路工程
Highway geometry, Highway routing 公路路线
Highway Guardrail 公路护榈
Highway information 公路资料
Highway information system 公路信息系统
Highway interchange area 交流道地区
Highway Intersection 公路交叉
Highway maintenance 公路维修与养护
Highway passenger vehicle 公路客车
Highway performance 公路绩效
Highway Performance Monitoring System HPMS 公路绩效监测系统
Highway planning 公路规划
Highway ramp 公路匝道
Highway Research Board (Renamed to be
Research Board) HRB 美国公路研究委员会
Highway service standard 公路服务水准
Highway Supervision and Administration Statistics 公路监理统计
Highway surveillance 公路调查
Highway Transit 公路大众运输系统
Highway Transportation Statistics 公路运输统计
Highway transportation, Road transportation 公路运输
Highway Travel Time Survey 公路行驶时间调查
Highway Type 公路之型式
Highway, Road 公路
Hiking trail design 健行步道设计
Hill land, Hill slope, Hillslope, Slope, Slope land, Slopeland, Sloping land
Hinterland 腹地
Histogram 直方统计图
Hit-and-run driving 肇事逃逸;闯祸逃逸
Holding Line Marker 等候线标记
Home interview 家庭访问
Home-Based Trip 旅次
Hook-Headed Spike 钩头道钉
Hopper 进料斗
Horizontal Alignment 平面线形
Horizontal angle of the cone of vision 水平视锥角
Horizontal Clearance 侧向净宽
Horizontal control surveys 平面控制测量
Horizontal Curve 平曲线
Horizontal drain pipe 水平排水管
Horizontal Marking 横向标线
Host 主机
Hot-Mix Asphalt Mixture HMA 热拌沥青混凝土
Hourly variation 时变化图
Household trip 旅次
Human characteristics 人类特性
Human factor 人为因素;人事行为因素
Hydroplaning, Aquaplaning 水滑作用
Hydrophilic 亲水性
Hydrophobic 厌水性
 楼主| 发表于 2004-9-26 12:57:44 | 显示全部楼层
Ideal Condition 理想状况
Illegal parking 违规停车
Illumination 照明;明亮度;照度
Illumination, Lighting 照明
Image 影像
Image element, Picture element, Pixel 像素;像元;像点
Image geometry 影像几何
Impact 冲击
Impact energy 撞(冲)击能量
Impact resistance 冲击阻力
Improvement plans 改善计画
Improving Highway Traffic Order and Safety Projects 道路交通秩序与交通安全改进方案
In-Band-Adjacent-Channel IBAC 带内邻频
In-Band-On-Channel IBOC 带内同频
In Kind, Match Fund 配合款
Inbound 往内方向;进城;驶入
Incident 事件
Incident Management 事件管理
Inclinometer 倾斜仪
Incremental Delay 渐增延滞
Incremental launching method 节块推进工法
Indemnity of Damage 损害赔偿
Intensity of Rainfall 雨量强度
Index 指针
Index system 索引系统
Index system, Indicator system 指针系统
Indigenous 原著民的;本土性
Indirect observation 间接观测
Individual Communication Subsystem 个别通讯次系统
Individual difference 个人禀性的差异
Individual spot 独立点
Induced Coil 感应圈
Inductive loop Detector 环路线圈侦测器
Inductive Receiver 感应收讯器
Inertia resistance 惯性阻力
Information center 服务台
Information Flow 信息流
Information Level 信息层
Information Management Services IMS 信息管理服务
Information sign 指示标志;信息标志
Information Sign/Guide Sign 指示标志
Infrared Beacon 红外线信号柱
Infrastructure 内部结构;基础建设
Initial Cost 初置成本
Initial Daily Traffic 初期每日交通量
Injury 伤害
Injury rate 受伤率
Inlet 集水口
Inlet Control 进口控制
Inlet Time 流入时间
Inner lane 中心车道
In-situ 现地
Inspection of Vehicle 汽车检验
Integrated Ramp Control 整体匝道控制
Integrated Service Digital Network ISDN 整体服务数字网络
Integrated Services on Lease 整合租用
Intellection or identification 运用智能;辨明
Intelligent Transportation System ITS 智能型运输系统
Intelligent vehicle 智能车
Intended Running Speed 期望行车速率
Intensity 光度;光的强度
Intensity and Duration of Rainfall 降雨时间与密度
Intercepting Drain 截水管
Interchange 交流道
Interchangeability 相互交换性
Intercity Bus 公路客运汽车
Intercity bus industry 长途客运(业)
Intercity highway passenger transportation 城际公路客运
Interconnectivity 相互连结性
Interference 干扰绿灯带
Interlocking 连锁控制
Interlocking Plant 连锁装置
Intermodal 不同运具间的转换
Internal Offset 内时差
Internal resistance 内部阻力
Internal survey 内区调查
Internal-externaltrip 内区-外区间旅次
International Driver License 国际驾照
International Telecommunication Union ITU 国际电信联盟
Internet 网际网络
Internet Protocol IP 网际网络通讯协议
Internet Service Provider ISP 网际网络服务业者
Interoperability 操作时之相互连网性
Interpolation Method 内插法
Interrupted Delay 干扰延滞
Interrupted flow 受有干扰车流;间断流通
Intersection 交叉路口
Intersection Angle 交角
Intersection capacity 路口容量
Intersection channelization 交叉路口的槽化
Intersection characteristics 交叉路口特性
Intersection design 交叉路口设计
Intersection Point 切线交点
Intersectional delay 交叉路口延滞
Interstate 州际间的(一般指出入受限的公路)
Interstate Commerce Commission ICC 州际商务委员会
Interval 时段
Interview technique 访问法;访谈法
Intoxicated driving 酒后驾车
Inventory 数据库
 楼主| 发表于 2004-9-26 12:58:37 | 显示全部楼层
Jitney 随停公车;简便公车
Job Mix Formula 工地拌合公式
Joint Opening 开口宽度;
Joint Operation of Transport 联运
Jointed Concrete Pavement JCP 接缝式混凝土铺面
Jointed Reinforced Concrete Pavement JRCP 接缝式钢筋混凝土铺面
Joule 焦耳(能量单位)
Journal Resistance 轴颈阻力
Jumbo 钻堡
Junction 路口
Junction box 汇流井
 楼主| 发表于 2004-9-26 13:01:16 | 显示全部楼层
Kalman filter algorithm 卡门滤波法
Kalman filter, Kalman filtering 卡门滤波
Keep right sign 靠右标志
Key count station 关键调查站
Kinematic Viscosity 动黏度
Kink 纽结
Kiss-and-Ride 停车转乘
Kneading Action 辗挤作用
Knot 节(等于每小时1.85公里)
Knowledge Base 知识库
Kurtosis 峰度
