查看: 2767|回复: 0
高手请进!CFDesign7.0和Pro/E wf2.0能链接吗?
发表于 2005-3-9 21:04:00 | 显示全部楼层 |阅读模式
装了一个CFDesign7.0,可是挂不上Pro/E  wf2.0,按安装说明:“For CFdesign with Pro/Engineer Installations:After the installation is completed, copy the protk.dat from the CFdesign installation folder into the text sub-folder of your Pro/Engineer installation.”设置后并没有在Pro/mechanica模块菜单下出现CFD菜单,老大可不可以帮帮忙啊?先谢过了!E:lillquan@21cn.com
