查看: 12700|回复: 21
氢气/氧气/氩气爆震燃烧流场详细结构(II)
发表于 2004-12-10 10:14:27 | 显示全部楼层 |阅读模式
detonation simulation of gas mixutre(H2:O2:AR=1:1:7) at temperature 298K and pressure 6670Pa.
clear and detailed triple point structures are obtained
 楼主| 发表于 2004-12-10 10:15:46 | 显示全部楼层
either pressure contours and temperature contours can provide detailed structures of flow field
 楼主| 发表于 2004-12-10 10:17:06 | 显示全部楼层
close-up of pressure contours around the triple points
 楼主| 发表于 2004-12-10 10:18:06 | 显示全部楼层
close-up of temperature contours around its triple point
 楼主| 发表于 2004-12-11 12:34:07 | 显示全部楼层
 楼主| 发表于 2004-12-11 12:34:54 | 显示全部楼层
pressure contours
 楼主| 发表于 2004-12-11 12:35:29 | 显示全部楼层
h2o
 楼主| 发表于 2004-12-11 12:36:02 | 显示全部楼层
OH
 楼主| 发表于 2004-12-15 12:07:28 | 显示全部楼层
[这个贴子最后由wangdingxi在 2004/12/15 12:08pm 第 1 次编辑]
here is the pressure contours at t=239.94us,the regular detonation cells can be seen clearly from the pressure contours.Acoording to the classification of detonation,it should belong to ordinary detonation which poessesses smaller detonation cell size than marginal detonation
发表于 2004-12-21 13:00:06 | 显示全部楼层
what is the triple point ?
 楼主| 发表于 2004-12-26 18:12:08 | 显示全部楼层
下面引用由tailor1st在 2004/12/21 01:00pm 发表的内容:
triple point is the intersection of  three shocks:incident shock,mach stem and transverse wave
发表于 2005-1-18 15:31:02 | 显示全部楼层
thank you very much! But what does that point mean?
发表于 2005-1-18 20:26:53 | 显示全部楼层
非常漂亮的图片!
 楼主| 发表于 2005-1-18 21:18:33 | 显示全部楼层
下面引用由tailor1st在 2005/01/18 03:31pm 发表的内容:
the triple point plays an important role in the formation of regular structure in the flow field of gas mixture detonation.Actually the triple point is not the unique point for flow field of gas mixture detonation,the terminology is borrowed from gas dynamics.
发表于 2005-2-12 16:29:10 | 显示全部楼层
请问您用的是什么求解器?CFX还是Star-CD?能把网格和solution show给我们吗?
