查看: 2079|回复: 0
询问一个kiva的图形输出问题
发表于 2007-7-14 16:53:23 | 显示全部楼层 |阅读模式
大家好,最近在用kiva3v做毕业设计。但是碰到一个问题,为什么我用a.out输出图形文件的时候只运行了头上一小部分就停止了,我应该在哪些文件中找错误呢,可能是什么错误呢,谢谢。输出结果是这样的。
The mesh is moving
and you will split the grid.
New files will be created with basename tst
The specie(s) is/are given as mass fraction(s)
Reading results from file itape9 from kiva3v
------------*NOT* selected -----------
amu, temp, sie, tke, eps, lnsl, convex
wfilm, equiv, mach, zmean, zvar, sootm, c2h2f, c2h2ox
pref, preox, sootf, sootox, dpart, c14h30, is...o2., is...n2.
is..co2., is..h2o., is...co., is...h2., is...oh., is....r., is....b., is....q.
C, NO, C2H2, PRE, N2O, NO2, N
---------------SELECTED---------------
rho, p
dump   0, ncyc=    0, crank =-150.00, np=    0
dump   1, ncyc=    1, crank =-149.86, np=    0
dump   2, ncyc= 1029, crank =  -4.98, np=    0
--end of file--
The name of the casefile is : case
