查看: 5448|回复: 3
[求助]请指教:众所周知,点偶极子是不会产生环量,那为啥能用她作计算……
发表于 2006-6-9 20:34:12 | 显示全部楼层 |阅读模式
计算定常、有升力物体绕流的分布奇异元?
但,前人在著作中指出,点源(汇)是不会产生环量,
那就不能用她作计算定常、有升力物体绕流的分布奇异元。
参见:John D.Anderson Jr.的Fundamentals of Aerodynamics
     Katz,J.的From Wing theory to panel method.
于是,我不免发出此疑惑。
感谢,解惑。
发表于 2006-6-20 12:19:27 | 显示全部楼层
Point sources and point-source dipoles are two different kinds of fields.
Any two-dimensional flow field can be decomposed into a divergence component and a vorticity component. Similarly, a point forcing/source to a fluid could be a divergent point forcing, a vorticity point forcing, or a combination of the two.
Responses to the forcing by point sources and point-source dipoles can often be derived analytically, say, in the book recommended by 周华:
下面引用由周华在 2006/06/01 00:54pm 发表的内容:
最近在图书馆的旧书中找到一本书,Lighthill的Waves in Fluids,里面主要讲了4种波,声波、激波、表面波、重力波,应该能很好回答楼主的问题。我们气动专业的在学气动基础时学过声波和激波(膨胀波),表面波和重力波没有涉及过,后面两种波动问题研究水波的人接触比较多。Lighthill这本书是对各类教科书的一个补充,推荐一下!
 楼主| 发表于 2006-6-20 18:30:54 | 显示全部楼层
Thanks,coolboy .
I would refer to the book,if possible.
发表于 2006-6-21 00:01:20 | 显示全部楼层
点偶极子与平直来流的流场叠加可以形成圆柱绕流流场,在面元法中经常用于模拟物体的厚度分布,所以xumustc可以仔细看看原文献中是否还有其它奇异单元,比如点涡,否则根据茹柯夫斯基定理确实无法产生升力。
