查看: 8964|回复: 6
How to create a new solver?
发表于 2009-2-13 15:45:09 | 显示全部楼层 |阅读模式
How to create a new solver based on a standard solver (such as interFoam)?
I want to add temperature and non-newtonian properties to interFoam.
Any suggestions?
Best regards.
发表于 2009-2-21 21:16:49 | 显示全部楼层
Hi
  try to look at the code of interFoam in application/solver/multiphase.and you will find more informations.and the EHDFoam is a solve based on the interFoam with Electrostatic add-on.maybe usefull for you.
Regards
 楼主| 发表于 2009-2-23 11:28:09 | 显示全部楼层
回复 2# OpenFOAM 的帖子
Thanks a lot.
I'm trying to modify the solver--interFoam to overcome the problem.
Firstly,I added the temperature field in createFields.H
Secondly,adding TEqn.H and put it after the PISO loop.
Then, wmake. I got the rhcmFoam solver.
In case design ,I got the following warning:
| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \\    /   O peration     | Version:  1.5                                   |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
|    \\/     M anipulation  |                                                 |
Exec   : rhcmFoam
Date   : Feb 23 2009
Time   : 08:40:49
Host   : linux-3hds
PID    : 5951
Case   : /home/OpenFOAM/OpenFOAM/OpenFOAM-1.5/run/tutorials/rhcmFoam/damBreak
nProcs : 1
Create time
Create mesh for time = 0
Reading environmentalProperties
Reading field T
--> FOAM Warning :
    From function Field<Type>::Field(const word& keyword, const dictionary& dict, const label s)
    in file /home/OpenFOAM/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Field.C at line 252
    Reading "/home/OpenFOAM/OpenFOAM/OpenFOAM-1.5/run/tutorials/rhcmFoam/damBreak/0/T::leftWall" from line 25 to line 26
    expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0.
--> FOAM Warning :
    Reading "/home/OpenFOAM/OpenFOAM/OpenFOAM-1.5/run/tutorials/rhcmFoam/damBreak/0/T::rightWall" from line 31 to line 32
--> FOAM Warning :
    Reading "/home/OpenFOAM/OpenFOAM/OpenFOAM-1.5/run/tutorials/rhcmFoam/damBreak/0/T::lowerWall" from line 37 to line 38
--> FOAM Warning :
    Reading "/home/OpenFOAM/OpenFOAM/OpenFOAM-1.5/run/tutorials/rhcmFoam/damBreak/0/T::atmosphere" from line 43 to line 44
Reading field pd
Reading field gamma
Reading field U
Reading/calculating face flux field phi
Reading transportProperties
Selecting incompressible transport model Newtonian
Calculating field g.h
time step continuity errors : sum local = 0, global = 0, cumulative = 0
DICPCG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Courant Number mean: 0 max: 0
Starting time loop
deltaT = 0.00119048
Time = 0.00119048
MULES: Solving for gamma
Liquid phase volume fraction = 0  Min(gamma) = 0  Max(gamma) = 0
DICPCG:  Solving for pd, Initial residual = 0, Final residual = 0, No Iterations 0
    gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type uniform)
    on patch leftWall of field T in file "/home/OpenFOAM/OpenFOAM/OpenFOAM-1.5/run/tutorials/rhcmFoam/damBreak/0/T"
    You are probably trying to solve for a field with a generic boundary condition.
    From function genericFvPatchField<Type>::gradientInternalCoeffs() const
    in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 692.
FOAM exiting
发表于 2009-2-25 01:05:03 | 显示全部楼层
It seem that there is something wrong with your boundary definition in T.would you mind post you T file?
发表于 2009-3-10 15:12:25 | 显示全部楼层
应该是温度T的边界条件定义问题,肯定是写T文件中边界条件中出错了,expected keyword 'uniform' or 'nonuniform', assuming deprecated Field format from Foam version 2.0.
发表于 2009-3-10 15:15:19 | 显示全部楼层
以下是U的边界条件定义
boundaryField
    leftWall
        type            fixedValue;
        value           uniform (0 0 0);
    rightWall
        type            fixedValue;
 楼主| 发表于 2009-3-11 17:36:16 | 显示全部楼层
多谢二位,温度边界条件定义错了。现在问题解决了:)
