查看: 4692|回复: 0
CFX 10.0 浮点溢出的问题
发表于 2009-3-6 09:20:50 | 显示全部楼层 |阅读模式
在用CFX 10.0计算气液两相流时,出现浮点溢出错误,改了很多条件,包括网格密度、时间步长。错误还是不能解决,计算迭代100多次后,出现如下信息,请求帮助。
Parallel run: Received message from slave
Slave partition :        8
Slave routine   : ErrAction
Master location : RCVBUF,MSGTAG=1033
Message label   : 001100279
Message follows below - :
| ERROR #001100279 has occurred in subroutine ErrAction.             |
| c_fpx_handler: Floating point exception: Overflow                  |
Slave partition :        8
| Stopped in routine c_fpx_handler:                                  |
|                An error has occurred in cfx5solve:                 |
| The CFX-5 solver exited with return code 1.   No results file has  |
| been created.                                                      |
End of solution stage.
| The following user files have been saved in the directory          |
| /home/airtaohui/libo/gasinducing10_001:                            |
| mon        |
