查看: 3869|回复: 0
[转载]solvers>>basic>>scalarTransportFoam的说明
发表于 2009-5-1 20:05:44 | 显示全部楼层 |阅读模式
createFields.H
//提示读入温度场
Info<< "Reading field T\n" << endl;
//温度场创建,标量场,需要初始化文件,下面各项具体含义,参看以前solver的说明
volScalarField T
        IOobject
            "T",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh
//提示读入速度场
    Info<< "Reading field U\n" << endl;
//速度场创建,各项意义,前面solver说明中已经给出
volVectorField U
        IOobject
            "U",
            runTime.timeName(),
            mesh,
        mesh
//读入参数提示
    Info<< "Reading transportProperties\n" << endl;
//根据名字为transportProperties的参数文件构建参数字典,以便查找。
IOdictionary transportProperties
        IOobject
            "transportProperties",//参数字典文件名字
            runTime.constant(),//参数字典文件位置
            mesh,              //网格对象
            IOobject::MUST_READ,//需要读入文件
            IOobject::NO_WRITE //不对文件进行重写
//查询参数字典提示
    Info<< "Reading diffusivity D\n" << endl;
//参数字典查询,初始化带单位标量DT(温度扩散率)
dimensionedScalar DT
        transportProperties.lookup("DT")
//创建表面流率场,该文件位于
//src &#187; finiteVolume &#187; cfdTools &#187; incompressible
#   include "createPhi.H"
scalarTransportFoam.C
#include "fvCFD.H"
//主程序入口
int main(int argc, char *argv[])
//设置case目录相关,位于src &#187; OpenFOAM &#187; include
#   include "setRootCase.H"
//创建time对象runTime,位于 src &#187; OpenFOAM &#187; include
#   include "createTime.H"
//创建网格对象mesh,位于src &#187; OpenFOAM &#187; include
#   include "createMesh.H"
//创建场对象,前面已经详述
#   include "createFields.H"
//提示计算标量传输方程
    Info<< "\nCalculating scalar transport\n" << endl;
//显示当前courant数,位于src &#187; finiteVolume &#187; cfdTools &#187; incompressible
#   include "CourantNo.H"
//计算主流程
    for (runTime++; !runTime.end(); runTime++)
//显示当前时间(物理时间,非cpu耗时)
        Info<< "Time = " << runTime.timeName() << nl << endl;
//读入simple算法控制参数,位于src &#187; finiteVolume &#187; cfdTools &#187; general &#187; include
#       include "readSIMPLEControls.H"
//网格非正交循环
        for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
//构造并求解方程
            solve
                fvm::ddt(T)  //非稳态项,隐式离散
              + fvm::div(phi, T) //对流项,隐式离散
              - fvm::laplacian(DT, T) //扩散项,隐式离散
        runTime.write(); //求解结果输出,由于采用了注册机制,所有AUTO_WRITE声明的变量,
//都会输出
    Info<< "End\n" << endl; //提示程序结束
    return(0); //返回0
转自OpenFOAM研究:http://blog.sina.com.cn/openfoamresearch
[ 本帖最后由 su_junwei 于 2009-5-2 18:31 编辑 ]
