查看: 8686|回复: 3
[转载]如何使得OpenFOAM的solver自动调节时间步长
发表于 2009-5-7 19:08:06 | 显示全部楼层 |阅读模式
OpenFOAM很多求解器时间步长都是恒定的,这使得我们在CFD计算的时候不得不一个一个的试。求解器时间步长的自动调整会节省我们很多时间。下面以icoFoam为例谈谈如何动态设定时间步长。其实OpenFOAM已经为我们定制了自动调节时间步长的功能,如果要使用这个功能,需要以下几个头文件。
//读入动态设定步长相关参数
#   include"readTimeControls.H"
//计算CourantNo
#   include "CourantNo.H"
//初始化设定时间步长
#   include"setInitialDeltaT.H"
//根据CourantNo重新设定时间步长
#      include "setDeltaT.H"
要让程序自动调节时间步长,主要分4个步骤,下面在icoFoam中实例
#include "fvCFD.H"
int main(int argc, char *argv[])
#   include "setRootCase.H"
#   include "createTime.H"
#   include "createMesh.H"
#   include"createFields.H"
#   include"initContinuityErrs.H"
//步骤1:将前3个头文件加到这里。
//读入动态设定步长相关参数
#  include "readTimeControls.H"
//计算CourantNo
//初始化设定时间步长
#  include "setInitialDeltaT.H"
   Info<< "\nStarting time loop\n"<< endl;
//步骤2将for循环改成while循环
//    for (runTime++;!runTime.end(); runTime++)
   while(runTime.run())
       Info<< "Time = "<< runTime.timeName()<< nl<< endl;
#      include "readPISOControls.H"
//步骤3:将重新设定步长的头文件写到这
       fvVectorMatrix UEqn
           fvm::ddt(U)
         + fvm::div(phi, U)
         - fvm::laplacian(nu, U)
       solve(UEqn == -fvc::grad(p));
       // --- PISO loop
       for (int corr=0; corr<nCorr; corr++)
           volScalarField rUA = 1.0/UEqn.A();
           U = rUA*UEqn.H();
           phi = (fvc::interpolate(U) & mesh.Sf())
               + fvc::ddtPhiCorr(rUA, U, phi);
           adjustPhi(phi, U, p);
           for (int nonOrth=0; nonOrth<=nNonOrthCorr;nonOrth++)
               fvScalarMatrix pEqn
                   fvm::laplacian(rUA, p) == fvc::div(phi)
               pEqn.setReference(pRefCell, pRefValue);
               pEqn.solve();
               if (nonOrth == nNonOrthCorr)
                   phi -= pEqn.flux();
#          include "continuityErrs.H"
           U -= rUA*fvc::grad(p);
           U.correctBoundaryConditions();
       runTime.write();
       Info<< "ExecutionTime = "<< runTime.elapsedCpuTime()<< " s"
           << "  ClockTime = "<< runTime.elapsedClockTime()<< " s"
           << nl<< endl;
   Info<< "End\n"<< endl;
   return(0);
//步骤4:进入控制台重新编译程序
打开控制台,进入/applications/solvers/incompressible/icoFoam/
wmake
如何使用自动调节步长功能呢?
打开case文件夹下system/controDict
FoamFile
   version    2.0;
   format     ascii;
   class      dictionary;
   object     controlDict;
application icoFoam;
startFrom      startTime;
startTime      0;
stopAt         endTime;
endTime        2;
deltaT         0.1;
writeControl   runTime;
writeInterval   0.1;
purgeWrite     0;
writeFormat    ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat     general;
timePrecision   6;
runTimeModifiable yes;
//加入下面的就行了
adjustTimeStep yes;   //想变成静态步长,no即可
maxCo          0.5;  //如果Co 数大于 0.5则减小步长
maxDeltaT     1;   //最大时间步长
运行程序测试一下。
如何让程序自动调节步长的介绍已经完毕,是不是很简单?
转自OpenFOAM研究:http://blog.sina.com.cn/openfoamresearch
发表于 2009-6-29 14:41:22 | 显示全部楼层
呵呵 用上了。。。补充一条:
在while 循环里需要记得加上
runtime++;
呵呵否算了半天都反复存到初始条件里去了。 那样就惨了。中间结果一个也没有不说。初始条件也挂了
[ 本帖最后由 OpenFOAM 于 2009-6-30 11:23 编辑 ]
发表于 2010-11-20 15:49:45 | 显示全部楼层
自动调节时间步长
针对步骤3:OpenFOAM-1.7.1里许多*Foam.c中时间循环为 :
while (runTime.loop()),
循环中是否不需要加 runtime++了?
下面两段代码是否相等?
while (runTime.run())
                     runTime++;
                     solve;
                    runTime.write();
                    solve;
                    runTime.write();
发表于 2012-9-19 11:22:40 | 显示全部楼层
wmake出错
楼主你好,我是OpenFoam初学者。我按上面的步骤,把solvers/compressible/rhoPimpleFoam 的主程序该写了一下,然后wmake时出现下面的问题:
/opt/openfoam211/src/finiteVolume/lnInclude/CourantNo.H:39: error: ‘phi’ was not declared in this scope
请问这个怎么弄?
